Question about Epson LQ-2180 Dot Matrix Printer
Epson lq-2180 printer pause light continously on
I have epson lq-2180 printer with the following problem:The pause light is continously on and am unble to print. when i try to print nothing is happeninig.
  • 4 Answers
If u use up tractor use down tractor or inverse the operation
coz your problem is in paper sensor in up or down printing
Posted on Feb 20, 2009
  • Javaid Iqbal Jan 25, 2011
    Guys , there is big transparent cover on top of printer just take it out and put it back and make sure it sits properly in grips , then ur problem is solved , i was facing the same problem now it works perfect.. no problem what so ever.
First you check the cover switch may be it is not working than do the following: remove the front panel button cover, remove the two pin connector and short these 2 points by soldring them or by using jumper, the pause button problem will be removed
Posted on Jan 18, 2009
  • bnyaberi Sep 24, 2010
    It is not Helpful.Another Soln?Boaz
  • Eswaraiah Poluru
    Eswaraiah Poluru Oct 22, 2013
    nice advise thanks i fix my problem eswar kuwait
Epson lq-2180 printer paper out & pause Indicator continously on
I have epson lq-2180 printer with the following problem: Paper out & pause indicator is continously on when I try to print. The paper is rolling when I push pause button.
Jan 22, 2013 | Epson LQ-2180 Dot Matrix Printer
Epson LQ-2180 loading papar continuesly, and pause button is on.
Possible fault in the mother board, look like the loading control driver is faulty and is running off.
You might have to check the input of the motor drive to see if there is a signal from the mP or it is shorting to run.
Sep 30, 2010 | Epson LQ-2180 Dot Matrix Printer
Printing problem
sir, we have a problem to install a printer that "printer driver cannot be installed. your computer system may be in an abnormal condition. please exit window and try again". how to solve this problem.
Mar 07, 2009 | Epson LQ-2180 Dot Matrix Printer
Page setup
see the paper length you are using
ex. 8.5 X 12 "
set the paper length programatically by using following command
?? chr(27)+chr(67)+chr(0)+chr(12)
Jan 09, 2009 | Epson LQ-2180 Matrix Printer
The pause light continous blinkiing
plz check the ink status and check is there any paper jam
Nov 01, 2008 | Epson LQ-2180 Dot Matrix Printer
Lq-2180 continous blinking
Please read through these instructions first and then follow the steps below:
1. Please power the printer OFF.
2. Remove the printer cable from the back of the printer and remove all the paper as well.
3. Hold down the "FONT" and "TEAR OFF" buttons and turn the printer on.
4. Continue holding the "FONT" and "TEAR OFF" buttons down for five (5) seconds and then release both at the same time.
5. Power the printer OFF.
6. Reconnect the printer cable.
7. Reinstall paper and ensure the thickness selector is in the correct position and that the path selector is also correct.
If the situation persists, remove the ribbon and paper and slide the print head back and forth so that it makes contact on both sides forcefully enough to make a loud noise. Reload the ribbon and the paper and try your test again.
Dec 07, 2007 | Epson LQ-2180 Dot Matrix Printer
Epson LQ-2180 Dot Matrix Printer Logo
4,558 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
