455 could be gas cap but could be leak in system,102 mass flow sensor,try to clean with spray like brake cleaner,113 intake air temp.1450&455 gas problem.
If your A/C is on , or you are running the climate control in the defrost windshield mode , the engine will idol higher than normal. A Vacuum leak could also cause a high idol.. check the vacuum lines and be sure they are in good condition and all plugged in.
did you replace both 02 sensors? 02 sensors and camshaft position sensor do most of the engine timing. A bad vacuum hose will throw the timing off as well.
It either has a vacuum leak or a dirty MAF. To test for vac leaks spray the engine with carb cleaner to see if the engine speed changes., if it does you fond the leak. The most common leak is pcv line coming straight off the back of the throttle body. Check there first. Also check to make sure there are no air leaks between the throttle body and the mass air flow. Don't replace the idle speed motor or the tps, they won't fix it. It is possible the o2 is the problem, but it usually isn't. P0107 Is usually always from the stuff i listed above.
I decided to check the idol air control valve,when I removed it I found the problem right behind it. The P C V valve hose was just about into where it fastens to the intake,the other end was bad also. Cost me aout $6.00 Where auto parts stores were telling me parts would cost two or three hundred $$.
my ford explorer is idleing high when i crank it up
