Question about Kenmore 24032\24036 Top Load Washer
Dual Agitator not working
I have a Kenmore 80 series washer and the dual agitator only works on the lower half. A full load of clothes does not get washed properly. When I spin top half sounds like stripped gears in a transmission. When I press down hard on topof agitator it works with lower half. How do I fix the problem. Alo is it a hard job or should I call service. I hate to really break it!
  • 30 Answers
The agitator dogs*the part which pulls the top with the bottom* have worn out. They are relativley cheap and easily replaced.
Posted on Jun 13, 2010
  • 5,911 Answers
If the upper portion of the agitator is not working, this is commonly caused by worn agitator dogs. The following link explains:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
Yes...there is such a thing. These small plastic pieces have been the source of many trouble calls and only cost a few dollars to replace if you know how to do it. Replacements can be ordered on line at searspartsdirect.com, appliancepartspros.com, or repairclinic.com. Use your model number for the search criteria and look under the "Agitator Parts" section. The link also give instructions on how to remove the agitator. This is a very simple repair, that only costs a few dollars. If you wish not to order on
line, use the part number provided by the Sears website and go to your nearest appliance parts retailer. This is a common part they will have in their inventory. If you require further assistance, please let me know. I hope this helps you.
Posted on Jan 09, 2009
Kenmore Series 80 washer. Agitates too slow
check the dogs in the agitator take off the cap it should rachett if it turns free replace the dogs in the agitator
Jul 12, 2010 | Kenmore 24032\24036 Top Load Washer
Dual action kenmore 70 series washer need to remove agitator
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if your "Agitator Dogs" are damaged or broken. These are plastic pieces that allow the top agitator to turn only one way.
Please see the following for how to access and replace them if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=39649e541343127154c647348d1156d9
Basically,
1. Remove the fabric softener dispenser.
2. Using a short flat blade screwdriver, remove the cap.
3. You may see a 1/2" square plastic nut.
I've used a 1/2" extension for a socket set to remove the nut.
4. Pull the top agitator off and turn it over carefully.
You should see the agitator dogs (per the illustrations).
Replace them if necessary and re-mount the agitator, tighten the bolt carefully, put the cap and fabric softener dispenser back on and the top part of the agitator should only turn one way.
Nov 06, 2009 | Kenmore Washing Machines
Kenmore Series 80 Washer, Model 20852 - Agitator not turning well, making noise
Hi, If the washer spins properly but the agitator does not work, it could be the dog kit needs replaced. If the washer does not agitate or spin, it is probably the coupler.
Put the washer in wash cycle with no laundry in it and see if the lower prt of the agitator moves. If the agitator moves, try and hold the upper half of the agitator and see if it will only move one direction.The agitaor dog kit is designed to only let the top part of the agiator to grab one way. When they go bad, they can make some noise.
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16” bolt and lift the agitator out of the washer. Separate the 2 halfs of the agitator and replace the dog kit inside the upper part of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | Washing Machines
Spin cycle is not working right,
This is a problem in your transmission. Not Good!
May 18, 2009 | Washing Machines
Washer does spin but barely agitates
It sounds like the agitator dogs are worn.
To remove the agitator, pry off the agitator cap and remove the bolt that holds down the agitator. With the bolt out pull up on the top section of the agitator (auger) to remove it. Underneath the auger you should see 4 small white or beige plastic gears (dogs). . Replace those and it should be ok.
The part number is 80040
Let me know if you need more assistance.
Apr 08, 2009 | Kenmore Washing Machines
I have a Kenmore Series 80 washer that agitates a little but is very weak. Spins Ok. Clothes don't clean very well. I need help.
Check the agitator by turning it back and forth. It should work like a ratchet (turns one way, locks the other way).If you're able to turn it in both directions, the agitator dogs are worn and need to be replaced. To do this remove the agitator cap and the bolt that holds down the agitator. With the bolt out you can remove the top section of the agitator (auger) where you should see 4 small white or beige plastic gears (dogs). Replace those and it should be ok.
Feb 23, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Top half of dual agitator stop working.
Most likely th agitatot dogs have worn out.. The part number is80040. They are located inside the agitator thy look like quotation marks. There is also a kit available which includes the dogs but more often it is just the dogs that are the problem. Good Luck.
Jan 09, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series agitator problem
time to look for a new washer, this is a gearcase problem, or cluth. Not easy to fix , unless know how.
Nov 08, 2008 | Washing Machines
Kenmore 70 series washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Jul 19, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
123 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
