Question about Intel Desktop Board D815EEA2 (BOX815EEAA2) Motherboard
Power cord getting shorted when connected - Intel Desktop Board D815EEA2 (BOX815EEAA2) Motherboard
  • 39 Answers
Ok... explain a bit more. Is the cable being shorted, and the pc won't boot? Or does it just short when you plug it into your power supply? In that case, don't worry, it's normal. If you don't like it (like me) try turning off the power supply if i has a switch at the back, or just plug it into the pc first before plugging into the wall. :)
Posted on Jan 09, 2009
Power cord is shorting out
The cable guy may have bumped the power connector and loosened it. Try pushing it in firmly. Sometimes the power connections get loose over time
Oct 03, 2012 | Toshiba Televison & Video
I think i shorted out my motherboard with another inverter to powerful now pc isnt coming on compaq 442875-001
Connect a known good inverter and Screen with the laptop's battery removed and power cord disconnected. The motherboard will power up without a screen or inverter connected if it's working. If not check F1 or FS1 on the main board power supply section. Also check the diodes in that area for shorts. Sometimes what happens is the screen or inverter gets plugged in while the battery or power cord is connected. Even thou the laptop is powered off it still has the standby voltage live.
Jul 18, 2011 | HP Compaq Presario F500 F700 and G6000...
When we plug in the dishwasher da4441s it short circuits.
The short circuit may be located in the junction box from which the dishwasher gets power.
Its probably bare wires touching under the "skirts" of two wire nuts.
If no power problems, then the dishwasher itself has a short. In this case, start locating the short in the
little box to which the power cord is connected - these connections will short if one of the
hot wires, or a hot wire spade lug is touching a frame ground (all components of the frame are grounded).
A third (remote) possibility is a wiring mistake - the dishwasher hot & neutral could be connected, causing a dead short.
May 13, 2011 | Dishwashers
The cord needs to be jiggled where it attaches to the unit, in order for it to work. I've tried to duct-tape it in place but eventually the power goes off. What is the solution?
The connectors in the cord have been worn and do not connect as they should. I suggest getting a new cord and this should fix the problem. The radio is shorting and thats why you have to duck tape the cord - to get the cord to stay in a position where the connectors are actually connecting.
Mar 26, 2011 | RCA RCD118 CD Boombox
Power connection short
If your power cord is not reaching to the place you want then use need to use spyker.It is type of device which is used to extend the power connection or you just plug the power cord into spyker and give power to it
Jun 05, 2010 | Computers & Internet
One red light flashing bottom right , what is wrong .
A single flashing light can mean a hardware failure. Did you get an error code? EXX where XX is a number...like 74 for instance? Please, let me know, and try this.
Power off the system and unplug everything from it..controllers, memory cards, av connection, power cord, and hard drive. Also unplug power cord from socket and the short cord from the power brick. Then reattach everything making sure the connections are firm and power back on your system. If this did not resolve the problem.
Apr 02, 2010 | Microsoft Xbox Console
Wont power up, power cord good. once plugged into laptop power cord stops working
As long as you are abslolutely sure the power cord is functional, without a more indepth analysis, it seems/sounds like the AC connection to the board is broken.
To rule out this conclusion as the failure point, see if you can borrow/buy or better yet, recharge your battery {assuming it has no charge left at this point}
Stick the charged battery into your rig and if it works, yes. The AC connection is broken - nothing a little bit of soldering won't fix.
If it works, will need to ask more 'protocol questions to narrow down the situation'.
...when you reflect on the usage of the laptop, is there a bit of manhandling when connecting the power cord? Do you run it mainly plugged into AC? Dell is infamous for dodgy AC connections strongly lending credence to a broken AC connection to the mobo.
Dec 07, 2009 | Dell Inspiron B130 Notebook
Glitch with the power jack on our DRC630N
Return it for warrenty sevice,the connection jack port ave some kind of shorts.
Jun 29, 2009 | RCA DRC630N Portable DVD Player
Machine powers up anytime the power cord gets plugged into it, is there a solution to fix this problem?
If the machine powers up the moment you connect the power cord, you most likely have a short on your motherboard. It could be as simple as too much dust gathering, or the motherboard itself isn't tightly secured to the chassis. Make sure all power connections are securely fastened to the motherboard.
May 05, 2009 | Computers & Internet
Unit trips circuit breaker when plugged in
On AC current it really makes no difference to the operation of the unit which terminal the wires are connected to as long as the circuit is completed. A reason for the inverted wiring is that there will be a resistance between the hot wire and the control circuit. It makes for a reduced load on the contacts and switches minimizing arching.
Jun 08, 2008 | Maytag Portable Air Conditioner M6P09S2A
Intel Desktop Board D815EEA2 (BOX815EEAA2) Motherboard Logo
22 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
