Question about Indesit W 123 Front Load Washer
Spinning I have a hotpoint washing machine WD420, does everything but spin and pump out, there is a tackling sound when it comes to spinning and wont do it. Can anybody advise me.
  • 3,741 Answers
Bearing is bad.its located on the motor.it is rusted and got totally dried up.the oil on the bearing is completely got over so its not moving frequently.so first put some oil on the motor bearing and wait for some time and check out.if still the same noise the bearings got worn out.so motor needs replacement.only spare bearing are very rare to get. --------------- If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Oct 01, 2009
What can be causing my washing machine making roaring sound during spin cycle
Could you have lost a coin or something else out of a pocket that has found its way into the motor.
Jun 29, 2014 | Hotpoint Ariston Aquarius WD420 Front Load...
Whay my Hotpoint -Ariston Aquarius WD420 Front Load All-in-One Washer / Dryer stpos have way the circle
You say it stops half way through cycle (if I have read it right), especially when fast spin starts. Does it stop anywhere else (in wash cycle or rinse cycle)?
I would check the main filter in the sump (pipe from drum to drain pump) and ensure pump itself is not blocked which could cause the pump out time to be exceeded and thus stop the program. A faulty pressure switch could also be responsible.
I would also check the tacho on the motor and connections to main board at bottom of machine near to motor.
Disconnect machine by pulling out plug and wait 10 minutes for capacitors to discharge before doing anything, to protect yourself against residual voltages.
From a retired engineer who owns one of these machines.
Jul 28, 2012 | Hotpoint Ariston Aquarius WD420 Front Load...
My Hotpoint Aquarius WD420 does not wash properly. It doesn't seem to take in any hot water and the drum does not turn, it just sways from side to side and does not move on from wash to rinse and spin....
For those problems, you have multiple issues and need a service engineer. It may be just the hot water intake solenoid, but may also be a problem with the logic board or both.
Nov 13, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
Machine does not empty and light flashes
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 11, 2011 | Hotpoint Ariston Aquarius WD420 Front Load...
Machine very noisy when it spins. Missing bra
If you cannot here it catching, then leave well alone, if it is still catching, then you could to try to locate it by removing the lower rear cover of washer, remove the large black hose on bottom of drum, and see if you can locate it from the bottom of the drum.
Hope this helps.
Jan 16, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Washing machine - terrible noise during spin cycle
sounds like the drum is rubbing on some part of an exterior wall of your washer,.or you have a bearing going, or worst case scenario you have transmission problems and need to get a serviceman in to check your machine.But firstI would call the manfacturer and explain the problem they may be able to resolve it over the phone give them model no. Make and year of manfacture they hopefully can help you with this
Jan 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
My hotpoint wd420 is leaking water from out the dispensor and door on a rinse/spin cycle.
You ne to get yure rubber seals checked and changed it sounds like they have perished
Nov 27, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Indesit W 123 Front Load Washer Logo
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
