Question about HP Officejet 5610 All-In-One InkJet Printer
No computer connection
The screen on my hp 5610 officejet all in one says that there is no connection. It is plugged in by USB cable. How do i fix this problem as it is also creating a problem with the scanner. I do not have my cd on hand.
  • Anonymous Jan 15, 2009
    no computer connection
  • Ganesan Chandraiah
    Ganesan Chandraiah May 11, 2010
    What operating system are you using?
    Have you tried with another USB cable?
    When this issue first started? Did you install any new programs or do any Windows update?
Lost my driver
Posted on Jan 15, 2009
Just got a HP laptop for work that's running windows 7. It won't find our HP 5610 printer at home even tho I've downloaded the right driver
Is the printer directly connected to the laptop by a USB cable? Try a new cable. Check that the USB ports work by plugging in a known working device.
If you are using a print server or USB hub, try a direct connection. (If networked, check that your firewall isn't blocking the access by disabling it. If the print server is another computer, make sure that computer's firewall isn't blocking the laptop (trust level between the two machines).
I hope this helps.
Jun 28, 2010 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-in-One
this is may be usb cable problem but you follow this steps to get solved Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online. Also I suggest you to change the usb port and the cable also still if you facing the problem follow these steps, right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd.
Dec 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer is off line on my 5610 how do i get back on line
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aswq1
Sep 07, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp PSC2355 scan function inop
hi,
aswq9
Aug 25, 2009 | HP Officejet 5610 All-In-One InkJet...
My printer won't print. When I go to the set up option, it says
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
ab37
Jul 06, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer cd will not download for hp 5610 The printer has worked for some time. now a message comes ujp that it is not connected to computer
hi,
ab44
Jul 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp officejet 5610
There might be some issues either with the printer cable or the USB port on your system... Just try another cable if you have one... or u can also try another usb port on the system...
Jan 03, 2009 | HP Officejet 5610 All-In-One InkJet...
Installing HP 5610 all in one printer
Please let me know if you have Windows Vista on the new computer and you are putting the Installation Cd to install the printer on the computer.
Please check if Windows Vista written on the CD. If not no problem. Plug the usb cable to the computer and connect printer. Wait while you get the message that the device is ready to use.
Now try printing abd it will work fine.
If it is still not getting installed.....Go to Add/Remove programs and uninstall the drivers for the Printer "Deskjets and Officejet" or anything like that. Then try installing. The issue will be resolved.
Aug 04, 2008 | HP Officejet 5610 All-In-One InkJet...
Driver problem on Vista w/HP Officejet 5610 All-In-One
This issue occurs when the drivers are not installed properly.
Once remove the USB cable from the laptop and insert the all-in-one CD and click on add a device and follow the on screen instructions and connect the USB cable when it prompts at the middle and complete the process. Then restart the computer and then check for the result.
Jun 04, 2008 | HP Officejet 5610 All-In-One InkJet...
Hp officejet 5610 all in one printer
you can use the serial/usb adaptor to connect it to your computer
May 07, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
573 people viewed this question
Ben Johnson
