Question about Lakewood Oil-Filled Electric Radiator Heater
My heater won't turn on.
My dogs knocked my heater over earlier today. so i unplugged it and set it up. that was over 12 hours ago. i came home and tried to turn my heater on and it won't work. HELP!!!
  • Anonymous Jan 22, 2009
    my oil heater wont work either
  • jimbo460 May 11, 2010
    what kind of heater is it?
  • 3 Answers
There really isn't anyway to give a difinitive answer to your problem. it requires some trouble shooting. Did you blow the breaker on the circuit feeding the outlet you had your heater plugged into? Is there a power indicator light on your heater? If so, when the dog tipped the heater over was it still working (ON)? If no indicator the problem gets more tedious and techy.
Oil heaters are great and simply designed. They are closed systems with heating elements that connect to the other end of the wire that plugs into your wall. The switch is in between the two to allow current to pass or not. If any of those connections was shaken loose by the fall it would cause your heater to malfunction. That's something you (or a service person) can only verify by opening the unit up. Hope this has helped...:-)
Posted on Jan 15, 2009
Amana upright commercial freezer not freezing
did you lay it down during transport .if so it needs to stand unplugged for 24 hours .the oil will have run out of the compressor
Sep 26, 2016 | Amana Refrigerators
Model 71-52DB 50 gal. water heater stopped heating
Press the reset button located on upper thermostat
Following link has troubleshoot for electric water heater
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Gene
Jun 13, 2012 | Rheem Water Heaters
WS-65511 won't turn on
Hello
The power supply section to your set has the fault. If you come over me by Fixya paid service purchase, I'll assist you to repair your tV by yourself at home. OK.
Dec 07, 2011 | Mitsubishi WS-65511 65" Rear Projection...
I went to turn on my Samsung a little bit ago, which was working earlier today, and now it won't turn on and is making a clicking noise. The noise does not stop until 10 seconds after I unplug it...
The tv power supply board it got short and already dead some how,tv have clicking noises mean ur tv power supply board are not stable and not regulating high voltages to the rest of the tv other boards.The tv power supply board that the board where the a/c power cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
The heater is turned on. All lights are on. The fan isn't running. No heat is coming out. It was working earlier in the day.
did it get set on its side, there is a saftey switch inside to kickout the heating element if its knocked over, unplug it, pick it up and turn it around at different angles, return upright, shake gently, plug in and see if it puts out heat
Jan 31, 2010 | Vornado TouchStone Vortex Heat 500 Heater
Amana #srd2555w bought from a friend in working condition. 3 yrs old brought home on its side. vacumed coils working 3 days then stopped cooling in fridge followed by ice build up and not working in...
You have a defrost problem. 3 parts: Timer (or "adaptive defrost control"), defrost heater and def. termination thermostat.Find the timer, it shoud be nehind the bottom front grille to the right on Amana (if you see a blck box under there with a sticker on it, it's the ADC model) turn the timer CW until it clicks. Take the back off the bottom of the freezer and listen. After 5-10 minutes if you hear the sound of the sound of water hitting a hot grill. If you hear this the heater and thermo are working and the problem is the timer/ADC. No hiss? Unplug fridge. Check thermo and heater for continuity. Replace the one that's open. If the heater's open, replace the thermo too: Maybe it didn't open soon emouhg and caused heater failure.
Sep 25, 2009 | Amana SXD524VW Side by Side Refrigerator
Won't heat
Try calling delonghi america at 1800 322 3848
Dec 14, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
SELF CLEANING MAGIC CHEF OVEN BOUGHT 24 YRS AGO
That's fairly typical but I would suggest removing the shelves and cleaning those with oven cleaner if they need it at all. Expect the door to remain locked for additional hours for safety.
The temperature rises to > 900 degrees F and is necessary to start the catalytic process that consumes the crud.
Sorry I didn't see your message earlier-
Nov 16, 2008 | Magic Chef 31000 Gas Kitchen Range
Lakewood Oil-Filled Electric Radiator Heater Logo
929 people viewed this question
Top Lakewood Heating & Cooling Experts
Mack Baxter
paulcarew
Superior Maintenance
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
