Question about Alcatel Newbridge MainStreet 3600 Multiplexer
Can't access to alcatel 3600 node managment station from faceplat
I think BD9/RJ45 cable pinout not ok , could you pl,s provid me the pinout wiring cable for SP1 to access to inactive controler shelf redundance
    Problem Solver:
  • 13 Answers
SP1 is belong to VT100
VT100 RJ45 DB9 1 8 2 7 3 2 4 3 5 5 6 4 7 6 8 --
Posted on Aug 10, 2010
Need 3612 mainstreet J8 pinout configurations DB9 to RJ45
DB9 -----------------------------------> RJ45 1 ---------------------------------------> 8 2 ---------------------------------------> 4 3 ---------------------------------------> 3 4 ---------------------------------------> 7 5 ---------------------------------------> 5 6 ---------------------------------------> 6 7 ---------------------------------------> 1 8 ---------------------------------------> 2 9 ---------------------------------------> NC
If not work, invert the RJ45 connector
Mar 03, 2010 | Alcatel Newbridge MainStreet 3612...
I am connecting 4 nodes through 2 switch located at 400ft distance. the data transfer is not working. 2 nodes are connected to each switch, both nodes connected to individual switch communicates with each...
Just to clarify, you have 4 computers connected to two ethernet switches. Two computers are connecteh to each ethernet switch and a network cable connecting the two ethernet switches 400ft apart.
For all the computers to communicate with each other, they all need to be in the same workgroup "name".
The cable joining the two ethernet switches need to be connected to the RJ45 UPLINK port on both the ethernet switches, and the uplink port may have a switch (the switch allows it to function as a standard RJ45 port or a RJ45 uplink port).
If there is no RJ45 uplink ports on the ethernet switches then a cross over network cable is needed to connect the ethernet switches together.
Oct 28, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
No connect to rs232 serial, ports PC
df1c50d.png This is for a newbridge or alcatel 3624 mainstreet channelbank - do not use the modem side, only use the terminal side - all is needed is Rx, Tx, and ground - if looking from the "window" side of rj45 connector, or pins-side up on rj45 socket.
Aug 18, 2009 | Alcatel Newbridge MainStreet 3600...
I need the pinout for the serial cable? RJ45 to DB9
f211598.png This is for a newbridge or alcatel 3624 mainstreet channelbank - do not use the modem side, only use the terminal side - all is needed is Rx, Tx, and ground - if looking from the "window" side of rj45 connector, or pins-side up on rj45 socket.
Aug 03, 2009 | Alcatel Newbridge MainStreet 3612...
We have our all Nodes on our network . They are accessed by NMS at our HQ . But the problem is that When we locally want to access DXX Node via ANM , it is not accessed.Also DXX Nodes SP1 and SP2 are CPSS...
You don’t need to configure SP1 for CPSS, log on to the node via you NMS and change it to VT100, then log in using a hyper terminal session on you laptop. If the SP1 port is setup for CPSS you will have to install a dongle and you will need to set your ANM up for networking meaning that you will have to speak to the node via CPSS. The only time you need to communicate using CPSS on SP1 is when you want to backup the database.
Jun 12, 2009 | Alcatel Newbridge MainStreet 3600...
NewBridge 3600 Mainstreet
Hello
The pinout is determined by the serial port you are plugged into. Are you using serial port 1 or 2. This is pinout from a standard DB9 PC serial port should get you into SP1.
Blue-8
Orange-7
Black-2
Red-3
Green-5
Yellow-4
Brown-6
White-No Connect
Write back and let me know - BAD421
Aug 01, 2008 | Alcatel Newbridge MainStreet 3600...
Alcatel Mainstreet 3600 Anphenol PINOUT
You must have a Dual E1 card that support a 120 ohm interface. There are cards for 75 and there are cards for 120 ohm. Sergio - Argentina
Apr 04, 2007 | Alcatel Newbridge MainStreet 3600...
Need support in configuration
Dear sir
i neeb to configure 3600 B/M of Alcatel
require rj-45 to bd 9pin configuration of console able
regards
Vijay Badade
Aug 24, 2006 | Alcatel Newbridge MainStreet 3600...
Alcatel Newbridge MainStreet 3600 Multiplexer Logo
451 people viewed this question
Top Alcatel Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
