Question about GE DBXR463EBWW Electric Dryer
Heat shuts off after a few minutes
I have a GE dryer and after loading the dryer and turning it on, the heat works for a few minutes and then the heat quits.
  • 166 Answers
The model number listed above appears to be for an electric dryer.
Feel the top of the dryer right next to the backsplash. If this area in the middle gets extremely hot to the touch, then you have a vent problem. Check to make sure that your vent hose is not crimped or blocked in some way. don't use plastic vent hose.
Posted on Nov 15, 2009
  • 716 Answers
Check Replace Thermostat. The Dryer Thinks Its Not Lighting Because The Thermostat Isn't Working.
The Dryer Has A Safety Mechanism So It Wont Flood Your Home With Gas. When The Thermostat Is Broken The Unit Doesn't Detect The Heat And Shuts Off The Gas.
If You Like You CV
Posted on Jan 09, 2009
  • Michael Fisher
    Michael Fisher Jan 09, 2009
    Sorry If You Like I Can Try And Find The Igniter For You As Well But The Best Way Would Be To Order It Directly From Ge Or Get It From A Local Repair Shop.
Ge dryer dcvh515efoww runs on air dry, but when set on any heating cycle, it runs for a few minutes and then it turns off on 00
it is over heating you might have unplugged a wire to the thermostat when you had it apart or the thermostat has went out.
Mar 21, 2014 | GE Dryers
Dryer drum turns, heats, but then heat shuts off before timer has finished.
The heat is supposed to turn off ten to fifteen minutes before the end of the cycle. It's a cool down period.
Jan 08, 2014 | GE Profile DPSB613G Gas Dryer
Front load frigidaire dryer does not heat and runs for a few minutes then shuts off and all the light flick off and on
Checkout the heating element. If it is open the electronics of machine may be programmed to turn it off and blink lights.
Nov 23, 2013 | Frigidaire FEQ1442ES Electric Dryer
My dryer starts, runs a few minutes, doesn't heat up and shuts itself off
check your sensors on the heater unit, there are two or more, simply us a meter and make sure power is on both sides of the sensor, if not then that specific sensor is bad and you should replace it, pull the sensor and tie the two wire together to see if it will heat, if it does replace the sensor they are cheap and will keep you from burning down the house
Dec 31, 2012 | GE DWSR463EGWW Electric Dryer
Have had a repair man out 3 times. Replaced igniter and gas regulator. Dryer will heat for a few minutes then stop heating. When I try to turn it back on, it will not turn on at all for about 10 minutes.
Are you saying the dryer will not start again after a few minutes? That is a motor [problem. Replace motor.
Are you saying dryer starts after a few minutes but will not heat? That is an air flow problem or a gas valve coil problem. Thoroughly clean EVERY single air passage in the dryer and vent tube. If that does not cure it, then replace gas valve coils if the igniter comes on and off.
Jul 02, 2010 | GE DCVH515GF Gas Dryer
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Gas Dryer Model #dbvh512gfoww heat problems
Hi, It sounds like the coils on top the gas valve are bad. If the ignitor glows but shuts off before a flame, the coils need changed.
I hope this helps. If I can assist you further, please let me know.
Thanks
Vic
May 24, 2009 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer -...
GE Profile Gas Dryer - Heat goes on and off
The operating coils get hot and quit. They only cost 20 bucks. Read more about it here:
Gas dryer works then quits then works some more
Mar 31, 2009 | KitchenAid KGYS850LT Gas Dryer
Dryer runs for a few minutes, then shuts off
thermo sensor inside is bad (are you sure ALL vents and pipes are clear?)
Mar 12, 2009 | Dryers
GE DBXR463EBWW Electric Dryer Logo
197 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
