Question about HP Photosmart 315 Digital Camera
White spot on photo
I get a whte spot on photo when i take a picture
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, this would be a temperature imbalance on the CCD lens. Often white spot(s) appear at night or when the temperature is cold. Workaround is to open the lens but delay taking a picture after a few seconds. The idea is allow the lens to match the ambient temperature.
Good luck and Thank you for using FixYa.
Posted on Jan 09, 2009
  • 565 Answers
Have u cleaned the lens
How do I know where to hook wires p on model 621MM master mechanic door opener
Your wires should be color coded blk/ white & solid white you will have a pair for each sensor twist the white wires together and twist your blk/wh wires together now on the back of the opener you should have three screws connect whites to the middle screw a(2) and your blk/white to the third screw (3) your sensors should light up now u should have a solid whte and red/whte connect red/whte to #(1)screw and white to #(2) your wall button should be lite
Mar 06, 2015 | Sears Craftsman LiftMaster Chamberlain...
I have black spots on my Panasonic Lumix DMC-ZS8 lens camera
If you want to know if these spots are on the sensor. Or you want to exclude this, You could try this:
Put the camera in A priority. (manual mode). Turn the aperture to the highest setting. Greatest figure like f 22 I can't find the exact figure. It could be it is only 8. Then in a bright light, take a picture of a white sheet of paper. The picture that comes out, should be checked on dark spots. If they are there the spots are on the sensor. If you can't find the spots on the white picture, something else is wrong.
Feb 12, 2014 | Panasonic Lumix DMC-ZS3 Digital Camera
Samsung es30
If the spot is in all foto's and in a video, it is most likely not the lens. Could be a dead pixel (some pixels). But almost certain a spec of dust or othes debris that entered the camera.
Because this camera came with a fixed zoom lens, there is no sensor cleaning option. And I can't find a posibility to make a dust retentie picture.
To check if the spot is on the sensor, put the camera in manual, set aperatur to the greatest figure (smallest opening) an make a picture of a white object. If you see the spot, you were spot on. When the camera is new, this could be a reason, to go to your dealer and ask a new camera. Take the dust retentie picture with you.
Oct 31, 2013 | Cameras
White cloudy spots on my images - a recent problem
If these are like "bubble" spots and they appear in different places on each photo, I'm guessing you're shooting flash pictures indoors. The spots are dust particles in the air reflecting the flash. This happens on small point-and -shoots because the flash is almost in the same plane as the lens.
Nov 10, 2009 | Canon PowerShot SD780 IS / IXUS 100 IS...
LCD screen and pictures go completly white
The camera is defective. But as you've only had the camera three months it still is under warranty. Canon is usually very responsive to these type of problems and will bend over backwards to make things right (probably the most responsive of the camera companies).
Call 1-800-OK-CANON to resolve this issue.
May 25, 2009 | Canon PowerShot SD1100 IS Digital Camera
White line on the middle of the screen
No you cannot solve this yourself unless you have a soldering iron with solder plus be able to identify dry joints or defective capacitors. Please take to a TV service centre.
May 12, 2009 | Televison & Video
White spots on photos
No setting can cause white spots on the picture, this is a fault.
By the way you can reset settings on this camera to initial state by simply removing and putting back camera batteries.
Alternatively you should have a reset command on camera settings menu.
My opinion is that this is a fault and not a settings problem.
Typically there are three kind of faults that can cause this problem:
1 - Dirty lens or water inside the lens:
The lens may be dirty inside, for example because of water condensation on internal surfaces, this will cause blurred dots or black dots. The lens must be taken apart and cleaned in this case.
2 - Defective CCD sensor.
The CCD sensor is the chip that detects the picture, if you get well defined white or colored spots on picture that is probably a defective CCD. I think this is the more likely in your case. To fix this the sensor must be replaced.
3 - Defective video chip on internal board.
This can cause any kind of problems, however it is quite unlikely.
It is an expensive repair.
Feb 09, 2009 | Sony DSC-T70 Digital Camera
Problems with picture
i think that its because you are on spot metering.
take it off spot metering and also make sure that you exposure is on 0.0
i allways use P mode.
my email is seekreep@yahoo.co.uk
Nov 04, 2007 | Canon PowerShot Pro1 Digital Camera
White spots
In addition, flash lighting dust doesn't make a white spot, but a fuzzy whitish circle (out of focus). The image underneath is still visible, but distorted. These are definitely not flash reflecting on dust.
Sep 07, 2005 | Panasonic Lumix DMC-FZ5 Digital Camera
HP Photosmart 315 Digital Camera Logo
88 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
