Question about Toshiba Satellite A135-S2276 Notebook
No wi-fi driver 4 my satellite L30
I can't found wi-fi driver 4 my satellite L30 even in toshiba pages it self...
    Problem Solver:
  • 17 Answers
You can download your new driver information from this link
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_home.jsp
Good luck
~Phil
Posted on Jan 09, 2009
Restore FN + F8 key to reactivate Wi-Fi on Toshiba Satellite L500
My laptop didnt enable the wifi with the fn+f8 key.
I even reset the cmos and nothing.
Then I went to toshiba drivers website and after installing the "thku" "toshiba hotkey utility" the fn+f8 start working and enable/disable the wifi. It now shows a popup windows when I press the fn+f8 key.
Before the wifi led was always off. Windows detected the wifi device but nothing on the wifi available list.
Now the led is always on, starts orange when I turn on the pc and blue when connected.
Oct 05, 2012 | Toshiba Satellite L500 Series Notebook
Tip
Toshiba Bios Password Deletion Satellite P100 & Satellite Pro P100 With...
With notebook turned off;
  • Open Wi-Fi Cover
  • Remove Mini Card Wi-Fi card
  • Locate & Short Out JP8 for 5 Seconds
  • Remove short and turn on
  • NO BOOT
  • Press & Hold Power button to turn off
  • Turn on again & password is cleared
Satellite L10, L20, L30 & Satellite Pro L20
  • Open Wi-Fi Cover
  • Locate & Short Out JP1 for 15 Seconds
  • (Satellite L10)
  • Satellite L20/Pro L20 short out G1
Satellite M100 & Tecra A6
  • Open Memory Cover
  • Remove Memory
  • Remove Black plastic insulation
  • Locate & Short CMOS CLR1 for 15 Seconds
NOTE:
All the following models use the same password removal process.
Satellite: 17xx Series, 1000, 1110,1130, 1200, 1900, 2430, 3000 P20,P30, P33, A30, A70, A80, M40X, M50,M60, M70, M100
Tecra A3/S2, A5, A6
  • The jumper is always located under or near the memory modules
  • Depending on the model the jumper could be labelled J1, J2, J5, J7, J9 or CMOS CLR1 (M100 & A6)
Satellite A100 & Tecra A7
  1. Remove Strip cover
  2. Remove 2 x K/B screws
  3. Move K/B Unit up but don’t disconnect
  4. Release & Remove Mini Card Wi-Fi Card
  5. Locate & short C88 Pin 1 & 2 together
  6. Power on Machine while still shorting Pin 1 & 2
  7. As soon as the TOSHIBA logo appears, remove short
  8. If machine boots, Password has been removed
  9. Satellite A100 (PSAA2A-02C01N)
    1. Remove Memory Cover from base of machine
    2. Release & remove right side Memory Module
    3. Lift black plastic insulation
    4. Locate & short PAD500 Pin 1 & 2 together
    5. Power on machine while still shorting Pin 1 & 2
    6. As soon as the TOSHIBA logo appears, remove short
    7. If machine boots, password has been removed
    TECRA A4 & Satellite M40
    1. Open modem & Wi-Fi card cover
    2. Remove mini PCI Wi-Fi card
    3. Lift up black plastic
    4. Locate & short C738 Pin 1 & 2 together
    TECRA S1
    1. Open palm rest cover
    4. Locate & short C5071 Pin 1 & 2 together
    TE 2300
    1. Remove 2 x B12 screws from bottom of system
    2. Remove strip cover
    3. Remove keyboard screws 1 x B2.5 & 1 x SF4
    4. Remove 1 x 4mm screw & Wi-Fi cover
    5. Remove mini PCI Wi-Fi card if fitted
    6. Locate & short points as shown in picture below
    7. Power on machine while still shorting points
    8. Short for 5 seconds
    9. Nothing will appear on the screen
    10. Turn system off holding down power button
    11. Password is now removed
    Satellite A60
    1. Open Wi-Fi slot cover
    2. Lift up black plastic
    3. Locate & short C561 Pin 1 & 2 together
    4. Power on machine while still shorting Pin 1 & 2
    5. As soon as the TOSHIBA logo appears, remove short
    6. If machine boots, password has been removed
    If you need your Toshiba bios password removed and your model is not listed above then chances are it's a procedure that can only be done at an authorised repair centre.
on Jun 08, 2010 | Computers & Internet
I have a problem witch wi-fi. my wi-fi can'not found internet or som conetction. I need drivers for wi=fi
here is the download link for your Wi-Fi driver
For Windows Vista :
http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_wifi_realtek_28824A.exe
For Windows 7 :
http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_wifi_atheros_TC00190600E.exe
Download and install the driver according to your operating system.
Your Wi-Fi will work fine now.
That's it.
Jan 24, 2010 | Toshiba Satellite L305D-S5881 Notebook
Drivers for Satellite L30 Toshiba
need the drivers for Model Satellite L30 Toshiba.Full Drivers Vedio,Audio Display,DVD
Feb 16, 2009 | Computers & Internet
About toshiba satellite L30-c330
If you don't have the original drivers; check in toshiba.com or download.com.
About the upgrade: check your manual to know with type of memory your laptop needs (yours is DDR2) , after that you can put any size from 512MB an up. Your Laptop can holds only 2 simms, so try to get the max of memory you want.
Nov 18, 2008 | Toshiba Computers & Internet
Toshiba satellite L30 PLS30L-00M00D
Please go to the below link and select the type of operating system you are using and download the drivers. Hopefully it should work.
"http://eu.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/download_drivers_bios.jsp?service=EU"
Thank you..
Sep 10, 2008 | Toshiba Satellite P30 P35 Series Notebook
Sound driver
Hi, I want to install sound driver on my laptptop model: Toshiba satellite L30. Please advise me.
Aug 10, 2008 | Toshiba Satellite L20-S310TD Notebook
Toshiba Satellite A135-S2276 Notebook Logo
212 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
