Question about Nikon COOLPIX L18 Digital Camera
Camera will not turn back on
Just got today a nikon coolpix L18 and all we did is put the batteries in fiddle with it for awhile and shut it off. When we turned it back on about 3 hour later it will not turn on
  • xostace13ox May 17, 2009
    i have used regular batteries previously and now i have the same issue where the camera just wont turn on. does that mean i still have to go to lithium? because im not sure if that would even make a difference considering regular batteries worked fine for the past year or so.
    Champion:
  • 225 Answers
Some cameras require special higher voltage lithium batteries to operate. Try lithium batteries before you assume your camera is broken.
Posted on Jan 09, 2009
How do I change the battery on a Nikon cool pics camera?
This link will take you to the Nikon USA website where you can view a copy of your camera's user manual for free. Page 10 explains and shows you how to replace your batteries. User Manual Coolpix L18 L16 Nikon Knowledgebase
Jun 05, 2014 | Nikon COOLPIX L18 Digital Camera
Power on green light on coolpix L18 is blinking. Why? Camera won't work.
This might not work with all cameras, but try it anyway...
Take out your battery and memory card. Put them back in with the battery being first. Try and charge.
You might still have problems charging with the USB lead to the camera. In such a case, you should buy a proper charger that you can put the battery into and charge it. Sometimes charging through the camera doesn't work.
Dec 12, 2013 | Nikon COOLPIX L18 Digital Camera
My Nikon Coolpix L18 shuts off automatically whilst im recording video. Please help!
Regardless of the size of the memory card, the largest video file you can create on the L18 is 2GB. You can stop recording one clip and then record another and another, and then combine them on a computer to create longer clips.
In a Hollywood movie, you seldom see individual scenes as long as five minutes in length. They're usually put together from much shorter clips, changing viewpoints and camera angles.
Nov 22, 2011 | Nikon COOLPIX L18 Digital Camera
My Nikon Coolpix L18 camera is sayi ng battery exhausted and I just replaced batteries
I have the same camera. I am working out an issue where it shuts off while I'm recording videos. But anyway, my solution for you is relatively simple.
Take a q-tip and dip it in rubbing alcohol. Remove the batteries from the camera, and clean the terminals with the q-tip. This should help remove and prevent the buildup of battery acid.
Put the new bateries back in. If they do not work, replace them with rechargeable batteries. I reccomend rechargeable because they are built better. If you don't want to spend the money on them, look into buying lithium. Duracell sells nice lithium batteries.
I personally reccomend Durracel Lithium batteries from my own personal experience.
Hope I helped!
Nov 02, 2011 | Nikon COOLPIX L18 Digital Camera
Recharging
The L18 takes two AA batteries. If you use rechargeable batteries you will need to recharge them outside the camera. To save weight, space, and cost, the camera does not incorporate any charging circuitry.
May 06, 2010 | Nikon COOLPIX L18 Digital Camera
Lens error message on nikon coolpix L18 I purchased my Nikon L18 Cool Pix camera last September ('08). Last week when I turned it on, the lens extended fully, then retracted fully as I got a "lens error"...
When system control does not get lens initialize signal while extending it, then it try again by folding it and extending and still no required initialize signal then generate error and stop further functions.
Please remove battery and open camera and remove flexible wire of lens mechanism from connector, there would be lock that needs to release to remove flexible wire. Clean wire terminals with alcohol, let it dry and put back flexible wire in connector and lock it. Now put battery and power camera up, hopefully lens will work properly.
Hit "add a comment" button for further query / info.
Thanks.
May 01, 2009 | Nikon COOLPIX L18 Digital Camera
Nikon Coolpix L18 will not turn on. Has fresh batteries.
this is the problem go for repairs Free of charge
http://www.nikonusa.com/Service-And-Support/Service-Advisories/COOLPIX-L16-L18-Service-Advisory.page
pls remember to rate me FIXYA fo rhelp
Apr 13, 2009 | Nikon COOLPIX L18 Digital Camera
Frozen image on nikon coolpix L18
We were in the middle of taking pictures on our Nikon L18 and it was in continuous shot mode and the picture froze on the screen...I called tech support and they wanted me to turn the camera in so it could i fixed..it was a BRAND NEW CAMERA!!!!
yeah so we just took the batteries out and let it reset...see if that works.
Apr 06, 2009 | Nikon COOLPIX L18 Digital Camera
Batteries Exhausted Message on Nikon Coolpix L18
How could I resist assisting someone with the handle 'Charm City'? What I would advise is getting some good quality 2300 mAH or 2500 mAh re-chargeable batteries - although all batteries have a nominal 1.5v output, not all can provide the sustained power necessary for the camera.
Aug 19, 2017 | Nikon COOLPIX L3 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
126 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
