Question about HP PSC 1510 All-In-One InkJet Printer
Where is the black ink cartridge located. How to remove fr refill
Changing Black Ink Cartridge
How do I remove the cartridge for a refill? I have no manual
  • balivalley Jan 11, 2009
    Your advice was very helpful and I am now able to replace the cartridges. Thank you for your help. Rating: Five Star
  • 1,901 Answers
Here is a link to the setup manual.
Go to page 3 and 4 for instructions for installing cartridges. (For removal, just reverse the process.) Make sure the printer is ON when replacing the cartridges.
PSC1510 Setup Guide
I am also giving you a link for the User guide below for reference.
PSC1510 User Guide
Replacement of cartridges is on Page 45 of the guide.
Save these for future use.
Posted on Jan 09, 2009
How to refill the cortrideg hp deskjet f4288.
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
I whant to refill pixma canon ip2700 with black ink but dond now how
Color Cartridge 1. Place the cartridge over somepaper towels in case there are any spills.Remove the label sticker from the topof the color cartridge. 2. Drill into the three small holeson the top of the cartridge to widen them so they will allow syringe needles. 3. Fill a syringe with 6 mL ofmagenta ink. Insert the needle into the refill hole that is located below thetwo protruding rectangles on the top of the cartridge. Slowly inject the ink. 4. Fill a syringe with 6 mL of cyanink. Insert the needle into the refill hole located below the large rectangleon the top of the cartridge. Slowly inject the ink into the cartridge. 5. Fill a syringe with 6 mL of yellowink. Insert the needle into the refill hole located below the small rectangleon the top of the cartridge. Slowly inject the ink into the ink chamber. 6. Replace the cartridge into theMX310 printer. Black Cartridge 1. Set the cartridge on some paper towels. 2. Drill a hole into the dimplelocated directly above the semicircle on the top of the cartridge.Fill asyringe with 20 mL of black ink. Insert the needle into the hole and slowlyinject the ink. 3. Replace the cartridge into theCanon MX310.
Nov 28, 2010 | Canon PIXMA MX310 All-In-One Printer
Changing ink cartridge
  • Here is an instruction set I found at
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer |
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    Replaced ink cartridge still shows ink low needs to be replaced but is printing? Can it be reset?
    1. Remove your current empty cartridge from your Dell printer. Turn on your printer and lift the cover and top half of the unit. You can suspend it in place by lifting the blue plastic lever and securing it to hold up the top of the printer. At this point the ink cartridges should move to the center of the printer and be easy to access. Follow the instructions locate on your printer to remove the cartridges. You can do this by pressing on the blue tab to remove the colored cartridge or the black tab to remove the black cartridge. Once you press the tab, the cartridge cover will pop open. Carefully pull out the exposed cartridge from it’s setting. Save the empty cartridge so it can be refilled.
      Remove the sticker from the newly refilled Dell ink cartridge. Follow the directions on the opened printer to insert the cartridge. Hold the cartridge so the writing is on the top and the ink spot is on the bottom. Gently push it into the opened setting until it is securely in place. Close the cover of the cartridge holder by pressing down on it gently until it clicks into place. Remember that the black cartridge goes into the black setting and the color cartridge goes into the blue setting. Close the top of the printer. You will hear the ink cartridges move back into place.
    2. Test your newly refilled Dell ink cartridge and load your printer with paper.Print a document so either in color or black and white (depending on the type of cartridge you had refilled). Review your printed document to make sure the color is consistent and you are pleased with the outcome.
      Repeat whenever you run out of ink.
    Apr 30, 2010 | Dell V305w All-In-One R840635AU InkJet...
    How do I change the toner?
    The Fax-2480c does not use toner cartridges.
    This is an inkjet and so uses ink cartridges.
    There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
    This machine takes LC-51 cartridges.
    You're probably out of warranty so jsut get refills... it's cheaper
    Mar 25, 2010 | Brother IntelliFax-2480C Fax
    Canon mx700 not recognizing cartridges
    I suspect that your have a damaged refilled cartridge. Also, you may have a clogged nozzle. Canon printers are sensitive to the quality of the ink used in the cartridges and refill ink sometimes does not meet the manufacturer's specifications. You can check this by inserting a new OEM cartridge, running the deep cleaning utillity three times and a aligning the printhead. The other problem may be that the electronic chip on the refilled cartridge may either be damaged or blocked by dried ink. In any case, you need to discard the failing cartridge and replace it.
    Let me know if this solves the problem. Thanks.
    Feb 22, 2010 | Canon MX700 Office All-In-One InkJet...
    I want to refill the ink cartridges (black 30 - colour31) do I do it?
    Filling is easy - but messy. I use No 40 cartridges for my pixma ip2200.
    For the black cartridge, carefully remove the label. Drill a 2-3mm dia. hole in the depression in the top. With a syringe fill, using about 10ml of black ink. Plug the hole with a suitable bung and away you go!
    You will however lose the ink level indication as it is not a genuine cartridge - but that is unreliable anyway.
    Don't refill more than a couple of times as the foam inside the case eventually perishes and all the ink runs out.
    Whilst the cartridge is out of the printer give the jets a wipe with a wet tissue. This is usually quite effective in removing dried on ink.
    You can do the same with 41 colour cartridges but it is a bit more tricky locating the correct place to drill.
    Good luck
    Apr 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
    Swap black inks with Epson 9800
    By using Colorbyte's Imageprint software and their 'Phatte Black' cartridge....
    I have not purchased it myself quite yet but im good friends with an Epson R&D guy who tested their system and highly recommends it.
    Mar 20, 2008 | Epson Stylus Pro 9800 InkJet Printer
    Refilling ink cartridges
    hp74a.jpg HP #74 Cartridge Refill Instructions
    Black cartridge
    1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
    3. Fill the syringe with 20ml. of black ink.
    4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
    5. When finished, replace the top label or leave it off (it will make no difference in the printing).
    6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
    Or print the following pages: for Black
    For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
    A Refill Kit should include Ink plus the following:
    One 30cc Syringe
    Jan 14, 2008 | Office Equipment & Supplies
    Black ink cartidge
    If a black cartridge will not print, with no error messages, it is probably th printhead. Clean it with proper cleaning solution. Refilled ones if done yourself or by someone else, can also have air bubbles, Try blowing down refill hole with tissue under the cartridge to stop ink spills. Also, if you press a folder non scented wipe under the cartridge firmly, you should get a solid little black line or impression. This will tell you if the ink is getting down ok. Try reprinting.
    Oct 13, 2007 | Lexmark X4270 All-In-One InkJet Printer
    HP PSC 1510 All-In-One InkJet Printer Logo
    112 people viewed this question
    Ben Johnson
