Question about GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
Samsung twin door fridge water leaking onto floor
There seems to initially be a build up of ice on the bottom (inside) of the freezer that appears to leak out onto the floor. When we have remove build up of ice the water subsides until the build up starts again and the process repeats (water leaks) can you help please.
Regards Greg
  • 1 more comment
  • greggy24 Jan 09, 2009
    Thanks for your help but this model doesn't have an ice maker. The model number is srs535nw. According to trouble shooting section in samsung manual (ice build up on wall of freezer) it suggests thar the fridge maynot be sealed (closed) completely this does not appear to be the case and the build up is only on the base of the freezer. Hope you can help. Regards Greg
  • bazzox Jan 21, 2009
    I have the same Samsung side by side SRS535NW. I also have the same problem. Water on the floor of the freezer section. It seems to be coming from behind the rear cover. Not 100% sure at this stage.
  • bazzox Jan 23, 2009
    I removed the rear freezer cover and found that the drain hole at the bottom of the evaporator coils was blocked with ice. When this happens the water from the evaporator coils runs across the built up ice and leaks into the freezer compartment under the rear cover.
  • 3 Answers
I have a Samsung side by side - model RS253BAWW.
Water was leaking onto floor from main refrigerator, not freezer. It was determined to be a blocked defrost drain.
The repair technician removed the trays and food from fridge, remove the screws from the panel at back, disconnected everything and remove panel.
The stainless tray at bottom of fridge as well as panel itself had solid ice blockage.
He placed panel in sink and used something similar to a blow dryer with narrow hose on it to defrost both the panel and drain in fridge. Took him maybe 15 minutes and charged $99 total for the visit.
In future I will do this myself now that I know how but thought it may be useful information to others who are having similar problems.
Posted on Sep 08, 2010
  • Jamie Jul 02, 2013
    We had the same problem. Repair man said unplug for 2 days.then plug it back in we waited 3 days. It worked for 2 weeks it is now leaking again. He told me it was not fixable and he would not take my money. He said look on line it's common with these refrigerator . My question did it work for you?
  • Cheri Eir
    Cheri Eir Sep 05, 2013
    we have had ours repaired twice and it is doing it again, very frustrating; going to do it ourselves this time, check out lawsuit against samsung for this reason; we have model R5263BBWP
I have a samsung Refrigerator model No. RS2556sh. The Fridge temperature indicator is blinking at 38 degrees. What is the cause for it? How can stop it?Please answer to my email is
Posted on Jun 10, 2009
I have a samsung Refrigerator model No. RS2556sh. The indicator on the coolslide zone the freezer temperature indicator is blinking. Also the water is leaking from the freezer. How do I stop the leak? What is the cause for it? Please answer to my email " Thanks. Sankaran
Posted on Jun 08, 2009
  • 700 Answers
Oyu need to go to the samsung download site and look up the troubleshooting portion on ice makers, there you'll find the part where oyu can adjust the water inlet for the ice machine and then oyu will have to adjust it to where it fillls the tray to the correct level and that should solve your problem. Good Luck and If you cannot find what you need then give me the model number that you have and I'll get it for you.
Posted on Jan 09, 2009
  • Todd Born
    Todd Born Jan 10, 2009
    water leajka t the base or the frezzer that sound like maybe a blockage in the drain? or either a tweaked door . do the dollar bill test, take a dolllar and put it between the gaasket and the door you ashould feel resistance if not then your gasket is not sealing properly, l'm assumoing that when you melt the unit you ae putting the covering and screws allo back together right?
Water collecting inside fridge, under meat drawer
Yes most responses are the freezer drain even if it is in the bottom freezer. If the drain is blocked water will build up anywhere inside your refrigerator only because it has no place to go during the defrost. Defective door seals can also can make the problem much worse. See Leaking Refrigerators I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | GE Profile 22.2 Cu. Ft. Side-by-Side...
How to access drain hole for maytag model mf12269vem3
please check your ice maker to make sure it is not jammed up water can leak into fridge
Nov 01, 2013 | Freezers
Water accumulates and freezes on bottom of freezer.
Orange glow is defrost heater and that is normal. Crackling sound is heater heating up area around it, normal. Water and ice build up in the bottom is due to a clogged defrost drain.
Sep 01, 2012 | Refrigerators
Kfcs22evms ice under freezer door and water leaks out onto floor
Check for a clogged drain line at he bottom rear.
Oct 30, 2017 | Refrigerators
Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Nov 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
Apr 04, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Water gushed out freezer door, possible solenoid problem?
The drain is clogged. The drain is usually located inside the freezer on the bottom shelf to the rear. Use a meat baster and a solution of 1 tsp. baking soda and 2 cups of hot water-not boiling to unclog the drain. You probably also have about 1/2 inch of ice build-up on the bottom shelf. This will have to be removed first.
Nov 13, 2008 | Kenmore 50522 / 50524 Side by Side...
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Logo
11,363 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
