Question about Kensington PilotBoard 64378 (085896643784) Keyboard
Mouse works, keyboard does not
I hooked up my receiver to the USB port on my laptop and the mouse worked fine and the keyboard worked fine for a minute or so. Now I am getting nothing from the keyboard and the mouse works fine HELP!!!
    Problem Solver:
  • 51 Answers
Try replacing the batteries in the keyboard. This usually solves the issue.
Posted on Aug 18, 2007
SOURCE:
Do i need a keyboard and a receiver for the mouse to work and if not how do i hook it up
Your wireless mouse and Keyboard work with the same wireless transmitter that is plug in into a USB port.of your computer. You can use the wireless mouse with that USB transmitter and dont use the wireless Keyboard. If you need a keyboard you can get one to be plug in into a USB port with the wire attach to the keyboard.
Mar 23, 2012 | Micro Innovations KB982W-F Wireless...
Wireless keyboard and mouse works fine with computer but when I attempt to use it on the f1dh104l switch it does not recognize the mouse or keyboard. it is a dell e6400 laptop that i'm attempting to...
the problem is that most Wireless Keyboard and Mice combos use Composite USB, the KVM however is expecting one signal on each entry port (one for mouse, and one for Keyboard).
replace yoru wireless Combo for a standard Keyboard and Mouse to make this work.
A work around would be using a MS Wireless Mouse and a different brand of Wireless Keyboard using both Wireless receivers and plug them into different ports on the KVM
Jun 05, 2011 | Computers & Internet
I am trying to hook my mouse up to my new laptop but I can't get it to work. Please help.
1.Put in the batteries Find the battery cover and slide it off. Insert the appropriate batteries.
2.Plug in the receiver to the computer. Usually the receiver will plug into the USB port, but some plug into the mouse port. If all of your USB ports are filled, see if the mouse came with a USB adapter. The adapter fits into the mouse port. Be careful not to accidentally force the mouse adapter into the keyboard port.
3.Connect the mouse once you have it plugged in. The receiver should have a visible button that is easily pushable by the average human finger. The mouse will usually have a very small hole with a button inside it that can only be pushed by something like a pencil or paper clip. Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
4.Position the receiver in a place that isn't far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk. The furthest a wireless mouse can get away from the receiver without not working very well is about 9 feet (2.7 meters), so keep that in mind.
5.Test your new mouse.
* If you plugged into the mouse port, restart your computer manually.
* If you plugged it into the USB port you may begin using it.
* When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
This should help you to fix the problem.
Mar 03, 2010 | Logitech Cordless Mouse
Mouse does not work when used under xp. Followed installation guide but mouse appears inoperable. Mouse batteries are good and usb receiver working but no cursor movement with mouse. Attempted several...
I called Dynex customer support and they walked me through the troubleshooting process. It turns out there was a problem or conflict with one of my usb ports. The port recognizes my flash drive and other usb devices but not the mouse. I tried using the other two remaining ports and the mouse was recognized and works just fine.
Feb 16, 2010 | Dynex Wireless Optical Laptop Mouse...
Keyboard and mousepad
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the software program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 01, 2009 | Acer 91.63X07.001 Keyboard
Wireless keyboard won't work but mouse does....
Have you reset the button on the bottom of the keyboard? If you haven't, try doing so and also if it doesn't work, push the receiver button and then the reset button on the bottom of the keyboard. Hope that helps. Bud
Dec 16, 2008 | Computers & Internet
Wireless mouse not picking up
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Feb 25, 2008 | Fellowes Manufacturing 99666...
Ir-700 mouse
Reinstall your CD software program for your mouse because it was wiped out when you went back to factory settings.
Nov 25, 2007 | i-rocks IR-7100 Mouse
Wireless mini mouse
Normal 0 Disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Nov 20, 2007 | Belkin F8E825 USB Mini Wireless Optical...
IBM Optical Mouse doesn't work
Nov 11, 2007 | IBM Optical Travel Mouse 2224P0480
Kensington PilotBoard 64378 (085896643784) Keyboard Logo
158 people viewed this question
Top Kensington Computers & Internet Experts
Alun Cox
robert roberts
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
