Question about HP Photosmart 315 Digital Camera
I try to take a picture for ebay useing the flash but a bright or white spot appears on item or figure after picture is taken.This just recently started.How or what ajustment can be made to correct this problem?
  • Jerry Mayhew
    Jerry Mayhew Jan 11, 2009
    Wihte spot appears on photo.I've cleaned the lens and it did'nt help.
  • Jerry Mayhew
    Your suggestion worked -thanks so much
  • 45 Answers
This white spot appearing on your camera is not due  to the problem of your settings it may be due to the flash light reflecting from some shining surface or there may be some substance inside the lense  of the camera which may be appearing as a white spot inside your camera
Posted on Jan 11, 2009
  • 143 Answers
It's a setting problem yr camera is set in night mode and it has a setting to make a process and also chek variouse setting is has u need to change it and take also clean lance.
Posted on Jan 09, 2009
  • HP Master
  • 13,433 Answers
Attempt to restore the camera to the default settings or change the flast setting, will have to check the manual to provide more details.
  • Ekse Jan 09, 2009
    Just to add, I haven't checked the settings yet, but my own camera does this same thing if I take the picture close from the object and its dark, suggest also try having more light on the room / object so flash is not needed.
I have black spots on my Panasonic Lumix DMC-ZS8 lens camera
If you want to know if these spots are on the sensor. Or you want to exclude this, You could try this:
Put the camera in A priority. (manual mode). Turn the aperture to the highest setting. Greatest figure like f 22 I can't find the exact figure. It could be it is only 8. Then in a bright light, take a picture of a white sheet of paper. The picture that comes out, should be checked on dark spots. If they are there the spots are on the sensor. If you can't find the spots on the white picture, something else is wrong.
Feb 12, 2014 | Panasonic Lumix DMC-ZS3 Digital Camera
For KDF-E42A10 When picture is black, a bluish fadded spot appears in the center of screen. When picture is white, a yellowish fadded spot appears in the center. Do I just replace the bulb?
no this is a problem with your Optical block your LCD chips have gone bad you need to replace this part to fix this issue the bulb will not solve this kind of issue
Oct 15, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
LCD screen and pictures go completly white
The camera is defective. But as you've only had the camera three months it still is under warranty. Canon is usually very responsive to these type of problems and will bend over backwards to make things right (probably the most responsive of the camera companies).
Call 1-800-OK-CANON to resolve this issue.
May 25, 2009 | Canon PowerShot SD1100 IS Digital Camera
White spot on photo
Hi and welcome to FixYa,
Initially, this would be a temperature imbalance on the CCD lens. Often white spot(s) appear at night or when the temperature is cold. Workaround is to open the lens but delay taking a picture after a few seconds. The idea is allow the lens to match the ambient temperature.
Good luck and Thank you for using FixYa.
Jan 09, 2009 | HP Photosmart 315 Digital Camera
Spot on photos from a canon 350d
If you see bright circles or spots on photos taken with flash, and the lens appears to be clean, then this is probably caused by particles (dust, pollen, etc) in the air.
There's also an interesting thread on the CANON DIGITAL PHOTOGRAPHY FORUM at <>
And an explanation of sorts at <>
I really don't know if a slave flash would help, because I assume the A40 flash would still be operating, but if you could borrow one it might be worth a try.
Might be a wild goose chase, but you could try changing some small thing, just in case ...
... like trying a different flash mode - slow synch for example?
... or different picture modes - perhaps snapshot or infinity?
... or changing from AUTO to Program, or from Program to Manual, etc?
Otherwise it's probably a case of waiting for most of the dust to settle, taking more than one photo, or just trying to do without flash whenever possible in that sort of situation ...
Another suggestion I just came across is to use a Negative Ion Generator - used to purify air by precipitating out the particles. Don't know how well it would work - probably not very well if folk keep moving around - and sounds expensive, so maybe not worth buying one - but if dust is a regular problem, and you just happen to know someone that has one ...
poached from
hope this helps
Dec 09, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
How do I use the self timer on my PowerShot A570 IS camera? Please help...
Press the Center Button
By pressing the center button on the four-way controller, you'll open up the Function menu. This menu has the following options:
  • ISO speed (Auto, High ISO Auto, 80, 100, 200, 400, 800, 1600) - see below
  • White balance (Auto, daylight, cloudy, tungsten, fluorescent, fluorescent H, underwater, custom) - see below
  • Drive (Single-shot, continuous, 2 or 10 sec self-timer, custom self-timer)
  • My Colors (Off, vivid, neutral, sepia, black & white, custom color) - see below
  • Flash compensation (-2EV to +2EV in 1/3EV increments) + flash output (1/3, 2/3, full) - this last item is only available in manual mode
  • Metering mode (Evaluative, center-weighted, spot)
  • Compression (see chart later in review)
  • Resolution (see chart later in review)
The Third Option is Having Self Timer ..... Check
Oct 14, 2008 | Canon PowerShot A520 Digital Camera
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Jan 19, 2008 | Pentax Optio E10 Digital Camera
A spot appears in same location on every picture
take the lens out and blow air inside the camera and on the inside part of the lens.
Jan 10, 2008 | Nikon D40x Digital Camera
White spots
In addition, flash lighting dust doesn't make a white spot, but a fuzzy whitish circle (out of focus). The image underneath is still visible, but distorted. These are definitely not flash reflecting on dust.
Sep 07, 2005 | Panasonic Lumix DMC-FZ5 Digital Camera
HP Photosmart 315 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
