Question about Asrock P4i65GV Motherboard
Intel based computer crashed and wont get in windows
My computer crashed reset it self and will not get in to windows gets to blue scren and stops i tryed running memtest 86 and that doesn't get me anywhere how can i test what could of burned out whether it is hard drive memory or what could it be, replaced cpu and still same problem i have two hard drives running like one and it will not let me reinstall windows or format the hardrives
  • niceguy18972 Jan 09, 2009
    no it doesnt start with blue screen it goes threw normal proces of starting up and gets to windows XP screen and just stops
  • niceguy18972 Jan 10, 2009
    well if u read closelly i sad that it doesn't let me reinstall windows or do anything with hard drives formattin, or brake them up
  • 144 Answers
Does it starts with the blue screen and do you have a 3d card and the monitor wire is attached to the 3d cardv socket " it happens with your 3d cards gets burst due to over heating " so now remove the monitor wire from the 3d card socket and attach it to the mother board socket
Posted on Jan 09, 2009
Widi crashes on start, can someone help?
If your system is running a Windows operating system, you should remove the WiFi manager that dell supplies. The Windows one is the most effective and efficient. When you have more that one system trying to do the same job you will always have a chance of conflict. If you are getting a "Blue Screen" when your system crashes then you should remove anything you have fitted since it was working properly. This type of system crash is usually caused by a hardware problem-either physical or driver based. To eliminate the drivers from the equation you should try and run your computer in "Safe Mode". this allows the system to run without external drivers.
Apr 04, 2013 | Dell 14Z-N411Z
The Machine Reboots after displaying Blue Screen With Error Message
Windows is entirely in control of any blue screens; so the hardware spec is not relevant yet.
can you try reading your windows event log immediately after a crash? :::Start>all programs>administrative tools>event viewer
you are looking for an error mentioning a filename... C:\windows\~somepath~\Minidump.dmp
If you get yourself a copy of WinDB (here: http://msdn.microsoft.com/en-us/windows/hardware/gg463009)
You can then open WinDB and open/read that crash dump file (file open crash dump), and it will provide you with a filename of the driver that caused a problem (possibly even tell you what it was doing when it was called).. chances are it's one of the following causing the problem: Graphics Card drivers Storage controller drivers Motherboard drivers (Power Management related issue usually)
If you have the latest driver; then get the hardware checked out...
May 17, 2011 | Intel D865GBF Intel 865G Socket 478 ATX...
System is wont boot
Getting 0x0000008e is surely a signal that your registry is corrupted. What you need to do is to fix 0x0000008e as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don’t fix 0x0000008e, this potential risk will bring you more troubles, Even system crash.
Cause of the problem would be.Mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause 0x0000008e.
Heres how to fix the issue
Download the software fix by clicking here.
Launch it after finishing the installation.
Click “Scan Now” button
Click “Repair Problems” button and fix 0x0000008e.
May 21, 2010 | HP Pavilion dv6000z Notebook
Begining dump of physical memory
Dumping of physical memory means that Windows is about to crash anytime. So, back up all you data on the PC and get ready for a crash and reinstall Windows. OR, you can reinstall right now. Do that, but remember that all other programs that you are using besides Windows, will have to be reinstalled. Windows is just the base. What you construct above it is dependent on your requirements. That includes MS Office and what not. So, take a good back up of My Documents as it will be overwritten.
Nov 03, 2009 | Averatec D1002UHCE-1 All-In-One Intel...
Why my laptop always blue screen after play games
try to reinstall the videocard drivers or your laptop is not recommend for gaming or replace memory card
Aug 16, 2009 | ASUS LGA775 SOCKET FOR INTEL CORE2...
Blue screen crash: something with PTE
use your windows xp OS disc to get to the repair function of windows and run the repair option once prompted. your overheating may be the result of bad adapter or battery back, otherwise cooling sink on motherbord as stopped working
Mar 23, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
I just finished my new build. when i power it up it goes through its boot series and gets to a point were it says media test failure, and under that it says exiting intel boot agent. In the bios, the hard...
I doubt it is a virus as you have not indicated doing anything that a virus could have been transmitted to your system. The blue screen of death at boot up time simply means the files that find your operating system are not working properly. Specifically, if you want to Google them they are NTLDR (NT Boot Loader), Boot.ini (tells the system the name and location of your system) NTDETECT.COM (inventories your hardware) and HAL.DLL also monitors hardware. If you could get those three files on a disk-NTLDR, Boot.ini and NTDETECT.COM, then it would boot. They are located in the C:\ drive of any computer with windows but you have to release the hidden files button first...best thing to do is go to the Microsoft Knowledge Base at support.microsoft.com and research your error and those files..you're not the only one this has happened to so there may be a fix in the knowledge base. Besides its good practice to use the Knowledge Base as you can find out about any answer on windows there..good luck. Please rate this solutionl.
Mar 19, 2009 | Computers & Internet
Dell computer blue screen saying STOP
Try installing the operating system or repairing the operating system.
Feb 22, 2009 | Dell Computers & Internet
Blue tooth headset problems with vista
all vista software goes of the market on the 11th april 2017 and it wont be avaible to restall it any more as microsoft wont allow this to happen ,,,,,,,,,sorry as i have vista and i will loose so much of my computer too on that day
Apr 01, 2017 | Radio Communications
Vista goes blue and restart after unnistalling intel turbo memory
I'm afraid that the only way is to reinstal Vista. If you recive a message that says that Vista arent capeble to repait it self ther is no other way. I Guess that the instalation of the driver for Intel Turbo Memory messed up Vista pretty good and uninstal it dosent help. You will always have bad file system on Vista. Better then to star from the begining with a fresh reinstal.
Good luck
Nov 21, 2008 | Computers & Internet
Asrock P4i65GV Motherboard Logo
52 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
