Question about Sanyo CLT2054 20 in. EDTV-Ready LCD Television
Sanyo television is stuck on Video 1 mode and cannot get it off; unable to locate television remote. Have read 4 hours for hard reset, but is there a way to perform a soft reset to simply return it to normal television mode? Also, have read 4 hours, half an hour, and also 1 hour for hard reset... which is it?
    Sniper:
  • 62 Answers
I would go for the 4 hours because it will the give television to longest time to recover from whatever issue it is having. In fact, just to be sure, leave it overnight. This will insure that a full reset will take place.
Posted on Jan 09, 2009
My tv is stuck on the video imput for my Wii and none of the front panel buttons work
Try to see if any of these four methods will work.
Sanyo TVs
1. Press VIDEO MODE or TV/VIDEO button in front panel or on remote
2. Press MENU , choose FEATURE SETUP, then choose either VIDEO MODE or TV/AV, select VIDEO or AV
3. Press TV/AV or INPUT SELECT on remote
4. Press SETUP, choose TV/AV, switch to AV
Sep 25, 2011 | Panasonic TH-42PX60U Television
I cant setup my sanyo still on factory mode
Factory mode? sounds wrong!
you might be stuck on "demo" mode! that's not a "factory"! someone pushed "demo" on remote control or at the set. there are few things to get this out: 1. locate "demo" button on remote control, 2. look for the same at the tv's touch pads. 3. have to push combination of buttons on remote or the set, Reffer to owners manual.
good luck.
Apr 04, 2010 | Sanyo Televison & Video
My tv is stuck on the blue screen .
Go push menu button on the front of tv or the right side.Pick the video out,or tv.Or buy a remote.Website 1-800-Remotes factory Original.For the original remote.
Dec 18, 2009 | Sanyo DS27510 27" TV
No remote
just buy universal remote. or disconect the tv
for 10 minutes and then pluging back
Aug 14, 2009 | Sanyo DS13204 TV
Sanyo DS31520 TV
I am relentless when it comes to problems like this. I had the same problem with my TV being stuck in video mode. I found out that there is a reset button......It's on the @*&#^&^ original remote!!!!! So I tried programming my Time Warner Scientific Atlanta AT8550 remote for the TV to see if the "video source" button would work. IT WORKED!!!! You have to use code 1062. Instructions are:
1. Turn the TV on.
2. Press and hold select and the TV keys until the lights blink twice.
3. Enter 1062. All mode keys blink twice to indicate that the code was accepted.
4. Point the remote at the TV and press power to test the TV.
5. You can then successfully use the "Video Source" button on the bottom left of the remote to change the video mode. VOILA!!!
If you don't have a Scientific Atlanta AT8550 remote, I'm sure you know someone that does. They're everywhere!
Feb 10, 2008 | Sanyo DS31520 31" TV
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
ok i have a sanyo tv that was set to imput my remote messed up but now it is fixed i cant figure out how to get it off. in order for me to reprogram my Universal remote i have it has to scan channles right wut do i do??? plzzz help me!
Dec 30, 2007 | Sanyo AVM-3259S TV
TV (Model DS27510) is stuck on Video2 setting, unable to change!!
Ours is doing the same thing except on Video 1. I called Sanyo customer service and they said I need the original remote. They were willing to sell me one for $20. Here is what I did instead. I used a cable box and hooked the cable in to it. Then I took the type of cables that will hook into my video 1 slot and plugged them in there and plugged them into the back of the cable box in the "cable out" positions. It worked ! If you do not have a cable box you might try a DVD/VCR combo or a VCR. Good Luck
Sep 16, 2007 | Sanyo DS27510 27" TV
Sanyo CLT2054 20 in. EDTV-Ready LCD Television Logo
122 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
