The duplex function on my canon dr-2580c is not working. I put the setting on duplex but it still does not scan both sides.
  • 565 Answers
If my caht helped rate fixya - use the Acrobat
Posted on Jan 09, 2009
  • Teet Bergmann Jan 09, 2009
    not here rate the chat fixya
    Scholar:
  • 143 Answers
U need to set setting in propaties thru pc also chek pritner setting...both are mach is must
Color duplex doesn't work
The Canon DR-3080C is only color on the front side. The back side is monochrome only. The next model, which was the DR-3080CII will do double sided color scanning
Sep 13, 2012 | Canon DR 3080C Path-Through Scanner
Canon DR-2580C scanner only scanning half the page. What could be the problem?
Select Auto for page size. The scanning software displays scanned image in many options, including 'fit'. Choose 'fit' so that you see complete image.
S. Mohan
Dec 29, 2011 | Canon DR-2580C Path-Through Scanner
Scanner only scans top page although set on duplex setting.
Switch the little button on top of the scanner next to the 3 buttons. This switches between 1 page or multiple page.
A.Misset
Installing these devices in the Netherlands.
Feb 05, 2010 | Canon DR-2580C Path-Through Scanner
Canon Dr2050C Duplex scanning reverse page all black
Check your brightness setting for backside. Ideally keep it automatic, else you can manually choose the right brightness.
S. Mohan
Sep 18, 2009 | Canon DR-2050C Path-Through Scanner
Scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
Jun 12, 2009 | Canon DR-2580C Path-Through Scanner
I have a new DR-5010C scanner. I used to use the
I havent used Canon 2580C and hence cant comment on Scan Panel. But you can download SU5000 or Captureperfect 2.0 from Canon website (http://software.canon-europe.com/). This is easy to use and probably offers more features as compared to ScanPanel. Canon 5010C is a higher model as compared to 2589C and Captureperfect may offer better user interface.
S. Mohan. Chennai, India
Mar 19, 2009 | Canon DR-5010C Scanner
Canon DR 2580C Scanning issue
In Captureperfect, select page size as 'Scanners Maximum'. Select automatic paper size, check the output now. If you select bigger paper size and smaller paper, you will see lack output, outside the paper area.
S. Mohan, Chennai, India
Nov 26, 2008 | Canon DR-2580C Path-Through Scanner
Canon Dr-2580C
Try and scan a white paper. If the output is black, then may be the LEDs are not glowing, likely the wire is loose. Actually it is not easily reacheable! Try duplex scanning to check if both scan modules are fine.
S. Mohan
Oct 14, 2008 | Canon DR-2580C Path-Through Scanner
Error message -4431
If the scanners keeps blinking while powering on, it is because it has not been intialised. Check for loose shreds of paper in the paper path. Unless the scanner intialises, it cannot scan. If simpel 'countonly' option works, then the scanner is okay.
Sep 04, 2008 | Canon DR-2580C Path-Through Scanner
69 people viewed this question
jasbo
jasbo
