Question about Tag Heuer Aquaracer CAF2112.BA0809 Wrist Watch
I am unable to return to the 0 crown Position - TAG-CAF2112
After setting time and date, I am unable to return to the 0 crown position on My aquaracer CAF 2112 Automatic, 300 Mts - Pls help
  • Arturs Kalnins
    Arturs Kalnins May 11, 2010
    Be more specific, please. What exactly you can not do? Crowns does not have 0 position. May be it is seconds hand? Explain, please.
    Problem Solver:
  • 13 Answers
The aquaracer has a 'screw-down' crown.  This means that the crown needs to be screwed in the reset it back to the 0 position.
Posted on Jan 20, 2009
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    How to reset the chrono function of a Tag Heuer Aquaracer Calibre S CAF7113.FT8010 after a battery change
    Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions. Hope this works..
    Jan 17, 2014 | Tag Heuer Aquaracer Calibre S...
    How do I wind up my tag carrera automatic using the crown??
    Wow, how wrong yall are.
    There are three positions for the Carrera's push-down crown. The inner position is used for normal wear and winding. To wind the crown manually, simply rotate it clockwise.
    Changing the date on the Carrera is done from the middle crown position. Turn the crown clockwise to advance the date, one day at a time. Push the crown back to the inner position when finished.
    The outer crown position is used for setting the time. You can turn the crown in this position either clockwise or counter-clockwise. Adjust the time forward or backwards. Setting the time backwards will not damage the watch. When the time is correct, press the crown all the way into the inner position.
    Feb 24, 2011 | Tag Heuer Automatic Chronograph Series...
    How can i make the date of my tag heuer formula 1 change automaticaly?
    To s e t t h e t i m e a n d d a t e
    Your TAG Heuer chronograph is fitted
    with a screw-in crown and safety seals
    which guarantee it to be waterproof
    to 200 m (660 ft).
    Position 0: Crown is screwed in
    (normal position).
    Important: The crown must be
    screwed in correctly to guarantee
    the water-resistance of the watch.
    Position 1: Crown unscrewed.
    To change the hour (change of time
    zone) or date quickly, unscrew the
    crown, pull it out to position 2 (quick
    corrector) and turn it in either
    direction. This mode allows you to
    change the hour and the date without
    any loss of minutes.
    The date changes each time the
    hour-hand passes midnight.
    To set the time, unscrew the crown,
    pull it out to position 3 (setting the
    time) and turn it in either direction.
    After setting the date or the
    time, push the crown back and
    screw in to position 0.
    Oct 10, 2009 | Tag Heuer Formula One
    Date change on my Tag Aquaracer Calibre S
    Do as follows:1) At any time of the day pull the crown out and advance watch hands forward for EXACTLY 12 hours ( for example: if it's 6.35 on your watch, then after advancing hands it will be 6.35 again, just minute hand will be forwarded clockwise 12 full circles, while hour hand will be forwarded 1 full circle). Push the crown back in.
    2) Pull the crown out to the date setting position and change to the desired date. Pull the crown back in.
    Now your watch will be changing dates at midnight continuosly.
    Rate me, please.
    Apr 06, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
    I own a tag heuer Automatic aquaracer watch and I noticed that when I set the hour, I pull it to position 3 and to move the time (forward) I have to turn the crown counterclockwise. Is this correct?
    Yes it is correct as your watch has a counterclockwise crown forward setting direction. This is due to the specificaly layered lever and setting gear construction, so, nothing wrong with your watch.
    Do not forget to rate, please.
    Jan 26, 2009 | Tag Heuer AquaracerWAF1110.BA0800 watch
    When truning crown to change date, the date stops moving
    there is 2 settings when you pull out the crown very delicate clicks first is for the date i think. if this helps please rate joe
    Nov 16, 2008 | Tag Heuer Watches
    How to adjust the date in tagheuer watch
    Some TAG models have a date "quick set". Pull crown out just a wee bit to position #1. Turn counter clockwise to advance date. Pulling out the crown to position #2 stops the watch and sets the time.
    Dec 05, 2007 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
    Reset Stopwatch Hands on CL1111 ?
    Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
    Oct 18, 2007 | Tag Heuer Aquaracer Quartz Chronograph...
    Tag Heuer Aquaracer CAF2112.BA0809 Wrist Watch Logo
    812 people viewed this question
    Top Tag Heuer Watches Experts
    Jimmy Accardi
    Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
