Need Manual for Hitachi 42PD9800TA 42-inch TV
Need a free online manual for the Hitachi 42PD9800TA 42-inch Picture Master HD II Plasma TV and remote control?
  • 1 more comment
  • ruthgalos Jan 19, 2009
    Am looking for an instruction manual in 'English' for the Hitachi 42PD9800TA 42-inch Picture Master HD II Plasma TV and remote control
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Download reqyuired user manual from HERE
    OK..
    If you are looking for Instruction Manual, click HERE to download it.
    And if you are looking for Service Manual, its available HERE with little fee.
SOURCE: dell tv
My Dell LCD TV/Monitor (20-21") also responded to the 0054 code in the Comcast remote
Posted on Mar 18, 2008
SOURCE: Akai tv remotes
I purchased a HARMONY remote ( logitech ) and it worked for the AKAI PDP4273M .
Posted on Mar 16, 2009
  • 44 Answers
SOURCE: gateway 42 inch plasma p42m303 6 blinks on power supply
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
  • 304 Answers
SOURCE: pink vertical line down my 42 inch digital plasma
I do believe the Panel is bad and needs to be replaced. Check with the manfacture to confirm this.
Posted on Jul 16, 2009
micromend
  • 748 Answers
SOURCE: I have a Sylvania 42 inch Plasma HD TV. It is 3
Hello
Before taking this to a local repair person, I suggest you check with your cable provider. See if they are having trouble with their HD transmission and then have them test your lines. Out here in Arizona with have constant problems with HD due to heat, rodents and poor installations. Your DVR only recorded the problems that were on your set. If these prove fruitless then take the TV to a reputable repair person.
Good Luck
Posted on Sep 24, 2009
Ps3 won't play on my 42hds69.
plug in hd lead from ps3 to tv/now go to tv menu were you will see a choice of hd/scart/dv etc go to each till you find picture/or on remote av button/remember hd is not like a scart it does not switch ur tv to picture
Dec 26, 2009 | Hitachi 42HDS69 42 in. Plasma Television
I have a 2006 Hitachi Ultravision 42 inch plasma
plasma tv units use a lot of power ,well into the hundreds of watts 9 some big screens use up to 800 watts to work)
I suggest that you consider a new led unit which uses barely any power and you will get a remote with it
Jun 24, 2017 | Hitachi UltraVision 42HDS52 42 in....
42edt41a hitachi plasma tv went dark sound ok
sounds like your y and z drive boards over heated and need replacing...
May 31, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black side bars on hd channels
You may have to refer to the instruction manual for details.
There should be in the menu set-up an option to set the aspect ratio for the different broadcast modes. Normaly, when viewing a 4:3 picture on an HD 16:9 set, the sides will be cut off, otherwise the picture will be stretched or compensated.
Jerry G.
Apr 11, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Model 42edt41 has 2 inch vertical line in middle of screen. was only on coax now on all inputs.
42EDT41
Symptom: Vert Bar in picture just off center,
Cause: Defective Control pwb (LVDS) TS05678.
If you need the service manual contact me at billyjones@fletchersite.com
Mar 08, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Plasma TV picture adjustment
Use your remote to reconfigure the picture. There may be a picture button on the remote that will switch the picture from 4:3, 16:9, Standard, Stretch, and so forth.
Dec 26, 2007 | Hitachi 42PD7800 42 in. HD-Ready Plasma...
Connection for tv cable to hitachi 42" plasma Tv
there is no cable slot. the monitor is not a receiver. it has no tuner in it. it will need a signal from a tuner box. and that must be fed to the tv with an hdmi cable or a dvid cable for hd to work. see your manual for further information on cables. see your cable supplier for information on hd boxes available in your area. if you do not buy hd service, you will not get an hd signal. so you will see little difference from a non hd device. your dvd player may have hd capabilities, but will also need the same cable to deliver true hd signal.
the good news is that its fixable by using the right equipment.
good luck
mark
Dec 07, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
ESA EDTV - 42 inch plasma TV, sound OK no picture.. has vertical lines.
pull plug. allow to reset. try again.
good luck on that, otherwise you need service.
good luck
mark
Nov 28, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Televison & Video Logo
372 people viewed this question
Top Televison & Video Experts
