Question about Kenmore Elite 45986 Front Load Washer
Controls are flashing but nothing happens when you press start
My washing machine control panel flashes but when I press start nothing happens. Is there a way to canel all programs? I have unplugged it for 24 hours and nothing happens.
Belt came off! It has happened to me severeral times, however; my father usually puts it back on. Take the screws off above the drawer if you have a pedistal one. Check and see if the tiny little belt is off. Happend to me 3 times in the last 2 years
Posted on Aug 18, 2007
I recently ran into this problem - searching for an answer lead me to your post. I chose the easy route and called Sears. In my case, the door sensor was broken. On the body of the machine itself, in the upper right area, there should be a small 'post' the depresses when the door is closed. That 'post' is prone to breaking, I'm told, and if it is broken off, the washer quits working. Since I had Sears do the work, I do not know the part number for the sensor. I did, however, watch the tech replace it. A very simple 5 minute procedure. ? First, remove the three screws holding the module in place ? Second, there is a wire retaining ring that surrounds the rubber door seal. Look towards the bottom of the seal, and find one end of the retaining ring. Carefully insert a common head screwdriver between the seal and the machine body - again - CAREFULLY (you don't want to scratch your paint, do you?) and gently pry the seal/retaining ring assembly towards you until you can remove the ring by hand. ? Third, gently fold the right hand half of the door seal backwards into the washer, out of your way and exposing the sensor assembly. ? Remove the door sensor assembly from the machine body, and unplug the connections. ? Plug in the new door sensor, then follow the above directions in reverse order to put your machine back together. One last word of caution - the tech told me that the retaining ring has a "spring that can remove your hide" so please be very careful when removing and installing it. When the tech was reinstalling it around my door seal, it seemed to be a bit awkward with just one set of hands. One extra finger to hold the top portion in place while the rest of the ring was stretched around the seal made it go much quicker. Again, this is what fixed my washer. Hopefully it will fix yours, and if not, at least help someone else searching for answers.
Posted on Aug 17, 2007
Why won't my washer start a cycle? Start button LED just flashes. All other lights are steady. Door lock sounds like it engaged, but nothing happens.
There should be a way to enter the washing machine into service mode to view an error code. Check your user manual and then you should have your answer!
Jul 23, 2014 | Washing Machines
No sign of life to our 5 year old D/W except flashing "CLEAN" L.E.D.
7-1 heating circuit problem control programmed to shut down machine when no rise in water temp during heat cycle, you either have an open heating element or wire burnt a shorted thermistor or a bad control not outputing 120VAC to the heater you can reset the control by placing the machine into diagnostic hit cancel button to turn off all the lights press heated dry-normal, heated dry- normal within 6 seconds lights should come on press cancel unit should start it will run till same part of cycle reached and lock out again if it has not been removed the little black panel below the door remove should have the tech sheet in a plastic pouch which explains how to check the components mentioned earlier,
Apr 03, 2014 | Whirlpool GU2800XTV Dishwasher
Washing machine humming but nothing else :(
if you watch carefully, the end light flashes and then stops, and then flashes again... how many times flashes?
Dec 22, 2013 | Zanussi FS1455W Front Load Washer
The green start light is flashing and won't start again when pressed.
Cycle thru the wash settings. Do all the lights work for the different settings?
Nov 25, 2012 | Washing Machines
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Dec 07, 2009 | Bosch Washing Machines
Power light is on but nothing happens - indesit iwme12
If the door does not lock at this point it probably needs door lock replacing
Sep 05, 2009 | Washing Machines
Turn on ok. Press start and spin light blinking and beeping.
Several problems were found
1. the touch panel PCB board had tracks which were damaged by moisture and had it repaired for $50 (Aus); this affected the advance function on the washing machine.
2. Controller motor was replaced with a rebuilt one (since the touch panel kept on shutting down).
3. Make sure that the wire holding the harness reed switch is tight (this I think controls the level in the washing machine).
Apr 13, 2009 | Fisher Washing Machines
Maytag neptune
i have maytag neptune wash,modelo mah5500bww,my problem is: no starting,flashing start/pause button,after ten minutes is off.And now is ready for start when press start/pause button
May 20, 2008 | Maytag Neptune Washer
Pre wash not happening
poss blocked filter which also controls your pressure system, on your machine I believe if the prewash ligbt is flashing it would indicate a blockage there
Jun 13, 2007 | Hotpoint WMA46 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
