Question about Marantz SR-4200 Receiver
Unit goes into protect mode
At first the unit (secondhand) worked fine, but the next day, it went into protect mode after about 10 seconds. I unplugged everything and it still does it. Is there aanything I can do at home to diagnose? Thanks! Steve
  • Steve Wong Jun 05, 2007
    Swongman update:
    In the true spirit of DIY, I took off the cover and vacumed out the inside parts, replaced the cover and reset the unit by holding down the F/P button as described in the manual.
    So far so good! No protect mode so far.
    Just need to keep my fingers crossed!
    Steve
    President:
  • 3,130 Answers
Not unless you know how to troubleshoot solid state electronics. If you disconnected the speakers and the unit still goes into the protect mode, most likely you have a short in one of the power output stages. Good Luck
Posted on Jun 04, 2007
Getting out of protect mode I have a Denon 787 receiver. It was working fine for 8 months. All of sudden, my reciever goes into protect mode after playing for about 30 min. Right after it goes into protect...
most of the receivers come with a cooling fan inside see if its working they usually work when you turn the volume up,, if its working that means you are playing it to loud if you lower the volume a little it will play just fine..( if the fan inside is not working thats the reason it goes into protect mode and it means you must have it repaired,, it goes into protect mode to prevent furter damage to the unit or the speakers,,
Dec 18, 2009 | Denon AVR-787
Sylvania 6842THG won't turn on. the tv red light displays when you push the power button you hear a click and then 5 - 10 seconds it goes back off
I have been having the same issue. I unplug the TV for 10 minutes and it usually works fine. I moves all of my A/V plugs to a single power strip and that helped a lot. Since then, the TV went into protection mode only once in 2 weeks. Next, I will use a power strip that includes the cable protection.
Dec 12, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Roady 2 signal goes in and out....
We've been having the same problem with our Roady XT unit at the office. Sometimes I think it's possessed because it goes in and out, changes to the mute mode, and sometimes turns itself off. Just got another Roady XT unit today. It played fine, then went into the mute mode. Called XM and they told me to reset unit to factory default. It's fine at the moment.
Jun 01, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
Protection mode
The protect mode with nothing connected indicates that the output transistors for one or more channels are shorted. These will need to be checked and replaced. This is a simple repair for an experienced audio shop, Figure about $10 for each output transistor and add in another $10-$15 for misc parts that may also be smoked.
Dan
Mar 18, 2009 | Denon AVR-3600
JVC HX-C6 goes directly into "Protect Mode".
I received a reply promptly from JVC to check power connections for shorts. O course I had already done that. So as a last resort, I pushed the power switch on and held it for maybe 10 seconds. It seems to have reset the unit, and it's playing fine. Best of luck, hope you all read this and it works for y'all. AJ
Sep 26, 2008 | JVC HX-C6 Shelf System
STR-DE445 Works, but goes into protect when you turn up/down volume
This is a piece of **** unit. Mine only works on the left side, sometimes. When those times are I have NO idea. It doesn't seem to play 5.1 correctly and it goes into speaker protect mode for NO reason. It is TRUE lemon !!! ..let me know if you have any other problems with this JUNK .....schafe1001@aol.com
Aug 28, 2008 | Sony STR-DE445 Receiver
Protect Mode on Kenwood KDC-MP335
this is very simple to do just take your face plate off and were you see a red light blinking just get like a bobby pin or something and pit it through the hole and the radio will reset and that should fix your problem
Jun 23, 2008 | Kenwood KDC-MP205 CD Player
Stuck on standby
Unit is in protect mode there are a few problems that can trigger protect mode the most common is blown channel (shorted outputs). Sometimes one of the 15v regulators may go bad causing imbalance of supplys triggering protect mode. Also sometimes a bad solder connection could cause unit to go into protect also. I work for Denon authorzied repair center in Michigan if your nearby and Shipping to Michigan is economical let me know kstahl65@att.net
Feb 13, 2008 | Denon AVR-1804 Receiver
AUDIOBAUN A8002T Car Audio
add doide from the battery to the unit, 2 doide should help that.
1 connected to the positive, an 1 connected to the negative. 5-10 amperes is ok. check for the polarity. and try to take off the ground of the unit then try it.
Jan 15, 2008 | AudioBahn A8002T Car Audio Amplifier
Sony Trinitron KV-28WS3U Dies
B+ over current protection (OCP), unit goes to the standby mode. Could be a short in the power supply of any of the circuits.
Nov 05, 2006 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Marantz SR-4200 Receiver Logo
824 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
