Question about H.D. Hudson 2g Yard N Garden Sprayer
Hd hudson Garden Spray Suprema Model 712201
This is a 20 litre back pack job, but the trouble I am having is when the liquid goes down halfway, or below the actual pump, pressure seems to drop and only a dribble of air comes out. Have I lost something? I am wondering how the liquid is supposed to jump up to the pump section.
Anyone got one of therse darn things?
3 Suggested Answers
SOURCE: immediate pressure loss
your dip tube inside the tank has come loose or has a leak near the top. instead of fluid being pushed up the dip tube into the wand hose the air in the tank is just escaping. You will have to remove the wand hose and figure out where the leak is and fix the dip tube.
Posted on Apr 20, 2009
  • 332 Answers
SOURCE: I have the hudson eliminator sprayer and squeeze
IF your sprayer is full you should be good to go after 20 or so full stroke pumps
If it is not spraying unscrew the adjustable tip and clean out the little holes around the end
If you leave spray in the unit after using it it will get crudded up and plug up
Posted on Mar 08, 2010
SOURCE: Need help with Hudson Trombone Tree and Shrub Sprayer Model 61224
There's a parts illustration on the Hudson web site that may be helpful to put the sprayer back together correctly. Here's the link: http://www.hdhudson.com/PDF_files/10.pdf
Posted on Mar 29, 2010
Looking for hudson sprayer repair kits
you will need to contact them from here
http://www.hdhudson.com/contact-us
they will direct you to the closest reseller of their kits or they can ship one to you.
Dec 29, 2012 | H.D. Hudson 2g Yard N Garden Sprayer
Why does Pump not build pressure
probably bad seals or ring or the relief valve is stuck open
Aug 29, 2012 | H.D. Hudson Hudson Pumpless Sprayer 2...
Sprayer drips instead of spraying
Pressure test: pump it several times then open the cylinder (like you were going to pour in more solution): was there a noticeable pressure release? If not, then your problem is in the pump assembly. Examine the end (the end which goes into the tank) flapper valve. While the pump is out of the tank, pump it a few times. Do you see/hear the flapper move with inflowing air? If not, herein lies your problem. Put a few drops of oil down the assembly where the pump slides up/down. Work the pump a few times. If this does not solve the problem, try to dissamble the pump mechanism and MAYBE you will be able to replace faulty intern parts/gasket. If you DO have internal pressure in the tank, yet no spraying action: disassemble all parts coming after the pump. Hose, off/on switch/lever, spray tip. Yes, it will completely disassemble. Inspect/clean everything/blow out the spray tip or use a thin needle to clean the tip. While you have everything apart, use "silicon plumbers' grease" and generously lube all of the o-rings: this will afford a very good seal and prevent pressure loss. You can buy the plumbers' grease at the big box stores or plumbing supply places. Good luck.
Feb 12, 2011 | H.D. Hudson 2g Yard N Garden Sprayer
Pump is presurized but no spray
Most weed killers and fertilisers either crystalise or turn to gel when left unused. Pull sprayer wand to pieces and run hot water through the hose and wand, they especially clog up at the spray tip and at the on'off control.
May 14, 2010 | H.D. Hudson 1 Gal Poly Deck Sprayer
I have the hudson eliminator sprayer and squeeze the trigger I just get one burst of spray and then a couple of drips. I do have it pumped up all the way. What is the problem?
Mar 08, 2010 | H.D. Hudson Hudson, H D Mfg Co 1 - 1/2gal...
The pump has pressure applied, but no spry comes out.
These sprayers get rust in spray handle, they taking apart and lubing sprayer. If you leave chemicals in tank you will ruin the spray handle.
Jun 20, 2009 | H.D. Hudson 1 Gal Poly Deck Sprayer
From jdwillia on hudson sprayer
I poured hot water in the top and let it soak for ten minutes. Removed pressure valve and it broke free.
Jun 16, 2009 | H.D. Hudson 2g Yard N Garden Sprayer
I have a hudson classic sprayer and have no instructions.
The pumping mechanism should unscrew from the plastic bottle. Push the handle all the way down and try to unscrew the pump while holding the bottle steady.
Jun 16, 2009 | H.D. Hudson Hudson Trombone Sprayer - 140...
Immediate pressure loss
Nov 18, 2008 | H.D. Hudson 2g Yard N Garden Sprayer
H.D. Hudson 2g Yard N Garden Sprayer Logo
123 people viewed this question
Top H.D. Hudson Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
Are you a H.D. Hudson Garden Expert? Answer questions, earn points and help others
