Question about Compaq Presario Notebook
How can i install windows xp on compaq presario cq60-104tu
I have purchased compaq presario cq60-104tu and now i want to install windows xp professional sp2 in it but i am not able to install. can any body help me out from this problem....... my email adderss is : ratherzahoor@gmail.com, ratherzahoor@hotmail.com
  • ratherzahoor Jan 19, 2009
    I have received ur solution and have down loaded sata driver but still it is not working it is giving me error again and i am not able to install windows xp. Please specify me the driver and the site where from i can install the same
    Thanks for trying to help me by solving my problem but it is not working in my laptop
  • Compaq Master
  • 508 Answers
Windows XP does not provide drivers for all the SATA controllers, therefore, during the installation procedure, the user must insert a floppy with the drivers that came in the package along with the motherboard.
Not a big deal, not much effort, but the funny thing is that a great number of people passed on their floppy drives. Under these circumstances, no floppy means the impossibility to install Windows XP on SATA (on some mainboards). The result? The installation guide simply won't detect the SATA HDD.
Let's take it slow. Where is the problem? We have a driver problem strictly because the SATA driver we need does not come embedded in the Windows XP installation package. What if we add the driver by ourselves before installing Windows?
What ingredients are involved in this operation? The original Windows XP Installation CD, a freeware application named NLite and a blank CD. Moreover, we need the drivers for the SATA controller provided by the manufacturer. In case you did not find any floppy inside the motherboard package or you cannot locate them on the mainboard window.google_render_ad(); installation CD, you can consult the manufacturer's website to download the latest versions. To do the trick I have been talking about, it is assumed that you already have a Windows installed on an IDE drive. In case you don't, pay a visit to a friend and ask him to let you use his computer. It won't take too much time, I guarantee.
So, download the drivers and unzip them (in case they come archived) in a desired location. Then download and install the Nlite application. When you start the Nlite application, you will be asked to provide the location for the Windows installation package. Insert the genuine Windows Installation CD into the CD drive and, inside the application, select the CD drive letter.
To insert the SATA drivers within the installation package, you need to have it saved on the HDD. Hence, when the warning window appears click OK and select the destination folder for the files to be saved. Make sure that the destination partition / HDD has enough space to store the contents of the installation CD.
I tested a Windows XP Home Edition and it seems that it required about 566 MB. Immediately after you have chosen the destination folder, the application will start copying the Windows installation files. When finished, it will display some version information regarding the newly copied Windows Installation Package.
Now, click next twice until you get to a screen where you get options sorted in 4 categories: Integrate, Remove, Setup, Create. We are interested in the integration procedure, therefore select the Drivers button and click next. From the next menu window, click Insert and select multiple drive folder option from the drop down menu. This option permits you to browse to the location where the downloaded drivers are found.
Select the containing directory and click next. You will get a list with the available drivers (in case there are more than one) or simply one driver. Select it (them) and click next. Now the application will ask for the permission to start the integration procedure. Choose Yes and wait for the drivers to be inserted into the installation package.
how can i install windows xp on compaq presario cq - satawin_001-small.png satawin_002-small.png satawin_003-small.png satawin_005-small.png
satawin_006-small.phow can i install windows xp on compaq presario cq - satawin_008-small.pnga>
<a rel='nofollow' href=satawin_007-small.png satawin_008-small.png satawin_009-small.png
With problematic driver being included in the installation package you can install Windows XP on your SATA HDD...but...the installation package is on the HDD. You need a bootable CD in order to start an installation. Don't worry, once the installation package has been adorned with additional user selected drivers it can be transformed into a bootable disk image and later burned on a CD. To encapsulate the installation into a ISO image use the same Nlite application.
Open it, make sure the HDD installation folder is selected and click next. Select "Last session" preset and click next again. Now from the options menu choose Bootable ISO and click nexthow can i install windows xp on compaq presario cq - satawin_010-small.pngndow, make sure that the mode is set to "Create Image" and click Make ISO. A destination folder is required where the reshow can i install windows xp on compaq presario cq - satawin_011-small.png be saved. Once the image saving process finished you have the freedom to burn it on a blank CD with whatever you favorite CD burner software may be.
The new CD will be the twin copy of the Windows Installation CD but with one difference, it includes the SATA driver.
for more details look here:
http://paparadit.blogspot.com/2007/06/installing-sata-hard-drive-with-windows.html
Posted on May 27, 2009
    Scholar:
  • 143 Answers
U need to update yr bios or u need a usb floppy drvier then downlaod sata driver from hp website when u start install windows xp then give F6 to install sata but first of all u need a sata drvier for yr laptop and make a floppy of driver also is other way to install but it's difficalt called "Nlite" but for this u need sata drvier must.. it's help u
Posted on Jan 09, 2009
  • Chinmay Joshi
    Chinmay Joshi Jan 09, 2009
    u need to update yr bios or u need a usb floppy drvier then downlaod sata driver from hp website when u start install windows xp then give F6 to install sata but first of all u need a sata drvier for yr laptop and make a floppy of driver also is other way to install but it's difficalt called "Nlite" but for this u need sata drvier must.. it's help u
Windowsn xp
Windows XP installation problem in Compaq Presario CQ40-108TU
Hi, go to this link and read carefully about this article:
http://www.zyxware.com/articles/2008/10/17/windows-xp-installation-problem-in-compaq-presario-cq40-108tu
*Your vote is highly be appreciated. I hope this will help you. Drop me a comment if you still have problems. I will help you.
Jan 05, 2009 | Compaq Presario Notebook
Want install windows on compaq presario c700
you can install xp from any xp disk as long as you have a valid xp key.if your pc was purchased with xp installed you probably have a valid cd key on a sticker youll find on the underside of your pc .if you aint got one go into any pc shop and look for a pc installed with xp(theyre all pre-installed with either xp,xp pro or vista) on laptops look on the underside and write down the number on towers look at the sides near the bottom.if shop assistant ask do you need help say no just looking and taking down some details cos thinking of purchasing,
Dec 21, 2008 | Compaq Presario C700T Notebook
Installing windows xp to compaq presario 700 pc notebook
HP Compaq Presario 700 series was originally designed for XP and Vista, therefore you can install XP on it.
After installing Windows XP, you will need to install all drivers.
You can download drivers and software for your laptop from HP here.
Oct 07, 2008 | Compaq Presario 700 470024-192 Notebook
Drivers problem
i have been problem for driver on my notebook laptop c765tu model plz solve it
Sep 09, 2008 | Compaq Presario 700 470024-192 Notebook
Invalid code, and wrong product
Sounds like you have 2 legitmate choices.
Either install WIndows ME on the system since that is the OS that shipped, or purchase and install a retail copy of Windows XP
Aug 06, 2008 | Compaq Presario 5000 PC Desktop
Compaq C751NR need windows xp - conexant HD audio smart audio 221 driver
i just purchased a compaq presario c700 and the audio is not working. the device is conexant audio smart audio 221..any help would be greatly appreciated.
Jul 31, 2008 | Computers & Internet
Sound Driver of a Compaq Presario C700 Notebook PC
I have installed winxp on my new hp presario c700 laptop, but i have no drivers of said laptop for winxp. Will you help me find those drivers?
benjie
May 09, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario Notebook Logo
230 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
