Question about Motorola Mobility HS850 Consumer Headset
Pairing a motorola n136 with a lg vx5500
I put the blue tooth into pairing mode, try to pair it with my phone and it says no device found. WHat do I do?
    Problem Solver:
  • 14 Answers
Your phone probably is not capable of syncing into that kind of blue tooth, if not go see your cellphone dealers store they will help you.
Posted on Jan 10, 2009
IHF1000 IS NOT PAIRING SUCCESSFULLY WITH MY VERIZON BLACKBERRY PHONE. I ENTER THE CODE 1-2-3-4 REQUESTED, NOTHING HAPPENS, SO THEN I REPEAT PAIRING STEPS?
yes most motorola blue tooth devices have a pin pairing code of 0000 andyou have to make sure your blue tooth device is in discovery mode.
Feb 25, 2011 | Motorola Radio Communications
Can't remember how to pair my LG HBM-710 to my new phone - Samsung Fascinate. Can you help?
to pair a blue tooth device to a phone first you must turn the bt power on the phone to on,then you have to put your blue tooth device into discovery mode,now most manufactures use the power button for thisw feature.By holding down the power button on your device when turning it on for 6 to 10 seconds it usually puts the device into discovery mode.there should be a light that stays on on your blue tooth device.once you have the bt device into discovery mode you will be able to pair the device to your phone by search or add new device,once it pairs it will ask for a pin or pairing code.most manufactures of blue tooth devices use a 4 digit factory pin pairing code they aare as follows 0000,1234,9999,or 1111 once youve put tjhe pin code on they will pair ,i hope this helps
Feb 25, 2011 | LG HBM-710 Wireless Headset
Need password to connect to my phone. Motorola bluetooth H371
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps..
Thanks for using fixya...
Oct 27, 2010 | Motorola Mobility H371 Bluetooth Headset
How to put a hbh705 into pairing mode
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Aug 06, 2010 | Sony Bluetooth Headst HBH705 Sandcolor...
What is the bluetooth passkey code for lg gt505 mobile phone to pair with other devices
HOW TOCONNECT BLUETOOTH
Take care.
Jul 02, 2010 | LG GT505 Cell Phone
Motorola H700 won't pair with LG CU720 phone
You will need to enter pairing mode on your device. The H700 User Manual indicates that you do so by first turning off any previously paired device and opening the headset BOOM. The indicator light should light a steady purple while in pairing mode.
You may not need to turn off your phone if you do not desire this, you may be able to get by turning the blue tooth function off and on, on your phone and attempt to pair again.
Pairing Pin is likely 0000.
Dec 29, 2008 | Motorola Mobility H700 Wireless Headset
HOW DO I PAIR A MOTOROLA n136 TO A LG VX5400
follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Dec 21, 2008 | Motorola Mobility HS850 Consumer Headset
How do I put the Blue Tooth device into pairing mode?
first switch on ur mobiles bluetooth connection......... then switch on ur moto H350..... then it automatically ask to pair with ur mobile jst accept it........ and then enter the pass code 0000.........kkkk... then it get paired... kk..........
Oct 26, 2008 | Motorola Mobility H350 Wireless Headset
Bluetooth help
turn on bluetooth in both the phones
in anyone of the phone try searching for new devices.
it may ask some code for pairing of both the devices.
after giving the code ,both the phones ll be enabled to send and receive the files in both o them..
Jun 16, 2008 | Cell Phones
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Motorola Mobility HS850 Consumer Headset Logo
324 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
