Might be the flame sensor. if it is open the ignitor won't light off. Check this part for continuity. Number 59. If it is open now power can get to the gas assembly. Clean out the duct work and filter housing if that puppy is blown.
When the drum temp is below 105f the control Klixon throws the power onto the gas valve assembly. The flame sensor,ignitor, and solenoids are all powered up at the same time but the solenoids won't kick in until the ignitor drops out. The flame sensor bi-metal bends with the heat from the ignitor and open the circuit to it. The solenoids then have the power to ****** open the gas valve and raw gas flows out onto the hot ignitor and lights off. The burn last only till the drum temp reaches 160f which takes not time. When that temp gets to 160 the control opens and power is removed from the gas valve assembly. This goes on throughout the drying process. So what goes wrong? Open sensor, bad ignitor, faulty solenoids that quit after working a tiny bit. Blown or tripped thermal limit. bad control tstat. And me fave: unpaid gas bill.
There are several things that can prevent a dryer from not heating.. Unplug Power Before checking. Electric Models 1- Power- Your dryer runs on 220volts. 110 runs the entire dryer and 110 runs just the element. Your breaker may have half tripped. Check to see if you are getting the correct amount of power by using a ohm meter. Also check the power cord for burn marks on the plugin and the cord itself. 2- The thermal fuse can prevent this from heating. The thermal fuse is a sensor on the blower housing the measures the temperature of the air. There is a cycling thermistat near the thermal fuse. If the dryer temp gets over 190-220 degrees the thermal fuse will blow to cut power to the element to prevent fire. You can test this by using a continuity tester. 3- High limit and/or thermal cutoff. These are both sensors on the heating element housing. Thermal cutoff is at the top and the high limit is near the bottom above the heating element connectors. Test these with a continuity tester. 4- Heating element- Just below the high limit on the heater housing. Test for continuity. 5- Motor- The motor has to reach a certain rpm to activate a sinfrigrial switch inside the motor. If the rpm is not reached it will not allow current to go to the element. 6- Timer- Make sure you are trying this on timed dry. Sometimes people use air fluff and forget to change it back. The timer could also not be sending current to the heater.
Gas models 1- Electric ignitor- Inside the flame tunnel inside of dryer near where gas line hooks up. Usually if it glows than it is still good but check to see if it is sending and amp signal to the heat coils. 2- Heater coils are two valves that open up when the ignitor send signal saying the ignitor can ignite the gas. Heat coils will not open to send gas if it does not receive a signal from the ignotor. They look like two round disk with two wires running from ignitor. 3- Flame sensor- Change if you change the heater coils. The flame sensor could not be detecting the flame inside so it shuts down the ignitor. 4- Motor- See above 5- Timer See above
If you have any further questions or need further assistance please feel free to comment me back
Electric Models
Gas models
4- Motor- See above
5- Timer See above
If you have any further questions or need further assistance please feel free to comment me back.
The only other possible issues would be your gas valve is bad or maybe a bad flame sensor. If the ignitor is glowing and you have replaced the booster coils mounted on top of the gas valve then your gas valve is probably stuck shut. Before replacing the gas valve I would ohm out the flame sensor mounted on the side of the heater housing. If it has continuity then its probably ok. If the thermal fuse was bad your ignitor would not even glow.
there's a thermal fuse that usually is the problem. when you push the start button; listen for 2 clicks. The motor centrifugal switch & than the coil on your valve. If you only hear 1 click, replace t-fuse. if you hear 2 clicks than ck for problems in the flate sensor,ignitor,gas valve
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. igniter igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor) Replace the sensor (located near the igniter) if found defective.
Remove the vent line from the rear and try the dryer. If it heats then that means there is a clog or kink in the vent line blocking the vent air from exiting which will stop the dryer from getting hot! If not then it's another one of these problems.
Defective Ignitor (Gas Only) When heated the ignitor used on your gas dryer must obtain a specific high temperature in order to activate the flame sensor. This ignitor is fragile and susceptible to cracking. A hairline fracture that is barely visible to the naked eye is enough to change the resistance of the ignitor to a point that is will not work properly. You can test the resistance of your ignitor. You should get a reading of 50-400 ohms of resistance.
If the ignitor gets hot and then goes off after about 10-15 seconds and there is no ignition, the problem is probably not the ignitor. It is most likely the gas valve coils that are defective.
If the ignitor comes on and stays on, it is the flame sensor that is defective.
If the ignitor is not getting hot it could also be one of the thermostats that is defective. The power for the ignitor is passed from the timer, through all of the thermostats, limit switches and fuses to the ignitor. So if you are not getting power to the ignitor during ignition, you should check the continuity of the individual thermostats and fuses. DRYER DOES NOT HEAT
Defective Gas Valve Coil (Gas Dryer Only)
If the gas dryer will light once but will not relight until it cools down, it is likely the gas valve coils are faulty. These coils loose some strength when subjected to heat. When they become old, the addition of heat may be enough to prevent them from opening the gas valve when hot. However the coils still work when when cool.
An easy way to diagnose the coils when the burner is not lighting, watch the ignitor. If the the ignitor glows for 10 to 15 seconds but no flame is created, then the coils are faulty. If the ignitor is not glowing the problem is elsewhere.
Recent Customer Symptoms: The dryer burner doesn't always come on when starting. If the burner does come on, once it goes off if won't come on again until the dryer cools down.
Defective Flame Sensor (Gas Dryer Only) The flame sensor's job is to monitor the ignitor for sufficient heat to ignite the gas. A properly operating flame sensor will pass a continuity check under room temperature.
Common Symptoms If the flame sensor is defective in the open position, the ignitor will not get hot when the dryer is started. However, if it is defective in the closed position the ignitor will get hot, but the flame sensor will not allow the flame to ignite. In this case, the ignitor will usually stay hot for a long period of time.
Defective Thermostat The thermostats are responsible for maintaining the proper temperature in the dryer. Check the exhaust temperature of the dyer and if the temperature is above 150 degrees, you will most likely need to change the operating thermostat.
The thermostat can also fail in the opposite mode. It can prevent the element from heating at all. A failed continuity check at room temperature will verify this condition.
There are some special thermostats that are single pole double throw. These thermostats are often used to control the timer when set to the Automatic Dry cycle. If the dryer timer will advance in the Timed Dry cycle but not the Automatic Dry cycle, then the thermostat could be the problem.
Defective Thermal Fuse The thermal fuse is in series with one leg of power to the motor. If the fuse is open (no continuity) the motor will not run.
Location: The thermal fuse is located in different locations according to the model and brand of dryer.
Solution: Check the thermal fuse for continuity with a volt/ohm meter. If it is open, it will need to be replaced
Thank You For trusting us with your question Please remember to leave a solved rating before you leave!
my dryer will not heat up not sure what is wrong or how to go by fixing it, cant find my manual
