I get an error when i trying to install my motherboard driver for k8t800pro for windows xp pro
  • chinthaka Jayasinghe
    chinthaka Jayasinghe May 11, 2010
    i need to know more details of the issue
  • 416 Answers
The error you get is due to the fact that it does not support some functions in XP.
Posted on Jan 15, 2009
  • 144 Answers
Hallow dude looking for *********** board drivers ,you can install it from this website http://www.nodevice.com/driver/K8T800_Pro/get37355.html
caution > the motherboard is not suitable for windows xp ,so it is better to install windows 98
Posted on Jan 09, 2009
ASUS M4N68TM 1TB hitachi HDS721010C SATA Drive 460gb partition Phenom II X2 Trying to load Windows XP Pro For a client of mine. Windows trys to install but after the format partition part it reboots then...
What Service pack of Windows XP are you using? A 1TB drive will require SP2 or 3. Also, does this board require "AHCI" drivers (hitting F6) to install special boot time driver.
It sounds like a boot time driver. The other option is that there are bad blocks on the drive. That will do the same thing. However, check into boot time drivers, Visit http://support.asus.com look up this motherboard and see if there is a "SATA driver" required .
Jan 07, 2011 | ASUS M4N68TM Motherboard
Error code
Apparently the XP Pro CD you are using is pre-SP2, thus causing the error. With XP RTM and SP1, you need to supply the proper SATA drivers for the chipset on the motherboard since there is no built-in support for SATA drives. You can download the drivers from http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=2214&areaid=2&LanID=0
During the XP setup you will need to press F6 to install these driver before attempting to copy the XP files to the drive. Or you could make a custom XP CD using the directions at http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html that has these SATA drivers already slipstreamed into the installation procedure.
Or if you know someone who has the WinXP Pro SP2 CD, you could borrow that for the install.
Apr 07, 2009 | Foxconn (945G7MA-8KS2) Motherboard
Problem loading XP Serve Pack 2 in Gigabyte 8I845GVM-RZ
I know this may sound mundane, but did you load the correct set of windows drivers for the Intel 845 chipset? I mistakenly loaded the Home drivers onto a unit I tried to install Pro on and I got all sorts of errors.
Mar 26, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
CANT GET WINDOWS XP PRO TO COPY FILES TO A GX280
The problem is the driver for the sata hard drive. You would need to get that from the dell site and put it on a floppy disk, then at the start of the windows install select to install that driver. I ended up just installing the rc version of windows 7 and it worked out fine.
Mar 02, 2009 | Dell Optiplex GX280 (99301) Motherboard
Changing processor results in windows xp pro failing to install
I'd try upgrading the bios with the working cpu and then try again.
Let me know what happens. I like the weird ones like this.
Feb 26, 2009 | Abit KT7A Motherboard
VIA Asus A8V Socket 939 Motherboard - K8T800Pro
You should be able to find it on the Asus website under the support section. All you need is the board model # & the operating system you are using. Hope this helps & please remember to rate my answer. Thanks.
Jan 09, 2009 | VIA Asus A8V Socket 939 Motherboard -...
Motherboard driver for k8t800pro
Try these links
http://www.via.com.tw/en/products/chipsets/k8-series/k8t800pro/
Good luck :)
Jan 08, 2009 | ASUS P5S800-VM Motherboard
Hd audio driver fail
i have intel 945 motherboard when i install audio driver i found error hd driver fail how can i resolve this problem.
Apr 09, 2008 | Intel Creative Labs Sound Blaster 16 PCI...
Can not install win xp on MS9158E MATSONIC motherboard
Dear Sir/Madam,
I install the winxp in MS9158E matsonic motherboard and after installation sound card not working. Mean sound not coming and i search the drivers from website but i didn't found the sound driver from web. So, I request you to please help me for download the driver for specific motherboard.
Jan 17, 2008 | Matsonic MS9158E+ Motherboard
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
