Question about Dell Inspiron 1521 Notebook
My screen doesnt work.
When I start my computer, it makes the starting sound, and the light flashes, indicating that it is working, but the screen doesnt start, the screen stays black.
    Problem Solver:
  • 11 Answers
I suggest you to perform these steps.
Test the AC adapter Follow the steps below to determine whether the problem is related to the AC adapter or your notebook system board.
  1. Remove the battery and disconnect all external devices from the computer.
  2. Hold the Power button for several seconds, with all power sources removed. This drains residual power from the system, and may correct many problems.
  3. Connect the AC adapter to a wall outlet and plug the other end into the computer.
  4. Press the Power button to start the notebook PC.
If the notebook does not start or the display is blank then check the power indicator light or power socket LED. I suggest you to connect the notebook to external monitor and check whether its working or not. Then please perform the harddrive self test also.
Posted on Jan 09, 2009
Problems: ac speedometer warning lights 2006 honda civic
It sounds like you have a ground issue near the transmission. Make sure the ground strap above the upper radiator hose is booked down good. Also check the plugs on the transmission for a loose connection.
Apr 26, 2017 | 2006 Honda Civic 1.8
When u turn left turn signal on they flash really fast and the light on fender doesnt light up now with no turn signals on and you push horn button left side starts flashing with the fender on flashing...
dear,
firstly make all the bulbs glow in the indicator segment.
this will moderate the flasher speed as due to even one bulb fused, causes other bulbs to glow at high rate.
thanx
May 20, 2011 | 2007 Hyundai Accent GS Hatchback
Hp1350 wont scan press scan button on/resume light blinks buzzing for a few seconds and nothing else.
Did you try print any document just to make sure that printer is connected properly to the computer. If it is printing than try to scan from computer , i mean there must be a icon in your computer "Hp Director", open that and click on scan document. if that doesnt work, than click on start, got to run and than type "stimon.exe" than hit enter from keyboard. Nothing will happen , just screen will flash for a second, than try to scan. if it doesnt work than you have to unistall and reinstall the software
Aug 07, 2009 | HP Office Equipment & Supplies
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Screen stays blank when turned on
take your computer to your dealer and send it for repair.
The problem is most likely the inverter for the screen.
actually to see if that is the problem you can try to put bright light to the screen and see if you barely see the picture.
May 28, 2009 | IBM ThinkPad R51 Notebook
Indicator is turning on but not flashing.
Assuming ALL bulbs work including the warning lights on the dash, it sounds like a faulty flashing indicator relay to me. Try a replacement.
Apr 07, 2009 | 1993 Suzuki GSX-R 600
When I start up my computer, the screen stays black. However, the light flashes indicating that it is working, and the computer makes the starting sound.
Test your notebook with an external monitor attached to the VGA port on the side of your notebook. If both internal and external monitors have no image, this problem is not related to the notebook screen.
It could be memory related problem. Try reconnecting the memory module. If you have two modules installed, remove them one by one and test the laptop with each module separately. It’s possible that one of the memory modules is bad and your notebook will start as soon as you remove bad RAM.
Jan 09, 2009 | Dell Inspiron 1521 Notebook
A drop image on screen
hi i have panasonic NV DS 65 initially when i power on the cam it started then after 5 to 10 sec the power light automatically flashes and the buttons on camera doesnt work any more. but now the problem has got worsend the powen light keeps on flashing and no buttons work moreover a drop image is flashed on the screen.
plz have me solve my problem
sam_rav
Jan 24, 2008 | Panasonic NV-DS65 Mini DV Digital...
Dell inspiron 1150 laptop black screen
Can you hear the Windows startup noises but can't hear it?
Does it work plugged into an external monitor? (Any good CRT or flat screen should work.
Be sure to plug in the screen before you turn it on.
If it doesnt output to the LCD automatically you may have to hit FN-F8 to switch to external.
If it works on external monitor you are just dealing with a screen problem of some sort - either a bad inverter or backlight in the LCD most commonly...
Let us know.
Dec 17, 2007 | Dell INSPIRON 6000 CENTRINO...
Dell Inspiron 1521 Notebook Logo
177 people viewed this question
Alun Cox
