Question about Dacor Epicure ERD48 Dual Fuel (Electric and Gas) Kitchen Range
Controls completely black after power surge DACOR ERD48 Range
We had a power outage then brownouts in an ice storm and after power was restored our range control panel did not come back on. Our microwave, alarm, and an electric toothbrush were also fried.  What part would have been damaged on the range and need replaced?  Thanks!
frankgant
  • 250 Answers
SOURCE: F6 Error
I contacted Dacor and they stated that the F6 error means the ERC or Electronic Relay Control is bad. This part would need to be relaced. They gave me a parts company to contact for the part. It is Appliance Parts Depot at 1-800-642-6420.
Posted on Jul 09, 2008
sdmc73
  • 121 Answers
SOURCE: How do I calibrate a Dacor Millenium oven range?
the main control can be adjusted by holding down the bake button for 1 min.
Posted on Nov 29, 2008
dovaleh
SOURCE: Dacor Oven Death
hi,
i think first you should call dacor, 4 months is marginal - they should cover it
but if all else fail you can try this link ti diagnostics manual:
http://dacorservice.com/PartsCatalog/docs/ProductModels/437/Diagnostic_Manual.pdf
and this link to dismanling instructions:
http://dacorservice.com/PartsCatalog/docs/Ranges/Service%20Manuals/ERD30s06_sm.pdf
good luck
dov
Posted on Jan 10, 2009
jumptrout51
  • 3361 Answers
SOURCE: dacor rsd305
Once you replace the oven control again....never use self clean on any oven....unless you want to replace parts.
Before you replace the control...look inside the control panel for a resettable thermal fuse.
Posted on Mar 10, 2009
jumptrout51
  • 3361 Answers
SOURCE: Dacor oven door does not close completely
Place a hammer handle between the hinge and the door frame. Exert moderate pressure to close the door. It should spring back to normal position. Do both sides.
Posted on May 05, 2009
We have an XE-A217W which has decided not to work following a power failure. The printer still scrolls but the screens remain blank
Hi Trevor.
By 'scrolls' I guess you mean 'feeds paper'?
If display screen is blank since the outage, try switching off and unplugging the printer for a minute or so, then re plug.
Unfortunately, a power outage often results in surges and brownouts while power is being restored, which can disrupt or damage electronics and electrical devices.
The board may have fried.
Nov 23, 2017 | The Office Equipment & Supplies
Samsung Rs2530B frig had power outage, now cubed ice is blinking and water and ice dispensers are not working.
CONTROL BOARD ON REAR PANEL IS MOST LIKELY THE PROBLEM .THIS IS COMMON WITH STORM DAMAGE..
Apr 26, 2017 | Samsung Washing Machines
Model NE-9970. After a storm-caused power outage, why does the microwave have no power to the control board?
Usually the microwave is plugged into a ground fault protected outlet. Push the buttons on the receptical and power should come on. The ground fault may be above your counter top and protects the plug your microwave is pluffed into.
Nov 18, 2015 | Microwave Ovens
Westinghouse ice maker quit working
Is it your ice maker, or possible the blades that crush the ice or dispense the cubes? What can happen in the latter case is that during the storm the ice melted and pooled in the cutter mechanism. Then, when power was restored, the blades were frozen solid. To fix, investigate taking out the cutter mechanism and letting it thaw and drain. Then reinstall and use frequently for the first few days to prevent refereezimg.
Feb 26, 2014 | White-Westinghouse White Westinghouse...
Dacor ERD48 Range. The circuit board went dead. No lights at all. Time flashed a short while (as if there was a power outage) then nothing. I assume I need the board repaired or replaced. How do I...
There are screws somewhere around the board housing. First check below the control panel just above the door. There might also be one screw on the ends of the control panel. Usually you do not have to remove the knobs to do this.
When you get to the board just behind the panel, it might be held down further be clips at the edges.
Oct 20, 2013 | Dacor Kitchen Ranges
Where is the model # on an older 48" range w/ 2 ovens?
Epicure ERD48 quite likely is your model number and unit information is usually located on a sticker on the back panel of any unit
May 19, 2012 | Dacor Epicure ERD48 Dual Fuel (Electric...
Lost power due the storm' when power was restored micro. never came back on
Possible that during the power outage there was fault in the mains supply and with the oven being plugged on it is possible that the power supply or the main board is damaged.
Unless you are able the top cover it is difficult to confirm if this can be silly fault like a fuse blown which is on the mains circuit or a Step down transformer or the processor board.
Nov 06, 2011 | Maytag MMV1153A Microwave Oven
Had a storm the range works but the oven went out model number 8114P732-60 Maytag advance cooking system super cap. is there a reset button
There isn't a reset per say but you can turn the unit off at the breaker box for the home for 1 to three minutes. If this does not work...either the heating elements were blown during the power outage or the control board is now fried from the surge and needs replaced.
Sep 01, 2011 | Maytag MER5775Q Electric Kitchen Range
I have a moose z1100e and after a power outage i cant get in to program, what do i need to do?
It has been my experience that if an alarm panel behaves differently after a storm or power outage I would power system down wait 1 min power back up. If that does not help. Then I would try to default the panel and reprogram it, if the customer was desperate to keep it. If not(taps plays in backround) time to replace panel.
http://sirflannel.homeip.net/files/security/Burg/GE/MooseZ1100E-installation.pdf
GL
Aug 04, 2011 | Moose Z1100r Z1100 Led Control Station In...
Dacor Epicure ERD48 Dual Fuel (Electric and Gas) Kitchen Range Logo
73 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
