Question about Gateway 838GM (RB838GM) PC Desktop
When the computer starts up. "Gateway" appears on the screen. Then the computer freezes. None of the reinstallation discs do anything. How do I fix this?
    Novelist:
    Champion:
  • 233 Answers
When you get the Gateway splash screen hit the F12 key. This should get you a page with several startup options. Try Safe Mode and see if the computer boots. If it does go into Device Manager and see what it says about the hardware. Also see if you can get into setup, probably by pressing F2 or Del at startup. You might find a problem device in there. It sounds like the power supply, graphics card and monitor are working because you get a splash screen. My first guess would be the hard drive has a problem.
Posted on Jan 09, 2009
    Problem Solver:
  • 13 Answers
Sounds like ram ,or motherboard or hardrive , try switching ram 1st or try formatting the hardrive and reinstall windows
    Novelist:
  • 176 Answers
Reboot and keep tapping on F8 to go to Safe Mode. Do not put the reinstallation disk yet. Once in Safe Mode select "last known good configuration".
You can also run "Chkdsk" from the C hard drive Properties if you get to Safe Mode. Double click "My Computer", right click on C drive, select Properties, select Tools tab, go to Error checking and click on "Check now" then check "automatically fix file system errors" and "scan for and attemp recovery for bad sectors" and click "start"
If that doesn't work proceed to do System Restore in Safe Mode or remove previous programs that may have caused your Windows to freeze. If you suspect virus, run your anti-virus in Safe Mode.
If none of the above works then try your XP CD (or reinstallation disk) and do a repair.
My gateway laptop won't reboot after system recovery
I would put in a Windows disc and see if that prompts windows to start and/or reinstall. Actually, can you send me the recovery disc via download? I am trying to fix my old laptop and cannot find the discs. lilly.murphy@yahoo.com Thanks much!
Nov 30, 2012 | Gateway NV55S04u PC Notebook
How to solve this problem?
Does it get to the Operating System screen? ie, anything that indicates a Windows system or similar OS? If it doesn't make it to the OS screen I would say that there may be a problem with the hard drive, in which case you can try re-installing a clean version of your operating system, which would require you to lose your data. If your adequate with computers I would say take the hard drive out and retrieve any data you want to keep by using it as a slave drive on another computer. Otherwise you may want to take it to a computer expert to get the data retrieved for you. If you can live without it than get an operating system disc and do a clean install of the operating system, which should fix your problem.
Aug 17, 2012 | Gateway LT4004u 1.6GHz 250GB 10.1-inch...
How do I download or get gateways 500 gr recovery disc ? I need everything reistalled
To start the systemrecovery:
  1. Restart the computer.
  2. When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer. Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
  2. When the computer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.
  1. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Sep 22, 2011 | Gateway 500GR PC Desktop
The laptop won't load past the welcome screen. I can get it to start up, and go to a start in safe mode etc. but it won't load past the welcome screen.
Your computer is experiencing a no boot problem which means that the operating system is corrupted. You can do a start up repair to fix the computer but if it won't fix it then that's the time that you need to reinstall the whole operating system.
It could have been very helpful if you provided us with your operating system so that we can provide you with the exact troubleshooting. However, I just presume that you are using windows VISTA or Windows 7. However, this troubleshooting also works with windows XP.
Before you start the start up repair. You need the Operating System Installation disc from Microsoft.
1. Insert the disc in the dvd/cd drive.
2. Restart the computer.
3. Once you see the "press any key to boot to cd" message. Press any key.
4. It will bring you to a page where it will ask you to INSTALL or to REPAIR. Just click on repair.
5. It might ask you to load the drivers. Just click ok or next.
6. Follow the on-screen instructions.
However, if start up repair won't fix the problem, Clean Reinstallation is the next step. Clean reinstallation will delete everything in your computer including the files, pictures, etc. that you have saved. But you cannot really access them anymore since the computer won't boot up.
I'm am providing you with the links to the tutorial on how to reinstall the operating system.
1. WINDOWS XP REINSTALLATION TUTORIAL
2. Windows 7 Reinstallation Tutorial
3. Windows Vista Installation Guide
I hope this helps. Thank you for using fixya.
carloadrian
Feb 03, 2011 | Gateway M-7315U Notebook
Hello .. I have a laptop and the 7520G Aceraspire HDDWD2500BEVS .. Disc HDD does not occur in the BIOS says it NONE .. .. I do not know how to reinstall from the CD, when the disc does not load .....
> HDD does not occur in the BIOS ... says it NONE
This is the first problem that you need to fix, before doing anything else.
Check that the disk-drive is properly "connected" (both "data" and "power" connections).
Enter "BIOS SETUP", and see if the disk-drive is correctly "detected".
Probably, you need to replace the disk-drive, and then reinstall Windows.
Is the current disk-drive still under the manufacturer's warranty?
Dec 22, 2010 | Western Digital WD2500BEVSRTL Scorpio...
I have a gateway M 6843. my scren freezes, lines appear
Sounds more like a loose video connector on the back of the screen.
Nov 13, 2009 | Gateway M-6843 Notebook
Desktop frozen with the monitor showing disorted, green blocks
Try rebooting your computer with a disc or discs that came with it. That disc or discs should reinstall windows. If this does not work try getting linux or dos on a cd an try betting from the cd instead of the HDD. If this does not work either then it must your graphics card or HDD. I am leaning more towards graphics card because ussually your computer will give you a blue screen if your hard drive fails.
Aug 01, 2009 | Gateway Computers & Internet
Apple iBook G4 14 inch 512 ram 1.42 GHz. 3 Year Warranty expired last December but I have lots of software and Classic programs too so want to fix it. Here goes. Running X-Plane Flight Simulator for many...
Sounds like a GPU problem to me.
You can go diy approach which involves taking the laptop totally apart and then heating up the GPU with a heat gun.
If you google you'll find guides for this.
Best of luck!
Jun 13, 2009 | Apple iBook G4 Mac Notebook
Gateway laptop computer freezes during system recovery
Turn the computer off, then start it back up and press the f2 key repeatedly til a blue screen called the BIOS screen comes up, press the right arrow on your keyboard so it goes to the advanced tab. go down to speedstop and disable it, press f10 to save changes and start computer over. Now it will work no freezing :)
May 31, 2009 | Gateway MX8711 Notebook
BLACK SCREEN
If you have a format disc for your computer or you still have the vista disc you will need to reinstall your Operating System. Reinstalling the Operating system will remove the old one and should fix the problem. But put the disc in the drive before the computer is turned on to reinstall.
Apr 29, 2009 | Computers & Internet
Computers & Internet Logo
152 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
