Question about Motorola Mobility RAZR V3
Phone goes off dialing 777 over and over again
This cell phone malfunctions in that it dials number 7 all by itself. I barely have to touch it sometimes and it goes off dialing 777 over and over. So, I definitely can't dial out because instead of the numbers I press, I get number 7. Receives calls okay though.
  • Kandy Lykam Jun 04, 2007
    It does happen while talking as well. No longer under warranty. I shall look into a new keypad and manual on how to replace it...thanks a bunch
  • Kandy Lykam Jun 05, 2007
    Ebay has for sale a MOTOROLA RAZR V3 V 3 OEM LCD KEYPAD FLEX CABLE PARTS at the site below.
    http://cgi.ebay.com/ws/eBayISAPI.dll?Vie...
    I'm thinking this may be what I need? Manuals are only about $1.50, but I may not need it if I request instructions as stated in the listing. What's your take on this idea?
  • 35 Answers
Does the problem occur while you are talking? That is when you barely touch the keys while talking. If it does you have a bad keypad. You can order another. Just google "razr parts". There is also several manuals on how to disassemble it. If it is still less than a year old and there is no apparent physical damage you may have it sent under warranty. When all possible go with the warranty.
Posted on Jun 04, 2007
  • Gerry Welter Jun 05, 2007
    Good luck! It is very tight fit inside the phone. Make sure you heed all the warnings in the instructions.
  • Gerry Welter Jun 11, 2007
    There are manuals online. Do a search for razr manual disassemble. They vary slightly but they will get you there.
SOURCE:
How do I get my home phone number to ring on my cell phone while I am on vacation
It's called "call forwarding" and the procedure varies from company to company. With many, dial * 7 2 on your home phone, then at the second dial tone dial your cell phone number. Answer your cell phone when it rings to confirm the call forwarding. To cancel call forwarding when you return from vacation, dial * 7 3 on your home phone.
If the above doesn't work then contact your landline telephone company for their instructions regarding call forwarding.
Aug 01, 2013 | Computers & Internet
How to set voice mail button on the phone - so i need not to dial intercom 777 and also how to set one touch button on the phone for music - so I need not to dial feature 19.... thank you
on that phone
press FEATURE 00
press the button you want to set for voicemai
press LEFT intercom then 777
now press the button you want for music (has to haave lights)
Press FEATURE 19
When done programming, press FEATURE 00
Aug 12, 2011 | Avaya Corded Phone avaparp18d
AVAYA Phone System: Lucent Partner Mail
press feat 00. touch btn to program dial feat14. this is now a voice mail transfer button. to program an ext button, touch btn to program, press left intercom dial 2 digit extension. Can you dial 777 and get voice mail?
Aug 26, 2009 | Lucent PARTNER18 Corded Phone
I have a motorola V186 cell phone. When I dial a number, if no one answers after 7 rings, the phone automatically cuts out and says 'no answer', then I have to dial again. My mom is just about deaf and I...
You are lucky to get 7 rings out of any cell phone.
Cell carriers limit the rings permitted to keep the traffic down. If you call another cell, it goes to voice mail. A landline just stops ringing.
Jul 03, 2009 | Lands Phones
Vu 204..new phone, speed dial does not work, goes to verizon wireless message which says call cannot be completed as dialed. Checked numbers they are OK, also happens which #1 for speed dial of *86 which...
I had the same problem and found that the speed dial feature in "settings" is not turned on by default even though voice mail number is pre-programed into the speed speed list. Go to "Settings & Tools/Call Settings/One Touch Dial" and turn the option on.
Cheers,
Don Devine
Mar 30, 2009 | Motorola Mobility VU204 Cell Phone
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
The phone dials numbers by itself i think it needs reprogramming
Blackberry pearl dials phone numbers on it's own.
I've taken out the battery for an extended time and when replaced, starts dialing numbers again.
How do I restart the phone to reset factory specs or what else can I do?
May 08, 2008 | RIM Blackberry 8110 Cellular Phone
Tom Tom ONE XL Connection
1. Phone selection - other
2. Carrier selection - other
3. Access point - vzw3g
4. username - (phone number)@vzw3g.com
5. password - vzw
6. number to dial - #777
7. No scripts
Jan 12, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Setting up a speed dial
from the website:
How do I set speed dial for one of my contacts? First, find the contact in your Contact List, highlight it, and press OK. Then select Options -> Speed Dialing and press OK.
Choose one of the numbers from the list and select Assign to assign it to your contact. You can now use 1-Touch Dialing for that phone number. Just press and hold that assigned one or two digit number instead of dialing the contact's entire phone number.
Sep 16, 2007 | Kyocera K10 Royale Cellular Phone
Motorola Mobility RAZR V3 Logo
141 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
