Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE true temp oven f2
I was self cleaning my GE oven when the f2 light showed and the alarm went off. I cant stop it from beeping and I cant open it. What do i do?
  • 3 more comments
  • dhcooper Jan 19, 2009
    The same thing is happening to me. How do I stop the cleaning cycle to cut it off?
  • sjds2000 Feb 09, 2009
    I had the same problem when self cleaning my GE TrueTemp oven: it overheats, won't shut off and flashes F2
  • tom_in_md Feb 27, 2009
    in looking around, F2 is the GE code for "oven too hot". this code is set by a resistor and not by the true temperature of the oven.
    that siad, i am not too sure how it gets fixed. my oven is doing the same thing.
  • Anonymous Mar 09, 2009
    I had been using the broiler, and then shut the oven off, then it started beeping, with the display saying F2. I opened the door and after awhile it stopped. I had been broiling a steak and it caught on fire prior to that. I wasn't able to grab the steak out of the oven because I was on the phone and couldn't get the other person to stop talking. I figured the oven over heated from the flames; hopefully isn't damaged. I'll see if it works tomorrow. I haven't had any problems with this GE range/oven in the 8 years that I've had it.
  • Anonymous May 24, 2009
    F2 show and oven beeps...what does this mean
This happens every time I clean my oven. It overheats, shows the f2 light and BEEPS loudly. The only way to stop it is to turn the oven off at the breaker box, wait until it cools (usually 2-3 hours), flip the breaker back on and start the process all over again until the unit is clean. If it's not to dirty, sometimes it's easier to juat use Easy Off.
hope it helped
Posted on Jan 09, 2009
    New Friend:
Hello I replaced the temp des or for a F2 code and it still hasn't solved my problem, what else could it be ??
Posted on Feb 25, 2015
  • Adrianne Lay
    Adrianne Lay Feb 25, 2015
    Temp sensor sorry auto correct
2 Suggested Answers
  • 213 Answers
SOURCE: Need to clean oven GE true temp self clean
the oven temp sensor is bad. replace temp sensor to solve problem
Posted on Nov 19, 2007
I was letting my oven self clean and then it has started beeping went and lookfed and F2 is flashing what does that mean
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
Nov 15, 2010 | GE Ovens
I'm getting a F2 Error and door locked with flashing and beeping after I ran the self-cleaning mode on my GE Model JTP85 built-in oven.
f 2 code states that your oven temp exceeds 590 w/unlocked door .. the oven tempt sensor will need to be replaced .. hope this helped mm
Dec 04, 2009 | GE JTP85 Electric Double Oven
F2 error
F2 is a bad temp sensor, needs to be replaced.
Jun 23, 2009 | GE JKS06BFBB Electric Single Oven
F2 displayed when using self cleaning
REPLACE THE OVEN TERMISTER PROB IT WILL FIX YOUR PROBLEM. CALL 800-614-2700 TO GET PRICE ON IT AND HAVE MODLE # REDAY
Jan 25, 2009 | GE JKP15 Electric Single Oven
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Self-Clean gets too hot on JTP56 double-oven
Your husband is correct, kind of. You should not try self clean again until you get the oven repaired. You have a temp sensor going out. I doubt that the oven actually got too hot, most likely the resistor in the sensor is failing as it heats up and giving a false temp reading.Since the lower oven was operating at the time, it is probably the sensor in the lower oven. Don't use it for baking until you get it repaired. It will go out completely and shut down both ovens. You should be able to get a new sensor for around $30 and they are not hard to replace.
The oven won't set your house on fire during clean mode if the cabinets were built with the correct air space and dimensions, but they do get very hot, about 800 degrees F. Most ovens give no trouble during the clean cycle, but if there is any weak components in the electronics system it will show up then. It will give you less trouble over time if you don't use the self clean mode and just manually clean it.
Jan 18, 2008 | GE Profile JTP56 Electric Double Oven
Nov 18, 2007 | GE JBP71 Electric Kitchen Range
F2 message when self cleaning
I have the exact problem, had a service man look at it while still under warranty. He said it was fixed and left. Tried it again, same problem. Called him back 2 times after that, he quit responding to my calls. By tyhen warranty expired and GE refused to do anything.
Nov 07, 2007 | GE JKP45 Electric Double Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
5,848 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
