Question about SanDisk Sansa e250 MP3 Player
Frozen screen my mp3 player when turned on only displays the name of the product and the version. I can not locate any of my songs. The only function I can perform is turning the device on or off.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
SOURCE:
Technical details and dealer in kerala ( Cochin )
Technical Details
  • Brand Name: Coby
  • Model: MP300-1GBLK
  • Digital Storage Capacity: 1 GB
  • Color Name: black
  • Battery Average Life: 8 Hours
  • Supported Audio Format: MP3 // WMA
  • Display: LCD
  • Hardware Platform: PC
  • Width: 3.6 inches
  • Depth: 0.7 inches
  • Weight: 0.2 pounds
Product Features
  • MP3 player with LCD 1 GB flash memory and USB drive
  • high-contrast LCD display with 7-color backlight
  • plays MP3 and WMA digital music files, ID3 tag support for song information display, mobile data storage function
  • convenient integrated USB plug( no cables required)
  • USB 2.0 hi-speed for fast file transfers
Product Description Coby MP300-1GBLK MP3 player 1 GB flash memory and USB drive with LCD, high-contrast LCD display with 7-color backlight, plays MP3 and WMA digital music files, ID3 tag support for song information display, mobile data storage function, convenient integrated USB plug( no cables required), USB 2.0 hi-speed for fast file transfers, black.
Batteries: 1 AAA batteries required.
Feb 02, 2011 | Coby MP300 MP3 Player
I cant download music into it
Thry the solution below. If it does not work then you need to reformat. Also you might want to go to the coby website and download a updated version on the firmware and reflash your player. This will set it back to factory settings.
  1. Open Windows Media Player.
  2. Find and click the "Sync" tab. This is located at the very top of the program.
  3. Plug the Coby mp3 player into one of the USB ports found on your computer. Depending on the exact Coby mp3 player that you own, you can either plug the player directly into the USB port or by using the cord that came with the Coby mp3 player. The name of the Coby mp3 player will appear in the top right corner of Windows Media Player.
  4. Click "Library." This link will be on the left side of the program.
  5. Double-click the "Songs" option in the middle of the screen.
  6. Scroll through the list of music on your computer until you find the songs you want to put on the Coby mp3 player. Right-click on the title of the song and a drop box will appear. Select "Add to Sync List." You will then notice the song listed in the column located on the right side of the program.
  7. Repeat the previous step until you're finished putting songs on the Coby mp3 player.
  8. Click the "Start Sync" tab located beneath the list of songs you chose in Step 6. Those songs will then be added to your Coby mp3 player.
Sep 26, 2009 | Coby MP-705 Digital Media Player
I have 1gb china mp3 but after loadng songs only 10 to 12 songs are repeating again and again...ho can i solve this problem..
Try to change your playlist, make a system-reset at the MP3-player and then add songs again. Turn off the repeat/shuffle-function at your MP3-player. If it doesn't work, maybe you have to download some new drive-routine to your MP3-player. Good Luck. /David
Jul 21, 2009 | Microsoft Windows XP Professional SP3 Full...
Creative Zen screen is frozen on ZEN
If you have tried the reset hole on the bottom, try the mp3 player recovery tool here.
Feb 12, 2009 | Creative Labs Zen Digital Media Player
Rare screen problem ( i can`t see song titles and band names)
Sony's are especially sensitive to certain characters - it is possible that there is a character in the band/song name that is causing the defect - this is unlikely, since you say that it's occurring on all songs. Try resetting the language back to English in the Sony menu just to be sure.
Another possibility is that the ID3 tag is in a version that is not supported by the player. Unfortunately, I went through all of the product documentation, and it doesn't say which ID3 tag versions it is compatible with.  This is time-consuming, but you could downgrade your ID3 tag editor, delete all songs off your player, and then reload them to be sure.
-Tha Mp3 Doctor
Sep 13, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Go Gear 2gb
First of all you need to restore the player.
Install and run the Philips Device Manager from the product CD.
Select the Repair/Restore option and follow the on-screen prompts. This will format the player and re-load the firmware.
The HDD1830 is only fully compatible with Windows XP and Windows Media Player 10. If you have Windows Media Player 11 you will need to uninstall it. This will roll it back to version 10.
Tracks must be transferred to the HDD1830 using the Media Player Sync function.
The HDD1830 is only compatible with .MP3 or .WMA music tracks. It is not compatible with iPod .AAC tracks.
Mar 10, 2008 | Philips GoGear HDD1830 MP3 Player
Creative Zen V Plus Frozen on the product title screen
this helped me as after it rebuilds the libary then it always froze on a song let the battery run out!
this worked for me straight away and i had tried loads of other ideas this actually came from the tech guys !!!
  1. Detach the player from the PC if it is connected, and turn off the player.
  2. Press and hold the Play button while powering on the player.
  3. When the player displays the Creative logo, release the Play button
  4. Select Format (All) and select Yes to format the player.
  5. After the player has finished formatting, select Reboot.
  6. Re-transfer the tracks to the player.
Feb 16, 2008 | Creative Labs ZEN V Plus MP3 Player
I won´t turn on/off
hi, i'm from chile and i don`t speak much english, but i'll try to help you, because i think i've the aswer by my experince. when i was listening some song, and press for the next song, my MP4256FM frozen and i can't turn it off or nothing like that. after many times that i put play again the same song and frozen again, i understand that the MP4256FM will not read any song that in his name have a X,?,?,?,?, or ? (example axel.mp3 or introduci?n.mp3). So you have to change the name of the song on your pc and the ploblem will solved. I hope that this help you. bye! =) Jonathan Zu?iga el.zunhiga@hotmail.com
Jan 10, 2007 | Audiovox MP4256FM (256 MB) MP3 Player
"formatting problem"
I had a similar problem, I could upload songs, but they wouldn't play and I couldn't delete them. turned out it was cause I didn't have WMP10 installed on my PC, had an older version. the user manual states it only works with WMP10, and after I installed it (just search for windows media player 10 on the microsoft website) I was able to use the synch function in WMP10 and all the songs are playable (I'm listening to an album as I type :D)
Dec 04, 2006 | SanDisk Sansa c150 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
18 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
