Question about RCA R56WH76 Projection Television
Tried to replace fuse f231
I tried to replace the fuse f231...as i had the convergence problem and no convergence adjustment in menu...after i did this the tv wont power on..the green light comes on and goes off quick...three times in a row..i can hear it try to power up over and over...if i hold the power button for a bit it flashed 1 long and 9 short flashes...is this a code??and what could this problem be?
  • 1 more comment
  • Del Freeman
    Del Freeman Jan 09, 2009
    my model number is actually R56WH78 CH# ITC222A
  • Del Freeman
    Del Freeman Jan 17, 2009
    still awaiting any suggestions.
  • Del Freeman
    Del Freeman Feb 03, 2009
    well...i took it to the shop and was fixed pretty cheap...apparently it had blown a cap...and was resoldered..works great now!!
    Genius:
  • 1,030 Answers
My first suggestion on this set is to cheack to make sure you have not loosen the cable connections between the boards there is a flat ribbion cabel that runs from the green main board to the front crt boards. when tiltling the cuircit board this can come loose.
Posted on Feb 01, 2009
  • Willie Howell Feb 04, 2009
    great good to hear this. i see alot of these at shop. it always good to see a sucess on these
My screen shows 3 colors what do i do?
you haveing convergence issues. first question. in your customer menu under setup. do you have the conergence option if you dont i suspect the f231 fuse problem.. read this... http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in if this dont apply you may have to replace some faulty components in the convergence curcitry. let me know how it goes
Oct 22, 2010 | RCA R52WM24 52" HDTV Projection Television
Tip
Convergence Failure Test
CONVERGENCE PROBLEMS
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these sets and a fairly simple DIY fix.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some pics of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
47a7bc4.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
on Apr 18, 2010 | Televison & Video
My problem is with the convergence because i try to fixt it but when i put in menu and them set up the convergence is not appear there so i thing some fuse is buru or i nrrd some thing els
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Here are some photos of convergence problems.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 20, 2010 | RCA HD56W66 56" HDTV
Lost the convergence on my menu how do i fix this problem
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped. Here is a quick test.... Using your original remote go-to the TV settings then go to the convergence section. Try to adjust the red and then the blue convergence. You should be able to move them up, down, left, and right. If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem. Solution #1 you need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for most models. If you don't see kits for your set send them a quick note under the contact us button please, you will get an answer within 24 hours or so.(excluding holidays Good Luck, if the menu is not there replace the convergence chips also as a pico or so is blown do not replace any blown pico fuses without first replacing the convergence IC'(S)
Techman
Sep 03, 2009 | RCA D52W23 52" HDTV CRT TV
Having trouble adjusting lenses and color to correct settings.
Are you adjusting the TV using the menu or did you open the set up and turn the knobs. I hope you did not adjust the knobs without some instruction.
It may be a convergence failure. ( common problem ) or cloudy CRT fluid.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 16, 2009 | Philips 55PP9363 55" Rear Projection...
No convergence
Aug 04, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
Tv model r52wm24
You most likely need a new convergence power supply board if fl231 keeps blowing thats the most likely cause, also check for shorthed capacitor cp231. If you need a link to get a replacement convergence power supply board, let me know I know where you can get them.
Jul 19, 2008 | RCA R52WM24 52" HDTV Projection Television
Fl231
Some of those models are a different version of the PTK195 chassis some dont have the fuse. in that case you will need the convergence power supply board thats what likely blew the 5 Amp fuse. let me know if you need help locating one of those power supply boards.
May 21, 2008 | RCA P52926 52" Rear Projection Television
Location of convergence IC's in R52WM24
i have the same problem where is the fusible link i replace 2 boards and a connector (t.v. repair man can and diagnoised the problem but did not fix it)
Feb 02, 2008 | RCA R52WM24 52" HDTV Projection Television
Double vision and no convergence
I have found that fusible link FL231 is the main cause of this problem. It's located by the high voltage transformer and looks like a square coil.
Check it with an ohm meter and if it checks bad, then, replace it and you should not have to realign the convergence.
Any questions or comments, respond to this post and I will reply.
Jan 01, 2008 | RCA R52WM24 52" HDTV Projection Television
Open Questions:
RCA R56WH76 Projection Television Logo
186 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
