Question about JVC KD-S570 CD Player
Faceplate won't connect
I have the KD-S570 in my boat. The radio only works sporadically, unless I press on the faceplate. It appears to be firmly locked in place, but apparently the connectors are not making contact. Assuming I have properly connected the faceplate (is there a trick to it?) I would appreciate any suggestions. As it stands the radio is unusable. Thanks. Bob
    Brigadier General:
  • 6,966 Answers
There are possibly three (3) ways of making sure that there is contact between the faceplate and the unit's frontend:
1. normally, what it would take would be cleaning thoroughly and a light application of WD40 to the mating contacts;
2. slightly bend out the elbow type pins. This should be done carefully so as not to overdo and bend it out of place; or
3. solder a thin layer of soldering lead on top of the flat contact points to increase the contact height. Light/Low heat soldering iron must be use to prevent burning the plastic surroundings.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 13, 2008
Please i need the code of radio kenwood kdc-mp6039.please help me.
1) Turn on the car.
2) The faceplate rotates out and the CODE - - - - prompt appears.
3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.
8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
May 25, 2015 | Kenwood Car Audio & Video
Jvc kd-lx300, radio workz but has no adjustments working or shutting off working by pressing the buttons
please bring a contact lubricat cleaner from radio shack and apply the spray over eash button while you are pressing it in-and out.
Jul 17, 2008 | JVC Car Audio & Video
I need the security code of my car radio I removed the battery now it need a code which I don't know Kenwood PDX500M serial number 31104056 please.
For this fix you need to reconnect your battery.
1) Turn on the car.
Dec 19, 2012 | Cars & Trucks
My KD-LH810 turns on and plays the cd that is in it but the faceplate does not come on and it continues to play the cd - I cant turn it on or off and none of the other buttons work on the faceplate work so...
wipe the connection where the face connects at i had the same problem and it works fine after cleaning the connection and i will guess the power light itself is still lights up and no other button lights or the screen itself if that is correct then u most likely just have moisture in the connections try wiping it with a dry soft cloth
Oct 27, 2010 | JVC KD-LH810 CD Player
What is the security code for kdc-891
You will need a Kenwood RC-410 remote control.
To reset the code do the following:
1) Turn on the car.
3) Press >>| and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>| key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>| key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>| key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>| key on the faceplate.
Jun 01, 2010 | Kenwood KDC-X891 CD Player
Xbox wont turn on
Your console should turn on when the eject button is pressed. Press the eject button on the front of your console.
If the console turns on when you press the eject button but not when you press the power button, the console faceplate might not be attached properly. To make sure that the faceplate is attached correctly, you should remove it and reattach it.
  • Position your console horizontally, as you would position a DVD player.
  • Unplug the power cord and any other cables connected to the back of your console.
  • While holding your console firmly, curl your fingers inside the oval USB door on the front of the console.
  • Push the faceplate away from the console with your thumb until the faceplate comes off.
Note You will need to use some force to remove the faceplate.
Once the faceplate is removed, look at the tabs on the back. If any of the tabs shown in red in the illustration below are broken, order a replacement faceplate by contacting Xbox Support.
If none of the tabs are broken, re-attach your faceplate by pressing it firmly until it clicks into place.Try to turn on your console again. If removing and reattaching the faceplate did not solve the problem contact the xbox support.
Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
I have a JVC KD SH55 and won't eject CD. Fix please. Recall?
there is a ribbon wire that connects the faceplate contacts behind the faceplate that always go bad on all radios with rotating faceplates. you can probably find this part on ebay or on parts.com or by jvc.
Sep 08, 2009 | JVC KD-SH55 CD Player
Kenwood KDC-MPV 7019 code
Kenwood Code reset for KDC-MPV7019: (remote required)
1) Turn on the car.
MANUAL for the same radio
Jan 15, 2009 | Kenwood KDC-MPV7019 CD Player
Need to reset the code for a kenwood kdc-mpv7019
If You Have The Remote Here Is Your Solution.
1) Turn on the car.
Thank You For Using Fixya.com Please Don't Forget To Rate My Answer
Jan 08, 2009 | Kenwood KDC-MPV7019 CD Player
No display on faceplate unless I push on it
Three possible faults. Irst choice would be connector on radio you see when faceplate is removed may have some oxidation on pins. Sometimes with a small fine point file or dental pick you can try to scrape off any visible oxidation use caution not to bend any pins and be sure radio has no power . 2nd choice could be worn flex cable that connects to main p.c.b. and Third is chassis that keyboard connects to may be slightly bent causing a bad connection. I have a PDF service manual if you need it kstahl65@att.net
Jan 13, 2008 | JVC KD-AVX2 Car DVD Player
JVC KD-S570 CD Player Logo
154 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
