I have connected my new laptop to the EPSON 1710 projector and it wont give me a signal. I have checked the basics (connected cables between laptop and projector, the lens cap is off powe is on. I have another laptop right next to it and when I put the plug into that laptop it works. do I need to configure something
    Sergeant:
  • 183 Answers
You need to update your driver.
if you wanna be sure about it just disable your all drivers on Laptop and try plugging in.
thanks
Posted on Jan 09, 2009
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
HDMI
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
DVI
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
S-Video
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
Epson projector
check HDMI port, whether it is work well.by connecting another laptop.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Mar 01, 2014 | Office Equipment & Supplies
Cannot Connect My Compaq Presario CQ57 to my Epson Powerlite S4 LCD Projector! Help! Please?
The USB port in the projector is only for Optional Mouse to srcroll down the menu of the projector. Its not ment for the Video connectivity. You have to use 15 pin VGA cable to interconnect the PC and the projector then only you will get the video.
Here i have added the link for the user manual of the projector. Check out page number 30 of the manual.
Ajin
Feb 10, 2012 | Epson Office Equipment & Supplies
My Windows XP is connected to my Epson Powerlite S3, but the screen is blue with the words Source: Computer (Auto) No Signal on it. When I click "Help" on the projector, it takes me to a screen...
'No signal' and 'unsupported signal' messages mean 1 of 2 things, either the VGA output is off(laptop) or the display resolution is set too high(laptop and desktop). Assuming the VGA cable you are using is good, try this:
Desktop: hook the computer back up too your computer monitor & set the computer to the basic VGA resolution. For windows XP, right click a blank area on the desktop, click 'properties' on the dropdown menu, click settings. Write down the numbers in the 'screen resolution' and 'color quality' boxes!
Drag the 'screen resolution' all the way down to then 'less' side. Then change the 'color quality' to the lowest setting. Click apply, then answer yes (the display will look UGLY - don't worry!!) Now connect your computer back to your projector. If it works, then the resolution you use on your desktop monitor is not supported on your projector. Experiment with different resolutions to see which one looks best on your projector. You will need to change the settings each time you switch monitor to projector.
Laptop: by default the VGA connector on your laptop is off. To turn it on, look for a blue symbol on one of your function (F1, F2, F3...) keys. It looks like an old TV with a line on both sides 'O' (F4 on HP) Press & hold the blue button (on the lower left of the keyboard, usually to the left of control ) and tap the bleu button you just found. Let go & give you're a computer a few seconds to change over. If the laptop screen goes blank, you found the correct button! The display image should now be visible. Repeat this 1 to 2 times to change it back to laptop display.
If you did not see the display on the projector, 2 other issues are possible. First, verify that the VGA output on the laptop is working - connect the laptop to a regular computer monitor & change the display resolution to the lowest settings (see desktop above), then try it again on the projector. If you cannot get an image on a computer monitor, your laptop settings may need to be adjusted in the same dialogue box as the settings. Monitor #1 is the laptop display, Monitor #2 is the external output.
Happy viewing :)
Jun 12, 2011 | Epson PowerLite S3 Multimedia Projector
No signal on epson emp-x3 projector using susb cable
I'm assuming (because of the USB) that you wish to connect a computer to the projector.
You will need a VGA cable connected to the Computer input on the projector and the VGA output on your laptop.
If it is a laptop you may have to active the external monitor on your laptop. This is generally done by pressing the function key and F5. But this will depend on your Laptop and OS on the laptop. Look for a button amongst the F keys (at the top of the keyboard) that will do this on your laptop.
Mar 21, 2011 | Epson EMP-X3 LCD Projector
No signal from laptop even though it is connected I have attached an apple laptop to projector and no image from the computer is being shown I have pressed source and it says no signal. The computer is on...
this is going to be a bummer, but have tried to use another cable? to check if there is an issue with the cable try using another device that uses the same. if it works with it it may depend on the configuration of on your operating system which may vary
Oct 09, 2009 | Epson PowerLite® 83c LCD Projector
Projector giving green picture it is ok with RCA inputs ok with S video input but if i connect component connector like 15 pin vga from dvd player it gives green picture but with same cable if i connect pc...
I think, the issue might be because of lenght of the composite cable. Not all projectors can "recognize the signal" on too long composite cables, try a "standard size" cable used on monitors, it is i THINK 1,8 feet long...? Dunno. Try two short cables and see if you get "green" - if not, then your cable is too long and gives the signal to much "resistance", so your projector can "read" only one of the color channels, in your case green. If your projector setup requires long cables (and it usually does ;) ), you will have to stick to Cinch connectors and analog video signal, which I have tested on 35m long cable without any visible quality loss. Hope this helps. ;)
Feb 20, 2009 | HP Compaq nx7010 Notebook
Bad connection between laptop and lcd projector
First, check all plugs and make sure there are no broken or bent pins in them. If the projector you are using have a replacable cable try to replace it to see if the cable is the problem. (borrow a cable from a friend or relative first so you don't buy one if it is not needed.)
If that doesn't fix it, try to connect a different computer to your projector to see if that is better. If so, the output port on your computer may be bad.
Also try to hook your compuber to a different monitor to see if that works. If no computers are able to make a good picture on your monitor, the monitor is at fault.
The fact that you can change the picture quality by wiggling the cable, and that it starts to search for a signal suggests that the cable or the plugs are at fault, but having the wrong resolution set up on your computer may also affect the image quality. Again, try to use a different computer as a source to eliminate (or confirm) your computer being the problem.
Feb 19, 2008 | Compaq Presario 2140US Notebook
Lamp is on but not no signal from projector coming out !!!
i figured it out. open it up, and make sure the ribbon cables are securely plugged in.
May 01, 2007 | Epson PowerLite S1 Plus Multimedia...
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
