Question about Fuji FP-988D 19" Flat Panel LCD Monitor
Plugged speakers into wrong slot and the monitor went black and the tower started beeping. Monitor and the tower both have power
    Champion:
  • 293 Answers
Hi...there,
Oh...common...plugged to a wrong hole doesn't caused a black out...It's seems you got a busted backlight inverter....
Posted on Feb 22, 2009
The tower turns on but does not boot the monitor
There could be a problem with the connection to your monitor.
Dec 21, 2013 | Gateway ATXSTF MNT Pro S P4 1500 Tower...
No Beeps, Post, Nothing.
make sure the p4 power connector is plugged in. (4 wire yellow and black wires) plugs in near cpu. Remove and reinsert memory modules. That is were I would start.
Oct 18, 2013 | Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX...
Where do I connect the speakers to the monitor. I have a Flatron L1922P monitor. I ordered 2.0 USB Multimedia speakers that come with a 3.5mm stereo plug and USB plug. I must not being doing something...
Your speakers do not plug into your monitor. Your speakers should be connected to a USB slot on your PC tower and the 3.5mm stereo plug should be put into the green stereo jack on your PC tower. If your audio jacks on your PC are not colour coded, then you should look for the jack which has a picture of a set of earphones over them.
Depending on your speakers, you may or may not be required to keep the stereo plug connected in order to get sound. Some models transmit model over the USB connection and others just use the USB connection as a way to supply power to the speakers and need the stereo plug to be connected in order to have sound. I suggest trying both.
Mar 25, 2011 | LG L1922P 19" LCD Monitor
Desktop: Gateway LX6810-01 PC will not power on. When I hit the Power button on the tower, a long continuous BEEP comes on and nothing appears on the monitor. After the BEEP, the On light (on tower)...
Thank you for using FixYa
I would try shutting down the computer in the normal way, and turning off the monitor.
Boot up and turn the monitor back on.
If it still doesn't work, then I would check the cables and power plugs and wall plugs.
Check the mouse and keyboard cable and any other cables plugged into the computer.
The next step requires a seperate monitor or laptop.
Try unplugging the monitor and pluging in another monitor. Most laptops have a common
VGA adaptor jack or even an Svideo jack.
If the other monitor does not work, Then take to a qualified technician for repair.
It could be your power supply in the computer or video controller.
I hope this was useful and please comment if this was helpful to you.
Mar 24, 2011 | Computers & Internet
Desktop monitor went black & and wil not power up
Try the fuse on the monitor power cord, and if this does not cure, you will have to get another monitor....pretty good prices on ebay!
Jan 04, 2010 | Computers & Internet
Desktop PC monitor suddenly went black & power light went off
1 either ur VGA card is corrupted or
2 RAM is corrupted
3 Last may be your motherboard is gone - not sure
Monitor comes up shows "acer" then says no signal and goes black
The interface between the monitor and the cable might need replacement. Please check it.
Jan 12, 2009 | Acer AL2016 W 20" TFT LCD Monitor
I started my HP computer today and it starting beeping, the tower and monitor have power to them, but the display isn't showing up on the monitor, it's just black
You need to open the tower and reset the memory sticks still if you get those beeps then try those memory stick one by one or swap the memory stick
Regards
Samson Ved
Dec 03, 2008 | HP Pavilion xl756 (P1358A#888) PC Desktop
My computer crashed and now the monitor goes into power save mode
You said that you hear a series of beeps, if you hear this kind of sounds maybe there is a loose connection from the CPU. Try to remove the Memory and put it back again.
Mon =)
Nov 15, 2007 | IBM IntelliStation M Pro 6219 PC Desktop
Fuji FP-988D 19" Flat Panel LCD Monitor Logo
50 people viewed this question
Top Fuji Computers & Internet Experts
Computer Links
Victorman
Victorman
robert
Are you a Fuji Computer and Internet Expert? Answer questions, earn points and help others
