Question about Bravetti KC271H Slow Cooker
Temperature This is my second slow cooker as I wanted another one for the cottage. I had to change it twice at the store as it does not heat enough. After 8 hours, vegetables are still crunchy. Guess what ? my third one has the same problem. The store refuses to give me my money back. Any suggestion ? (beside buying a Rival ?) Thanks !
    Genius:
  • 1,074 Answers
Check the current into your cottage.you could be getting low voltage inside.if the voltage is good change the model you are buying.good luck.
Posted on Jun 04, 2007
SOURCE:
Della 12 Quart 1600-Watt Electric Pressure Cooker Multi-Functional Timer Slow Cook XL Part number: 048-GM-48261 Unable to get this cooker to slow cook.
it is possible that you have misunderstood the instructions
for a slow cooker you have low medium and high
press slow cook and on low and in 8 hours the food is cooked
I see from your statements that you expect the cooker to be set on slow cook but cook at a high temperature fast
if it says slow cook --9 hours and the temp is 125 degrees , have you waited 9 hours to see if it is cooked as the slow cooking process is by the gradual build up of heat in the container that is not expelled by radiation to the air
in a pressure cooker , that build up of heat also builds up pressure and so it cooks better
other solution--- if it is not right return it for a warranty refund or if out of warranty , junk it and get a different make
Mar 25, 2017 | Crock Pots & Slow Cookers
On heat setting "low", how long before boiling starts? Assume water inside.
it may never boils on low setting that is not enough heat to BOIL guess that's why it's called SLOW cooker
Apr 14, 2015 | Sunbeam Crock Pots & Slow Cookers
Which will provide the lowest heat? low 10 hours or warm setting. Thanks
The WARM setting is the lowest heat. Here's a quote from the user manual:
"WARM is ONLY for keeping already cooked food at the perfect serving temperature. DO NOT cook on the WARM setting."
This is because at the WARM setting, the temperature doesn't get hot enough to kill food-borne bacteria.
Jan 18, 2011 | Rival 38601 Smart Pot 6-Quart
Can you boil in a slow cooker?
Generally, with enough heat and good insulation, water will boil. Boiling is caused by non-uniform heating - some spots are hotter.
My wife's slow cooker boils even on the low setting -slowly, but it boils.
Our rice cooker never used to boil until I burned tomato rice in it (OOPs). Don't make tomato rice in a rice cooker.
Mar 21, 2010 | Nutritionist 10 Cup Rice Cooker RA10NR
Use of an old slow cooker
NO!
it should say on the metal below the ceramic pot to not get it wet
slow cookers make enough heat to heat the contents of the ceramic pot.
Jan 10, 2010 | CorningWare SC60 Slow Cooker
Heat settings on enheat slow cookers
Generally, the lowest number is the lowest temperature setting and the highest number is the hottest temperature setting
Jan 02, 2010 | CorningWare SC60 Slow Cooker
What is the function of both the Auto and the High setting on the cooker?
I am not sure if it is the same as the Durabrand model I have but mine heats the food to boiling and then cooks and lowers the temperature automatically, it is handy if you are late preparing a meal, for example 12 noon and you want it ready for 7pm? Hope this helps. High settings usually boil quickly and is handy to use for the first hour after that reduce the temperature and you can knock at least an hour off the cooking time. Or you can use high throughout the meal and halve the slow cooking time, however this uses much more electricity than on slow.
Jan 22, 2008 | Michael Graves Slow Cooker (4 qt.)
WEST BEND SLOW COOKER
  1. The thermostat may temporarily lose calibration due to temperature changes resulting in an E01 error message on the display. Repeat the following steps to reset the unit.
  2. 1. Unplug the unit from the wall socket for approximately 10 seconds.
  3. 2. Plug the unit back into the wall socket.
  4. 3. Press the POWER button once. Within one second, press the COOK button once. The unit should now be rese
Dec 03, 2007 | West Bend 84496 6-Quart Slow Cooker
Crock Pots & Slow Cookers Logo
122 people viewed this question
Top Bravetti Crock Pots & Slow Cookers Experts
AZBen
AZBen
dave984
Level 1 Expert
Are you a Bravetti Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
