Question about Cameras
My camera is getting vibrate when i open the lens cover
My camera is getting vibrate every time when i open the lens cover and picture is not still when i shot. pls give me a solution asap..
    Champion:
  • 225 Answers
Sounds like the steady shot mechanism has went haywire.
Replace the whole lens assembly to repair it.
Posted on Jan 09, 2009
My olympus fe was dropped when the lens was closed, and everytime i turn it on the lens gets stuck out and makes a vibrating noise, than stops. sometimes it'll show me my pictures that i have on the camera...
Since a replacement is available for £46 on Amazon, and the repair charge would probably be at least that if not more, i should just replace it. And this time, don't drop it.
Jun 10, 2017 | Olympus FE-220 Digital Camera
My problem is im trying to record and i have the camera switched to tape and have it turned on to camera and it records sound but will not record picture, but will play back other tapes on the screen ok.I...
If the iris is opening to let light in, that light is not being changed to a picture signal or that picture signal is not
going into the camera circuits, What you see in the viewfinder is what is being recorded, Make sure that no cables have been left plugged in to the camera and turn the power on and off several times, I have seen the iris stick when cameras were not used for a while. The iris is inside or behind the lens and closes completely when you turn the camera off, If it is stuck, SOMETIMES it will open with repeated tries of turning it off and on or even removing the battery and putting it back in. And maybe it is just the vibration of opening and closing the battery compartment door or the slight vibrations of pushing the power button repeatedly. If it sticks once, it will stick again. This is not a repair, just a way to get those one time pictures' before.
Jan 08, 2018 | Canon ZR50MC Mini DV Digital Camcorder
My camera shakes (vibrates) very bad every time that i turn it on. it stops if i am looking at my already taken pictures but im not able to take any new ones because of it. how do i fix it?
It is possible that your shutter is not working and there are issues with the servo of the camera. When it is switched on the motor of the lens cover is vibrating as it is having a fault maybe a friction to move .
So a possible cleaning/service might rectify the fault , releasing a jammed shutter.
remove battery and replace after 30 minutes with a fully charged battery , while switching On tap the lens cover on your palm several times, might help sometimes.
Sep 26, 2010 | Cameras
Vibration after turning on
Make sure that the Battery is fully charged.
Check for the following steps:
  • Use the flash if the amount of light is insufficient.
  • Hold the camera steady with both hands
  • If the camera has an anti-blur feature, turn it on.
Please reset the Camera by selecting Initialize under Settings and Setup 1 Menu.
If the issue persists, your camera may require service.
Sep 21, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
When I open the lens cover camera vibrates non stop
if you alsow get vibrationOn Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
this was tested and worked on 2 additional cammeras
Aug 30, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
The lens cover will not open and close all the way.
to open them completely simply push them with your finger. try doing so also when closing them. i have the same issue sometimes.
Jul 13, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
When opening len cover I get display on monitor
I do not have a solution to this, but do share the same problem. This was my first digital camera and I was quite happy with the quality of the pictures until it stopped working. I have replaced the camera a long time ago, but wanted to give this little guy a second chance. I have tried to keep the lens open with a piece of tape, and am thinking of breaking it apart to see if I can remove the cover. Any ideas, anyone?
Jun 30, 2009 | Fuji FinePix 2600 Zoom Digital Camera
Turns off due to sliding lens cover
may need to replace the screws in the door or even tighten them up
Dec 30, 2008 | Olympus Camedia Stylus 300 Digital Camera
Cameras Logo
71 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
