Question about LaCie (301258U) 750 GB Network Storage Server
Replacing Drives Can I replace the internal drives with any ones bought from the local shops (any brand/size) or it has to be LaCie parts only. If the answer is any brand, how do I prepare and make it usable. Thanks
  • mterier Jan 09, 2009
    Does the drives needs to be prepared (partitioned/formated) before using. I have bought two new 1.5tb SEATGATE drives and when installed, the LaCie boots, then the rear leds turn blue and the front one is red. The LaCie habgs not accessible via network and power off doesn't work.
    When putting back the old drives, everything works!!!! and clue what could be wrong.
  • mterier Jan 11, 2009
    The LaCie was kept on for more than 20 hrs nothing is happening. The unit is set to "Big" and not "100 Safe" thus not RIAD is enabled. The rear LEDS are solid blue but the front one is solid red. Also the on/off button is not working, need to unplug the power to turn off.
    Sniper:
  • 62 Answers
You can use any brand or any size. It does not have to be a Lacie Brand Drive, but if you planning on using the RAID which makes an exact copy of one drive on the other drive in the server, you must pick two identical drives of the same brand and the same size. It can be any brand or size but both of the drives have to be identical. Otherwise, the RAID Will not work.
If you have any further questions, please let me know.
Posted on Jan 09, 2009
  • Logan Margulis Jan 09, 2009
    During RAID Synchronization
    Front LED – solid red
    Rear LEDs – Te LED corresponding to the original
    disk will be blinking blue and the one being synchro-
    nized is blinking red
    Once both disks are synchronized, their correspond-
    ing rear LED and the front LED will be solid blue.
    Turn on the drive with the new hard drives and let it run for a few hours. I believe the drives are going through raid synchronization. If they don't start working after a few hours and the rear and front LEDS both don't turn blue, let me know, and I will continue to research your issue.
LaCie 2big Triple - I replaced one drive, but capacity is wrong
Most likely the problem you are encountering is due to the RAID mode the device is set in. Most RAID arrays utilize multiple drives of the same size, or with drives of differing size, they just use a portion of the largest that matches the smallest drive. When the device rebuilt the array it partitioned off a portion of the 4tb drive of the same size as the existing 500gb drive. If you want to use full capacity of both drives you would need to use JBOD mode, which just strings the disks together into a storage pool using all available space. This won't offer the data redundancy of RAID1 or speed boost of RAID0, but should allow using full space.
Backup any vital data before doing anything, then look for a switch on the back. Rather than RAID0 or 1 the options may be labelled Safe or Fast, but JBOD is usually still labelled JBOD, or sometimes Big. You can try just flipping the switch to JBOD and seeing if it rebuilds to use all space. If that doesn't work you may need to remove the 4tb drive, connect it to a different system and erase it to get rid of the 500gb partition, then with the Lacie set to JBOD reinstall the 4tb drive so it will add its full size to the array.
The safest option though would be to buy another 4tb drive, backup all data and install both 4tb drives with the device set to RAID1/Safe. You would only get 4tb of total storage, but it would mirror the data on both drives so if one fails the other will still have your data. With JBOD you won't have any auto-backup. If a drive fails the data on it will be lost.
Jan 21, 2014 | LaCie 2big Network (2-disk RAID) (301257U)...
My external Lacie hard drive was in the upright position on desk and while i was moving it, it tip over (into flat position) on desk. There is now a clicking and beeping sound in the drive and the it's no...
traditional hard drives are sensitive devices and it is normal for them to fail even after such a shock. It is even recommended to not move a hard drive while it is spinning.
If you do not need the data on this drive, replacing the internal hard drive and then formatting with your operating system is all that you have to do.
If you need the data, you will need to bring the drive to a data recovery center, There is nothing you can try at home without taking the risk of negating any possible chance of recovering the data.
No matter the brand and type of storage device, it is recommended to always have a copy of important data on a different media.
Regards,
Jan 21, 2011 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
The power supply light comes on,but when i plug it the light goes out.how do i fix this problem .ty
when the green light on the power supply goes off or starts flashing when you plug it into the LaCie drive, there is a failure at the level of the internal electronic components. Either only on the interface, or on both the interface and one/both of the hard drive.
Usually, replacing the interface would solve this, but before doing so make sure that the internal hard drives electronic boards do not have any failure else they will cook your new interface. It is advised to consult someone skilled in electronics to inspect the internal components.
Regards,
Dec 31, 2010 | LaCie Big Disk 500 GB Hard Drive
Unit never revs up to 10,000 rpms it tries about four or five times then stops and gets a blue blinking light.lacie d2 quadra 500 gb
if the unit has the original hard drives inside (i never one with 10 000 rpm drives though), the problem might be caused by a power issue.
Please verify the power supply by plugging it into the wall then listening to it. It should be silent. If there is a high pitch noise or hissing, it is defective and needs to be replaced.
If replacing the defective power supply did not solve your issue or if the power supply did not have any issue at all, the internal components will need to be inspected.
If you replaced the internal drives with 10 000 RPM drives, it might be why the drives do not get enough power.
Regards,
Dec 31, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
My Lacie 500 GB big disk constantly has the flashing blue light. The drive dose not spin all the time, when it does is constantly clicks but does not mount. I use an iMac and a MacBook Pro and neither will...
Hard drive is no good. If new replace under warranty. Given the bad luck you have had with this brand, you might consider replacing it with a different unit.
Jun 19, 2017 | LaCie Big Disk 500 GB Hard Drive
I WANT TO OPEN THE LACIE 500 GB HDD AND USE THE HDD IN MY DESK TOP
Go for it. There's a chance the internal drive will be PATA (IDE) but odds are good it's a SATA drive with standard connections.
Make sure your PC has connections for SATA drives, and you'll need to buy a SATA cable since the one in the LaCIE case won't connect from your drive to your motherboard.
Sep 08, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Upgrade Possible?
Hey Al,
The internal Drive is a standard 3.5 inch IDE 7200RPM unit. you can indeed upgrade this to a 1TB drive as long as it's IDE wether 2.5 or 3.5. Luckily when Lacie was originally offering these drives you could get these in 1TB, so that won't be an issue.
Ciza
Oct 28, 2008 | LaCie (300770) 250 GB Hard Drive
Replacing the hard drive.
YES absoloutely. Diff Size, Make. There is NO difference to the PC.
Sep 02, 2008 | Maxtor OneTouch III Turbo Edition...
Samsung SD 616E Internal DVD
mmm! thats very strange! your drive could be damaged internally or have you checked all internal connections Ie: checked that the IDE or Sata cables are connected, By the way i will only recommend you do this if your technically minded.
you can do one of the following
1, have your system checked fully by a local engineer or
2, buy a new Drive if all other parts of your system is working
Dvd-roms / recorders are cheap enough now just to throw away and replace.
I can recomend a shop that i have personally been shopping with for the last 15 years and they really do know what they are talking about,
you can visit them at the shop if your local or shop on line, they even take Paypal as payment
Check em out HERE
ENJOY
May 01, 2008 | Samsung SD 616E (729507925578) Internal...
LaCie 1 TB Hard drive won't boot
I lave lots and lots of experience with LaCie Drives (I have 6 of the 2TB models). Every, every, every time a drive fails or runs slowly, it is the power supply. I have now replaced 5. They run very hot (so does the drive), and fail pretty often. It looks like the voltage drops just a smidge, and access times seem to increase, i.e., the drive "runs slow". Then it won't boot at all, and the blue light keeps blinking. Fortunately LaCie has replacement power supplies in the store. Buy a couple extra. I am married to the LaCie drives now, or I would probably switch brands. I kind of guess that they know about this because I contacted the help desk, and he wasn't surprised. Maxtor has a nice drive, and the Calvary drive is $150 cheaper. A drive is a drive I guess. By the way, if anyone is listening, how about building a QUIET, COOL drive with and INTERNAL POWER SUPPLY? GOT IT? All the cords and power supply bricks make me crazy. It might be nice to see a stackable drive where the top of one drive mates to the bottom of another, carrying network info as well as power to the drive above. Hint, hint. We all are building systems with ungodly amounts of storage. Too bad the manufacturers aren't building drives with the durability we need.
Oct 08, 2007 | LaCie (301074) 80 GB Hard Drive
LaCie (301258U) 750 GB Network Storage Server Logo
189 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
