Question about Canon PIXMA MP160 All-In-One InkJet Printer
MP160 will not print.
I added new colour cartridge, when i send picture to print it won't i get a staus error. It will not print a test page but paper still gets thread through. I tried scanning and that works. How can i fix this?
  • 3 more comments
  • liz_8225 Jan 09, 2009
    Where do i find that status error cause all i can see is status-error no code number, Where do i find this?
    I have got it to print but now the problem is the colour is very dull how do i adjust it?
  • Logan Margulis May 11, 2010
    I know this might seem like a dumb questinos, but have you removed the tape that covered the ink nozzles on the cartridges when you unpackaged them?
    Can you please tell me what the exact status error is? For example, a status error would be "e4". This will help me further investigate your printing issue.
    Sniper:
  • 62 Answers
I recommend print heading cleaning which is an option on your printer. The instructions on how to clean your print heads are given at this link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13368
IF this does not solve your problem, please let me know.
Posted on Jan 09, 2009
I have a four in one Lexmark x5630 printer and have replaced cartridges with brand new black and colour 36 & 37xl. The printer won't even print a test page - just says that cartridge error co
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Try to contact the store where you bought the new cartridge(s) and have them replace it. You may also contact Lexmark Technical Support Center for assistance (especially if you're using genuine cartridges).
Feb 14, 2012 | Lexmark Office Equipment & Supplies
The black ink on my Brother DCP-130C won't print and it's a brand new ink cartridge. I thought it was a defected cartridge so I bought another one, same thing. The other 3 colours print ok though....
I have the same problem. Everything on the printer is working just fine. It'll do a test page just fine, so everything's working right. The %$^ thing just won't print. It makes noise like it's printing when you give it a print job, but it spits out blank pages.
Sep 08, 2011 | Brother DCP-130C InkJet Printer
Ink is printing streaky, but this is my second brand new ink cartridge. Any suggestions?
this symptom signals blocked printhead, you need to do bit of cleaning, not necessarily cahnge the cartridge.
follow this procedure:
1. download test page with alternative from this site black:
http://www.inkjetcartridges.com/_black-print-test.html
and colour:
http://www.inkjetcartridges.com/_color-print-test.html
2. print page each and assess the colour and streaks. if on the beginnig of the page you do have errors and on the bottom all is corrected, this meant that you just cleaned your printhead nozzles and problem is solved.
3, if problem persist, from stationery store purchase few pages of absorbent paper, weight of about 120 to 160, do not use thicker than 160 and print these colour pages again,
4. print control page again and see if any improvement was made, if there were no changes, follow this procedure:
a. remove cartridges from craddle
b. determine what is ink solvent, water, isopropyl alcohol or methylated alcohol - correct solvent will be that which do not precipitate or curdle the ink
c. touch with absorbent tissuebottom of the cartridge and check if it is leaving even print, if not, whipe once with solvent
d. put a drop of solvent on gold/silver buttons inside of the craddle, allow to sink for about a minute, whipe off with absorbent tissue
e. put again a drop of solvent on the button in the craddle and insert ink cartridge
f. print test page, page will be very weak on the top (solvent print first!) and improve as it prints down, if necessary, print again colour or black test page from 1.
this should solve your streaking head problems, if they still persist, this meant that print heads are really well blocked by caked ink and usually is cheaper to change printer than change the head in it...
if you find this advice useful, please do not hesitate to leafe your feedback and vote for me, thanx!
Jul 31, 2010 | Canon PIXMA MP470 All-in-One Printer
Canon mp160 how to clean
- Remove all cartridges (Black & colours) & very gently clean the contact with clean tissue paper
- Clean print heads with wetted tissue paper making sure you remove the obvious 'mess'
- Re-assemble & test
Dec 29, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My printer will not accept a new black cartridge.
ITS NOT THE BLACK CARTRIDGE!!! Try changing the colour cartridge and see what happens. When a 9600 checks ink levels it does the black ink first, then the colour, if the colour is low it goes back and checks the black again but will constantly give an error message for the black cartridge. Sounds bizarre but try just the black cartridge in with no colour. print a test page in black only, if that does not print then it is a fault. Also make sure the driver is updated!!!
Feb 16, 2009 | HP DeskJet 9650 InkJet Printer
Have changed Ink Black and Colour... Stil getting error Message.
Make sure the tape covering the hole on the bottom of the black cartridge is removed. and then go into the printers folder and right click on your printer icon and go into the properties of that printer and there should be something in there to tell it that you changed cartridges and you can also print a test page as well.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
E 2 and service error 5100 on Pixma mp160 printer
You can try to clean out the printer check to see if there is any paper jammed in it somewhere
Then realighn the printer cartridges and run a test page.
Make sure that the paper tray is not overloaded
Dec 24, 2008 | Canon PIXMA MP160 All-In-One Printer
Canon pixima mp140 error code E4
following error codes i found
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
Apr 24, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
