HP LaserJet 4p Printer Logo
Anonymous Posted on Jan 09, 2009
How do you replace the fan on HP LaserJet 4P
Unable to get the cover off.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 09, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
210
Points
Removed cover - found foam filter was hitting fan blade causing an error code of 58 to appear.
How do I find the scanner unit, hp4mv
usually found just under top cover.
HP 4P band of grey on left side of the printed page. What should be done? change toner?
hi
very simple
Use the following troubleshooting steps to resolve this issue:
  1. The print cartridge is almost empty. Shake the cartridge gently to redistribute the toner, or replace the print cartridge.
  2. The print cartridge may be damaged. Replace the print cartridge.
  3. The printer's internal mirror may be dirty. Lift the print cartridge access cover, remove the brush from the underside of the cover, and clean off the mirror using the brush.
  4. use p/n 92274A for toner replacement
please issue 4 thumbs up
thanks for using FIXYA
Right side of page printing is broken up
Open the back cover and check out the fuser rollers
Just got a new computer. Have an old HP Laserjet
you have to refer to usb/ parallel converter manual, not printer manual
Need help fixing a HP Laserjet 4P printer. Makes
Check this link for printer parts:
http://www.printersupplies.com
1helpful
I have a HP laserjet 4P. The print was coming out
You need to replace your transfer roller. Might as well do a complete maintenance kit.(Rollers, Fuser and Transfer Roller)
HPLaserjet4P - printer service 50 -
A 50 Service error is a fuser error. Turn the printer off for 5 to 10 minutes, then turn it back on. If the error is still there, I think your going to need to make a service call you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
Good Luck the HP Laserjet 4p is a great printer.
Windows vista does not seem to recognize HP 4P printer
WOW!? HP4P... I don't think you'll find a Vista Driver for that printer.
Try www.hp.com in the downloads section.
Good luck from a crusty old HP Printer Tech.
Paper Qualty
Did you forget to take the small piece of tape off of the cartridge? Also, make sure the cover is latched all the way (sometimes you have to give it a good "slam".
Hp 4p printer related problem
Error 51 (beam detect error) Trouble shooting suggestions: Check seating on laser/scanner assembly Replace scanner assembly
k24674
Grand Canyon Tech
Grand Canyon Tech
