Question about Alpine CDA-9853 CD Player
Turning the bass level down
Could anyone tell if there is a setting which ables the unit to turn the bass level of the speakers down so that they dont distort as much at higher volumes
  • briimarie Apr 13, 2008
    i am having the same problem, i cant find an option for changing the bass leveles, anyone know any solutions?
    President:
  • 3,130 Answers
I could not find an owners manual for the CDA-9853, but I did find one close to it and it should be able to guide you to where the bass and treble levels are It is the CDA-9820. here is where you can download it from for free: http://www.alpine-usa.com/images/products/product_downloads_pdf/cda-9820xm_ptg.pdf Good Luck
Posted on Jun 04, 2007
I have a system installed and i have mtx speakers plus mtx subwoofers i want to know how could i take the bass of the speakers because it sounds horrible when loud
if you turn the bass setting in your radio down it will take the bass out, but may take some of the bass out of the subs as well, if this occurs and you still are not satified, you either have to get a car receiver with a non fading subwoofer preout, or you could get bass blockers for all the speakers you dont want the bass in
Apr 05, 2012 | MTX Car Audio & Video
Can I hook two 12in. Subs up with a 1100w amp. Sony explode, pioneer subs
Yes....hook one up to the left channel and one up to the right.....once everything is wired up.....keep gain down on amp and turn stereo on.....turn up stereo with amp gain down to right before high end speakers start to distort......then while its playing, turn amp gain up about 1/2 way. close your trunk and hop in drivers seat....sound gd????? You might have to adjust level on amp and bass on head unit to taste.....Be careful though....pioneer subs are only rated around 300 watts continuous.....dont want to blow them...gd luck....
Mar 20, 2012 | Pioneer Car Audio & Video
What are good settings to have to make the music sound clear for a jvc KD-R310 deck?
you will need to access the bass and treble setting on the unit.
If you have stnadard speaker then dont put the bass to high as you can not turn the volume up high.
The same for the treble.
Set them at about the same and turn the volume up until it sounds good.
If it is to quiet then turn the treble and bass down and then the volume up more
Mar 02, 2011 | JVC AM FM CD DET FACE CAR STEREO
White Noise and Speaker distortion 2002 BMW 3 Series
If bass control and/or equalizer is set normally then the issue lies with the unit's amps. Go to link for replacement Crutchfield Car Stereo Speakers Home Theater Pro Audio 4k TV
Aug 25, 2017 | 2002 BMW 7 Series
I have a Boss OL5KD Class D Monoblock Amplifier and I set it up but is no sound coming up from the speakers, can anyone tell me how to higher the volumen? where is located the volumen??I need to higher the...
Hello maydude01,
The Boss OL5KD does not have a volume control. It has an "Input Level" adjustment which is used to match the output from your head unit preamp output to the amp. It is the first rotary control just to the right of the input jacks.
If you have no sound at all, I'd suspect that something is incorrectly connected or there is no input to the amp. First make sure that the amp power light (green LED) is coming on when you turn on the receiver and that the protection light (red LED) stays off. Then check all of your wiring, especially the RCA output cables.
Initially set the controls like this: MASTER/SLAVE switch in MASTER position (left). INPUT SENSITIVITY 2v-8v (right). INPUT LEVEL, SUBSONIC FILTER, BASS BOOST, and LOW PASS FILTER; midrange. PHASE SHIFT "0" (left). Leave the remote level control disconnected.
After you've checked all wiring and initially set the switches and controls, turn the receiver on to about 3/4 volume. Now adjust the INPUT LEVEL to the left just until you begin to hear distortion, then turn it back right just a little. Adjust the other controls for best sound. Plug in the remote level control and make sure that it adjusts the bass up and down. You're finished!
If there's still no output from the unit after checking all of the wiring, either the unit is defective, it's not getting an input from the receiver, or the sub(s) are defective.
Hope this helps.
Aug 14, 2009 | Boss Car Audio & Video
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
My tv is making a poping noise. I unpluged the set from the radio but the sound is coming from the speakers on the unit. What is it, and how can it be fixed. Thank you Bryce,
Turn down bass in audio menu or if tv has subwoofer turn down sub level or like i stated earlier turn down bass other than that popping noise is a common complaint with vizio, if under warranty call service provider
c
Sep 29, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
SPEAKERS CUTTIN OFF
trying to push to much bass here try this turn the head unit half way up and then go back to amp and turn the level nob all the way down and then turn it up to u hear it start to cut out let me no if that helps please rate if u have any more q and a's let me no
Sep 26, 2008 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Low treble
I suspect that the speaker levels need to be set. You connected everything right - many people would not have connected the sats via the bass section (which has their high pass crossover and overload protection). But I am betting the HSU is turned up a bit on the high side.
Try this. Set all speakers to small, set all levels to 0. Play the receiver in stereo all mode. If the bass is strong, you need to turn the HSU down closer to a natural sound. Then use the speaker setup tone and adjust as needed.
May 14, 2008 | Onkyo TX-SR304 Receiver
Subwoofer Trouble
Turn the bass gain all the way down., Turn up your your volume on bass test song. Crank up the little box next to the steering wheel wide open . Now go gradually turn up the bass gain on the RF amp until you get distortion. Turn the gain down slightly. Now you can enjoy playing the bass from one end of the little boxes setting to the other without ovrloading your amp and subs. Open a can of whoopass on anyone who tries to crank up on your gain.
Nov 09, 2007 | Car Audio & Video
Alpine CDA-9853 CD Player Logo
254 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
