Question about Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator
Fishe & Paykel fridge drain electricity cause power serge
I have a F & P fidge < 5 years old (freezer at the bottom) . The fridge is draining power and cuase intermittent power surge which result in the electricity circle break and power supply failure.
I am unsure whether this is related to the compressor or the motor. Should I get a new fridge or this could be a simple problem which could be ratified by a qualified repeairer?
The fridge is generally working fine apart from draing electricity and cuase circle break.
    Scholar:
  • 67 Answers
Heya Helen,
On the old F n P fridges they use to use a 12v motor that was open shaft, there fore it wouldnt have a earth on it. Althou it can still over current. In lame mans turns I would say that it would be the compressor.
In terms of replacement, a new compressor in generally a third of what a new fridge cost. It would be a good idea if you didnt have the money for a new fridge but on that you dont get a warrenty. If you could get a domestic refrig tech out he would be able to quote on repairs.
Hope that helps
Posted on Jan 09, 2009
The strip down the middle between the the fidge and freezer doors is getting hot. So hot that it burns when you touch it. The sides of the fridge are also getting pretty not. I have just bought the fridge...
I have exactly the same problem with my Westinghouse side by side! And it only happens when it's hot in the house. Would love to hear what's wrong. And the fridge is 5 years old. Bought new.
Jan 12, 2011 | Westinghouse Refrigerators
My frigidaire refrigerator is leaking from the bottom of the freezer compartment.
usually the most common problem is the drain tube is plugged. This tube runs from the bottom of he fzr thru the fridge compartment to the underside of the fidge to a drain pan. First try to blow air from the bottom of the line. Second ck where the drain enters the Fridge from the freezer this is a very common area for this problem. good luck
Aug 13, 2010 | Frigidaire Refrigerators
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
Leaking water inside fridge
With mine I turned it off for 24 hours until totally defrosted. Checked behind the panel of the freezer and removed one stubborn piece of ice. When I restared the fridge it was all good. I have this problem when we have had a lot of humid weather.
Feb 22, 2009 | Fisher and Paykel Active Smart E522B...
My fidge wont cool down
Most likely a defrost problem..check the defrost thermostat, timer, heater, fan... if the fan in the freezer compartment running?? sometimes ice will form in the vents...check the easiest things first ..like the vents and drain tubes,,
Aug 20, 2008 | Refrigerators
Fidge is icing up inside on the rear
Defrost problem, advance into defrost to see if heater comes. If it does replaced timer, if it doesnt you will need to check heater and defrost thermostat.
Jan 07, 2008 | GE GBS22HCP Bottom Freezer Refrigerator
Hotpoint future RFA60 Fidge Freezer
I have lost the instruction booklet for my Fridge Freezer RFA60. How do I defrost the freezer?
Nov 04, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Digital Tempeture numbers off
Those control boards are sort of flakey and any kind of power surge, etc. can really goof them up. If you check under the very bottom of the fridge there should be a technical sheet taped up to the underside in a plastic bag. Take that out and read it to see if there is a test reset you can do before replacing the board.
Jan 03, 2007 | LG LRBN22514 Bottom Freezer Refrigerator
Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator Logo
241 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
