Question about Whirlpool MH1141XM Microwave Oven
MH1170XSB - Bottom 3 Buttons on Keyboard Pad No Longer Work
The bottom three buttons on the Keyboard Pad (Light, Fan, etc) no longer work. What could be the problem? IMy questions are:
1) If needed, what is the cost of replacing the pad?
2) Is it something I could do myself?
3) Is it a cost effective on a 2 year old unit?
  • Whirlpool Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is not the keypad, but on the control panel (circuit board), which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 09, 2009
GE SPACEMAKER MICROWAVE OVEN MODEL J VM64 003 LIGHT SWITCH BROKE HOW DO I REPLACE IT?
Unfortunately it appears none of these parts are avail anymore. The physical buttons, key panel assy, touch pad support are no longer available. The smart board (WB27X5239) seems to floating around, but this does not appear to contain either of the 2 buttons or switches as part of it's assembly. Pleazer Appliance..
Jan 11, 2015 | GE Microwave Ovens
Work light and fan stopped working
sounds as if your touch pad ,and,or the circut boaed it's connected to is going bad.
Nov 08, 2013 | Kenmore Microwave Ovens
The top quick access buttons stopped working 2 days ago. The bottom buttons still work but, we can't punch in a custom time. The only thing that will work is the 1 for 1 minute 2 for 2 minute...etc.
One of two things is happening, either you have broken connections in the membrane switches of the keypad and should replace the keypad(which is most likely) or your main control board has failed in a way that it can no longer read signals sent by the keypad.
Aug 04, 2013 | Microwave Ovens
Our sharp r520lw just quit working, timer works, light works, all buttons work, (clear, etc) however turntable doesn't work and no
That would be a bad bottom door switch or its mount.
See the help file on door switches here.
See the service manual here.
Dec 13, 2011 | Sharp R-520LW Microwave Oven
GE spacemaker HVM1540DNWW. After I cleaned touchscreen the buttons don't work anymore. i unplugged it for a while, still only get "press clock" message
Take a hair dryer in low / no heat setting or a plain old fan and let it blow on the keypad for a while. Do not let the key pad get overly warm. You got a bit of moisture in the pad membrane and the goal here is to evaporate the moisture. It may take longer than you think to evaporate the moisture. If you let the moisture stay in the membrane too long it will cause corrosion and the key pad will NOT be usable.
Apr 22, 2010 | GE Spacemaker JVM1540 Microwave Oven
GE model JVM5503 (1980): light and exhaust fan work, but touch pad does not respond to pressing buttons and therefore no functions can be initiated.
That would be a problem with your "touch control" but it is no longer available.
The oven will have to be replaced.
Sounds like it had a good run.
Jan 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Button panel does not work or it starts making 'pick-pick' noise
The touch pad seems faulty, there may be moisture behing the first touch pad film, suggest replacing touch pad as it cannot be fixed, Phil
May 18, 2009 | Sanyo EM-S9515W Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Whirlpool MH1141XM Microwave Oven Logo
159 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
