Question about Maytag MDE6000 Dryer
Dryer Maytag mde6000ayw
Burn smell just started open door to smell then tried to start the dryier again could it be a breaker or the belt.
  • 164 Answers
SOURCE: black soot in dryer
it sounds like something might have ignited in the dryer, something small. you need to remove the front of the dryer and then the front bulkhead. This will expose the motor, you will be able to see the impeller blades and clean anything stuck in there. I would reove the motor so i could clean out the exhaust tube. Look over by the burner area to see if any burnt material is there that needs to be cleaned. That should do it
Posted on Jun 29, 2007
  • 77 Answers
i would start by checking the power to the dryer there should be 110 volts ac from common to L1 and 110 volts ac from common to L2 and 220 from L1 to L2. If you are not familiar with either AC current or a volt meter call a tech. if that is good there is often a high temp safty thermostat some where on the unit. if it doesnt read continuity on your ohm meter than replace the safty thermistat. how ever there is usualy anohter underlying issue. check your venting and make sure it is clear. that is the most common reason for a safty thermo to fail. hope this helps
Posted on Sep 25, 2007
  • 16 Answers
SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Posted on Mar 30, 2008
  • 14 Answers
SOURCE: Maytag Neptune dryer won't start/
I do not have that specific dryer but try these simple steps.
Maybe they will help you.
1. Shut the electric breaker off to the dryer for about 30 seconds and and back on.
2. Open the dryer door and inspect the switch that tells the dryer the door is closed. work it by hand just to make sure it is not stuck.
3. Spin the timer controls to another setting and see if the other setting will work.
That's all I've got for now...
Posted on May 20, 2009
  • 1723 Answers
SOURCE: How do I remove the front panel on a Maytag
Remove the two screws holding the lint filter in. Then slip a putty knife in the top edge and pry up and the top will lift up. You may have to take out a couple screws on the control panel too, not sure
Posted on Jul 09, 2009
Won't Spin Drum
The problem could be a list of things . Let's start checking the belt , it coul be that the belt is broken or something is keeping it from doing its job ( a piece of clothing coul be stuck) due to the burned rubber smell you detected. It coul also be the electrical door switch and After checking the three first steps then comes the motor part lets hope is not . Good luck
Nov 20, 2013 | Maytag Centennial Series MEDC300XW
My dryer stop working, it made a big noise and is not spining anymore, ts sounds as if it is out of place or something, and after 3 minutes it starts smelling like burn My dryer is a Maytag...
Feb 20, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
My maytag dryer model LDE7304ADE stopped working. I stopped it mid-way through, closed the door, pushed the "on" button and it made a weird noise. I tried again and now it doesn't make any...
Door switch broke???
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Oct 27, 2010 | Maytag Dryers
My 7-year old Maytag MDE6000AYW drier will not start when I push the start button. It has been making a buzzing sound before starting for quite awhile. Today it died with a click followed by an...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Sounds like the motor has gone bad...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Aug 16, 2010 | Maytag MDE6000 Dryer
My kenmore 86161100 wont start. the breaker was 1/2 tripped and i smelled a burning. I reseated the breaker, ran the dryer, it low growled and i smelled the burn again. What part do i need? Motor? Belt?...
sounds like the motor bearings are beginning to seize up from heat/age or the combination of both,remove the front and top cover to remove the drum if there is no access in the rear to remove the belt off the motor so you can start the dryer or free wheel the motor by hand and see if it is beginning to turn hard
Aug 04, 2010 | Dryers
Press start button and dryer will start and stop , if you press start button again nothing happens , if you unplug dryer and plug back in it will try to start again and stop
Howdy: The motor could be popping it's breaker once the start button is pushed. When unpluged the motor resets and the cycle starts over. But also the dryer thinks the element is too hot and resets the safety switch. The temp thermistor (overtemp sensor) could be clogged with lint or open circuit. Not easy to diagnost. Do you smell burnt wires or lint? Check to be sure the door is completely closed. It may think the door is open and not start. Doug
Dec 09, 2009 | Maytag Dryers
Dryier does not Start
If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it.
A thermal fuse is a heat-sensitive fuse attached to your dryer's exhaust duct (in most models) that is designed to blow if the dryer overheats. A blown fuse would cause your dryer to not heat, or to not work at all. Open up your dryer's cabinet and locate its thermal fuse. Test the component. If it has blown, replace it.
Jul 21, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag dryer MDE6000AYW keeps blowing the fuse in the panel box, what is wrong? I reset the fuse in the panel box and turn the dryer right back on and it will start right back up. It may or may not blow...
Bad breaker in the panel box.Loose wires at the breaker. Loose connection in the wall outlet. Loose connection at the dryer cord terminal. Bad cord.
One or more of the above.
Jul 05, 2009 | Maytag MDE6000 Dryer
Hoover HDC7FM condensor dryer starts then cuts out
Open the dryer door (right after the breaker trips) and check for a burned smell. If it smells in the dryer, you probably have a direct short in the dryer wiring. Check for a burn smell at the wall socket. There may be a short in the socket itself, but not likely unless a mouse is lying across the contacts in the wall.
If everything checks ok replace the circuit breaker if this is an older home. Circuit breakers weaken after years of use. A 30 amp circuit breaker will trip at a much lower amperage after a period of years especially if it has tripped often.
Mar 12, 2009 | Hoover HDC7FM Dryer
It sounds like your belt is starting to go out. You might google the repair forums or check this site out.
Oct 29, 2008 | Dryers
Dryers Logo
592 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
