Question about Symantec WinFax Pro for PC
Cannot close controller to allow re-install of winfax pro 10.02
Was constructing docs in word perfect program while winfax 10.02 was faxing apprx 500 messages. normal activity and usual daily usage. experienced problems in WP, i.e. could not copy one file to another. rebooting frequently fixes problems like this, however, could not stop winfax from faxing in order to reboot. ctrl alt delete did not work. went to control panel to remove winfax prior to a reinstall. deleted symantec from windows explorer. add/delete function would not remove winfax pro while controller was active but asked if I wanted computer to remove controller. replied yes but computer unsuccessful, screen returned to populated list of programs. shut down computer, rebooted via power switch but controller automatically came back on. winfax screen is blank and message at top says "not responding". buttons at top do not work. winfax pro is default printer and is so indicated in printer section. as a troubleshoot tried to fax a doc from WP, but message says "winfax is not active for this user account. please start the crontroller and try again". yellow fax machine icon shows at bottom right when computer is turned on, however, shadow behind icon--indicating auto receive is on--is NOT present. message says auto receive is off. checked windows, winfax phonebooks still present and the muffled sounds from computer tell me it is faxing as I am writing this email. perhaps when it is finished faxing in about 4 hours--and the controller is inactive--I'll be able to straighten things out. until then, what is your evaluation? Thanks you. Mark A.
  • 143 Answers
Control-Alt-Del and end tasks Wfxctl32.exe, wfxsvc.exe , wfxmod32 ...and faxmng32.exe
This can be any number of problems, like corrupt logs, too many entries in your default log structure,. You can check this link regarding rebuilding your logs:;CODE=01;HID=30
WinFax Tools has many fixes for WinFax that are automated.;f=17;t=412
Posted on May 29, 2009
Have re-installed WinFax Pro 10.03. At every system start up WinFax install program appears even though it's installed. Also when I attempt to Insert file from Word 2003 in the fax, I get an error message...
Goto "Start" in windows select "RUN" type in "MSCONFIG" press ENTER, Select "STARTUP" tab uncheck the winfax then select apply then OK. Now restart your PC, u should not get this problem now.
May 24, 2010 | Symantec WinFax Pro for PC
How to link to outloo kexpress address book
In the WinFax PRO Program Setup, double-click Email and Outlook Integration.
Check "Enable sending faxes by email," and select Outlook Express from the drop-down list.
Click Apply, and click OK. A dialog box appears, notifying you to restart the controller so that the changes will take effect.
Click OK, and click Close.
Right-click the Controller, and click Exit.
Restart the Controller or Message Manager to finalize the integration.
In Message Manager, click Tools, and click External Phonebook Autolink.
Check Outlook Express, and click OK.
Click Next, and click Set Information.
Verify the Outlook Express Information, and click OK.
Click Finish. Outlook Express will now show as a phonebook in WinFax PRO.
Aug 15, 2009 | Symantec Winfax Pro 10.03 (winfax10.03)...
WinFax Pro 10.03 user Manual
The Symantec site has the user guide listed, but the PDF link doesn't work. Here's the Winfax Pro 10 User Guide:
May 13, 2009 | Symantec Winfax Pro 10.03 (winfax10.03)...
Outlook and Winfax integration
what version of winfax are you using? what version of outlook?
Controller is the icon that appears in your system tray
May 15, 2008 | Symantec WinFax Pro for PC
Program Setup in Winfax 10.03
I posted a probable solution for this under a user named Floopstick.
Check that out. But if you only need to fax once in a while Faxzero is free. You would need to scan in your data if you are not creating it on your machine. Tango.
Dec 15, 2007 | Symantec WinFax Pro for PC
Receiving Fax Line always 'busy'
Installing fax software can be tricky, particularly if you want to import phone-book listings from an existing database or PIM, such as Microsoft Outlook. But WinFax Pro proves easy to configure. A series of introductory screens walks you through installation; you just click Next to accept the default configuration. In our tests, WinFax Pro accurately detected our fax modem and seamlessly imported our contacts from Microsoft Outlook. By comparison, competing fax programs either don't import directly from Outlook or make the process trickier than it needs to be. you can try to look on website and there will explain to you.
May 28, 2007 | Symantec WinFax Pro 10.0 for PC
Winfax pro problem
This is a solution that was suggested for an earlier edition of the Winfax Pro, but there is no reason why it shouldn?t work on this one as well: 1. Close Winfax and any other program that has anything to do with it, delete all the temp files that yo don?t need. 2. Run Scandisk and fix any problems that may come up. 3. Run delfix.exe which is located in the winfax folder in the status files. 4. Run delfix-rebuild and delfix-optimize and check if the problem is solved. If the problem reoccurs there is another possibility- to change the name of the WinFax\data folder and create a new one which you will transfer the address book file, status files etc. from the old folder. Note that there might be some information that wouldn?t go through.
Feb 22, 2006 | Symantec WinFax Pro for PC
Symantec WinFax Pro for PC Logo
692 people viewed this question
Top Symantec Computers & Internet Experts
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
