Just add brake fluid as a start. See how long it takes before the light comes on again. Secondly check your brake cylinders for leaks. Lastly but extremely important when was the last time you changed the brakes? Check those brake pads and if you need to change them then do so. Then after changing add brake fluid as required.
It
can be issue with master cylinder or the problem is there is still some air
there in the system,that has to be bleed.Or else the parts replaced are not
aligned properly/.I suggest everything back. There
are few help links mentioned below to troubleshoot the issue. Click
the link below and follow its procedure:----- http://schematicsdiagram.blogspot.in/2012/06/2002-ford-windstar-brake-warning-light.html ----------- Battery and brake Warning lights on
Dash ---------- ----------- ---------- ------------ ------------- ----------- ------------- ---------- --------- ---------- ------------ http://whoisbyme.blogspot.in/2012/06/fading-sinking-brake-pedal.html ------------- ------------- ------------ http://howtobyme.blogspot.com/2011/11/abs-light-stays-on-but-brakes-work-fine.html ----------- ----------- ------------ ----------- ---------- ----------- ------------ ----------- ---------- --------- --------- http://technoanswers.blogspot.in/2012/06/toyota-tundra-parts-diagram-to-replace.html http://technoanswers.blogspot.in/2012/02/squeak-and-grinding-sound-is-heard-when.html ------------ Brake Pads Inspection on Acura
Integra? http://repairhelpcenter.blogspot.in/2011/11/brake-pads-inspection-on-acura-integra.html
------------- How to remove Brake Pads on Acura
Integra? http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-brake-pads-on-acura.html -------------- How to remove Brake Disc Rotor on
Acura Integra? http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-brake-disc-rotor-on-acura.html ------------ Brake Caliper OVERHAUL on Acura
Integra? http://repairhelpcenter.blogspot.in/2011/11/brake-caliper-overhaul-on-acura-integra.html ------------ How to remove Brake Caliper on Acura
Integra? http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-brake-caliper-on-acura.html ------------ How to remove Parking Brake shoes on
Acura Integra? http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-parking-brake-shoes-on.html ----------- How to remove Parking Brake Cable on
Acura Integra? http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-parking-brake-cable-on.html ------------- ---------- These details will help.
2002 Ford Windstar: Brake Warning
Light ON dash?
http://alltypesofpartsreplacing.blogspot.com/2012/10/battery-and-brake-warning-lights-on-dash.html
ABS & Brake warning lights remains steady
on dash?
http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
Brake warning light comes on and car will not start
intermittently?
http://repairhelpcenter.blogspot.com/2011/12/brake-warning-light-comes-on-and-car.html
When the car stops, abs pump turns ON?
http://howtobyme.blogspot.com/2011/12/when-car-stopsabs-pump-turns-on.html
Where is Power Brake Booster located on 1995
Lincoln Town Car?
http://howtobyme.blogspot.com/2011/12/where-is-power-brake-booster-located-on.html
Sometimes ABS light comes on while Driving?
http://howtobyme.blogspot.com/2011/12/sometimes-abs-light-comes-on-while.html
All types of brake problems and
repairs
http://howtobyme.blogspot.com/2011/11/abs-and-service-light-comes-on.html
Brake
Fade Issue?
http://whoisbyme.blogspot.in/2012/07/brake-fade-issue.html
Brake System Troubleshooting?
http://technoanswers.blogspot.com/2011/11/brake-system-troubleshooting.html
Car Brake lines have no
pressure?
http://schematicsdiagram.blogspot.com/2011/12/car-brake-lines-have-no-pressure.html
Car Brakes Dragging?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-dragging.html
Car Brakes grabbing?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-grabbing.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Brakes Pulling?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-pulling.html
Pulsating Brake Pedal?
http://repairhelpcenter.blogspot.com/2011/12/pulsating-brake-pedal.html
Spongy brake pedal?
http://repairhelpcenter.blogspot.com/2011/12/spongy-brake-pedal.html
Hard Brake Pedal?
http://repairhelpcenter.blogspot.com/2011/12/hard-brake-pedal.html
Fading Sinking Brake pedal?
Feels Like Brake pedal Pulsating
http://repairhelpcenter.blogspot.in/2012/06/feels-like-brake-pedal-pulsating.html
What is Brake Drum Bar?
http://repairhelpcenter.blogspot.in/2012/02/what-is-brake-drum-bar.html
ABS light stays on but brakes
work fine?
Vibrations while braking On Chevrolet Van?
http://technoanswers.blogspot.in/2012/04/vibrations-while-braking-on-chevrolet.html
Dragging brakes?
http://howtobyme.blogspot.in/2012/03/dragging-brakes.html
Brake pedal stuck?
http://howtobyme.blogspot.in/2012/03/brake-pedal-stuck.html
After replacing brake rotors and pads, brake pedal
remains on floor?
http://technoanswers.blogspot.in/2012/02/after-replacing-brake-rotors-and-pads.html
How to replace Brake Power Booster?
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-brake-power-booster.html
1997 Chevy Tahoe Brake lights not working?
http://technoanswers.blogspot.in/2012/02/1997-chevy-tahoe-brake-lights-not.html
How to service Drum brakes?
http://repairhelpcenter.blogspot.in/2012/02/how-to-service-drum-brakes.html
What type of problems usually noticed on Drum
brakes?
http://repairhelpcenter.blogspot.in/2012/02/what-type-of-problems-usually-noticed.html
How to test Drum Brakes?
http://repairhelpcenter.blogspot.in/2012/02/how-to-test-drum-brakes.html
Brake Bleeder Screw Function?
http://repairhelpcenter.blogspot.in/2012/02/brake-bleeder-screw-function.html
Toyota Tundra: Parts diagram to
replace Brake Drums?
Squeak and grinding sound is heard when brakes are
applied?
Brake pedal is pulsating and vibrating?
http://repairhelpcenter.blogspot.com/2012/01/brake-pedal-is-pulsating-and-vibrating.html
That's a bit alarming that your brake light is on. I'm certain that there are many different reasons that it could be. My own brakes are struggling. They're not making any noises and my light isn't on, but they don't feel like they're as good as they have been. Maybe we should both take our cars in to get the brakes serviced. http://fastautotech.com/brake-service-tw...
