Rear defrost doesn't work and the light stays on alll the time
  • 70 Answers
Check to see if fuses are all good and the wire to the back window is not damaged also the element strips on window are not damaged they make repair kits sold at autopart store if all is good is it possible to check power at the switch possibly bad switch let me know how you make out
Posted on Jan 10, 2009
Rear defroster inop 2007 dodge caliber,rear def.light will not stay on,light stays on if you hold rear def.button on.
The rear defrost has a built in timer in the switch, they can fail and cause this kind of problem.
Jan 23, 2017 | Dodge Caliber Cars & Trucks
AAbs light stays on
You need to check the fuse box make sure all the fuses are okay.
Jun 27, 2008 | 1999 Ford F250 Regular Cab
2002 dodge intrepid the rear defrost button light is always on my car battery wouldnt stay charged so I took the defrost relay out the light is still on but my car stayed charged next day no charge
Dear Deseree,
I would like to suggest you are on the right track.
Next, try to find the fuse for the rear defroster, and try pulling that. That light may be a lit because of the "instruments" fuse, and if you pull that one, your instruments may stop working.
Fuses are both under the dashboard and also in a black plastic box under the hood of the car near a fender.
I might suggest there are 3 more common things that can cause the battery to drain.
1) a short in the alternator can cause this problem.
2) a short in the ignition switch, and
3) a short in the computer itself.
God bless your efforts.
Jun 30, 2016 | 2002 Dodge Intrepid
My 2006 stratus sedan rear defrost dont work and will not light up
if you push on the rear defrost switch and it doesn`t light up then check the fuses with a test light. if the fuse is good then the defrost switch is likely bad.
Sep 17, 2014 | 2006 Dodge Stratus Sedan
Kalos ABS Light stays on?
Hi I had the same problem with my 06 Kalos and it failed the MOT because of the light staying on I tried all sugestions in different forums including new abs rings new brakes etc what worked for me was swithing the ignition key on and off at least six times turning the key alll the way back and then starting the engine the light did not go initially but the next day but this was enough to pass the MOT it came back on after going over potholes but i done it again and it went off and stayed off.
Apr 07, 2012 | 2006 Chevrolet Kalos 1.4
I have a 2003 dodge neon..and the rear defroster doesn't work..it has a button for it..and it just shuts off and back windshield doesn't clear at all...even if I keep turning it back on it...
Yeah, I'd think it would have lines, too, unless some new way of doing it that I'm not aware of. Maybe the rear window was replaced with a window without the defrost option. There should be a small two wire connector coming out of the back shelf near lower driver's side of rear window. That would be the defrost connector to the window lines (that aren't there,lol).
Well, good luck with that! I think there are aftermarket kits for rear window defrost, though.
Nov 23, 2011 | 2003 Dodge Neon
The rear window will not defrost. Also the defroster and heat are not working properly. It may start blowing warm air and then get cold. Once the heater stays on and Im driving for a distance it will...
i had a 2001 cirrus that did that i found that it was a vacum line for the defrost as for the rear window if the light is on in the buttonon the dash then you might want to see if the wire that goes to the defroster on the window are both hooked up
Nov 21, 2010 | 2000 Chrysler Cirrus
Ice maker, water dispenser stopped working first, now the refrigerator/ freezer will not stay cold all the time. Just figured out today that if you push the light buttom (by the ice and water buttons) it
The light switch turns on the dispenser when door is closed if switch is not defective. If the temperatures are increasing in freezer and fresh food compartment it is most likely the defrost heater and defrost thermostat will need replaced. Look to see if ice is building on the rear wall of the freezer. If yes unplug and remove the rear panel in back of freezer and defrost with hair dryer or a bucket of hot water setting inside freezer with door closed. This way when defrosted you can examine the 2 parts that may be defective listed above, Thanks Sea Breeze
Sep 30, 2009 | Hotpoint HSS25GFP Side by Side...
Need to replace the ETACS unit
ETACS
(Electronic Time and Alarm Control System)
as far as the rear defroster, it may be the switch, relay, or fuse.
i have all of the service info on mediafire.com , just click this LINK and download whatever you need. i would suggest these 2 sections for fixing your problem:
97-99Electrical.pdf
2gTech_Info_Man.pdf
Dec 21, 2008 | 1997 Mitsubishi Eclipse
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
